Page 1 of 2 12 LastLast
Results 1 to 40 of 46
Thread: Hand propping versus Horsepower options
    zenairdave's Avatar
    Feb 2015
    Ontario
    96
    No, not another how to hand prop question.
    I am considering a lighter aircraft with a goal of 750 lbs empty weight but with 150ish hp. Something along the Super Cub, Decathlon lines. Those planes routinely are 1000 lbs plus so it will take drastic weight reduction to get there.
    Simple weight reduction (if not needed) is drop the electric start and generator like many Cubs and Champs. I don't have any issues with the A65, C85 or even O200 that I am hand propping(small engines) but at some point, increasing engine size has to make for an engine that you would rather not 'swing' .
    So the question is not how big of motor you once started but rather, how big of motor is reasonable if the only way to start it is flipping?
    I have never swung any other bigger or Lycoming motors , and hence the question.
    (and yes, it is a given, almost no interior panels, instruments, radios, ELT's etc.)
    3,529
    I know of IO-520's being hand propped so I don't think any four cylinder should be a problem. It comes down to what you can handle (bad back or shoulders?) and what you are comfortable doing (training).
    Likes Hardtailjohn, 40m, mike mcs repair, FdxLou liked this post
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    783
    The worst engine I ever hand propped was a stock Lycoming O-360 with a short, lightweight wood prop. The lack of prop mass and inertia makes a big difference. An O-320 with a long prop shouldn't be too bad, as long as you can reach it reasonably.
    7,280
    79 here - no problem propping an amphib Cub with O-360 from behind. Metal prop.
    Likes barrow pilot, mike mcs repair, FdxLou liked this post
    Jan 2005
    Fowler, Ks
    593
    I propped a heat soaked io360 with 3 blade hartzell. Counted my fingers after it lite off
    Likes irishfield, mike mcs repair liked this post
    zenairdave's Avatar
    Feb 2015
    Ontario
    96
    Quote Originally Posted by flynlow View Post
    I have heard that 3 blade props decrease your chance to get out of the way.
    11,119
    An O-320 or O-360 is a piece of cake to prop, once you first learn how to start them. I’ve propped larger engines, but wouldn’t want to do so routinely
    Likes mam90, mike mcs repair, Brandsman, eviens liked this post
    Wolf Lake, AK
    5,649
    Targeting 750# would be much easier with a lighter engine.
    May 2017
    777
    Used to hand prop a 150 HP Super Cub all the time. I’ve propped R985s on AgCats and my Howard many times. Size isn’t so much a problem, prop position, flywheel mass, and compression ratio are the keys.
    Nov 2019
    Kalispell, Montana
    18
    I've hand propped various airplanes from time to time but refuse to do it now. Two of my friends who were very experienced have had props kick back and whack them on the back of their hands. I have a Catto prop (which is very light) on one of my planes, and no way would I let someone hand prop it. You need to have a heavy mass to swing. Years ago I let the Flathead Forest Supervisor hand prop the Cessna 206 we were flying that day. Stupid! He said he could do it, and he did. Normally he flew a desk.
    Hardtailjohn's Avatar
    Marion, MT
    813
    I've hand propped lots of engines...big and small. The absolute worst and most scary was a volkswagen in a Sonerai! Easiest was a 985. Like said above, mass of the prop has lots to do with it...Are you planning on higher compression, or other performance mods? I don't know how comfortable a Catto or some other really light prop would be. Use your head and you shouldn't have any problems.
    JH
    Thanks flynlow thanked for this post
    JimParker256's Avatar
    Aug 2015
    Farmersville, TX
    409
    As I was reading this thread, I was thinking "Man, I would NOT want to try hand-propping my Rotax 912ULS, with 2.43:1 gear reduction system and light-weight composite prop... Not sure it would be possible to get the engine spinning fast enough to light off... LOL
    Fortunately, it's got a full electrical system and starts quite easily, so not something I've had to lose any sleep over.
    Jim Parker
    2007 Rans S-6ES
    Thanks Toro thanked for this post
    10,309
    Remember that the taller the landing gear the greater the prop angle is. Prop at the 6 o'clock position might be 1 to 2' closer to your legs then the 9 o'clock position if your out front
    DJ's Avatar
    Jan 2009
    Bolivia
    254
    Search Lil Cub to get an idea of an 800 lb Cub with O-320.
    zenairdave's Avatar
    Feb 2015
    Ontario
    96
    Yes it would but I already have that with a Clipwing J3 Cub with O200.
    Looking at a different mission with more power and more wing. Not as easy to get the weight down.
    zenairdave's Avatar
    Feb 2015
    Ontario
    96
    [QUOTE=DJ;784234]Search Lil Cub to get an idea of an 800 lb Cub with O-320.
    When you look at Lil Cub, it seems like an impossible mission. LOL. Although I think it said 685 lbs?
    May 2014
    109
    Since some mention of Catto's is being made in this thread:
    I hand prop a high(er) compression O-235 with a Catto 76" prop. It can be a pain the a$$ some days, but the prop is not a problem. I would not hesitate to prop a 320 with a Catto, and it would probably be easier than what I do now...
    Likes Toro liked this post
    11,119
    I've never propped a plane with a Catto prop, but I've propped several O-360a with MT composite propellers. That's best done wearing a glove, since the trailing edge of those props is pretty sharp, but I've done it bare handed.
    I always prop from behind if at all possible, in any case. To make that work, you need to index the prop so it stops at 10 and 4 o'clock, as viewed from in front.
    Aviat started indexing Husky props at 12/6 years ago, and those are not friendly to hand prop, though I've done it. We re-indexed those props for that reason. The good thing about composite props is that they eliminate most vibration issues on these engines, so re indexing is not a big problem.
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    199
    I prop my high compression 0-200 with a 78” catto no problem and my pacer with a o-320 is no problem either
    May 2012
    SE Montana
    278
    Unless you're committed to a lycoming, consider the Yamaha Apex motor to save about 100 pounds, and still get 160-300hp...
    DJ's Avatar
    Jan 2009
    Bolivia
    254
    I'm pretty sure the 685 lbs was with a small continental. He later put a high performance 320 on Lil Cub.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    Good luck making 750lbs. You will be lucky to make 900lbs empty with an O-320 unless you sacrifice everything that makes the plane easy to live with.
    Lil Cub is a purpose built machine for short local hops and competition. You don't want to spend $$$ on a build so that you can only go a few miles from your home base at 65mph cruise speed.
    Likes DENNY, RaisedByWolves, G44, eviens liked this post
    2,181
    Around here most 150 hp supercubs are around 1200 lbs. Very light non electric ones might go at 1,000 lbs. If you want a 750lb plane don't even consider a Super Cub. How much does you J3 weight empty?
    Likes supercrow, Crash, Jr., eviens liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    Denny, my J3 is around 735 empty (book weight) but that's probably optimistic. On top of that, the J3 has what I'd consider the bare minimum for a flying machine to be useable and even that is debatable. Add a baggage you can use and some big tires and it's probably around 800# if you put it on scales.
    For a 150/160 horse plane I'd target 1000lbs. There's a few guys out there with planes that light and they work great that way. Another thing to consider is that 1000lbs is with some pretty heroic measures in the build process like drilling out every piece of channel, lowered floorboard mod, going thinner on boot cowl and leading edge material, no electrical system, no lights, and almost zero instruments. Basically a big J3 in essense.
    The point is that a 750lb 150hp cub is a dream. It's never going to happen. Hell the engine is 200lbs all on its own so it would be pretty nose heavy at that weight.
    BUT I will say a light cub is a fantastic thing. All this talk of shock absorbers and big tires is cool but when you're flopping 50% less aircraft weight into the ground the bungees and little 26's work just fine. I've muffed up some landings pretty good and still had respectable results just because there's so little amount of plane to get slowed up and stopped.
    Likes PerryB, flynlow, RaisedByWolves liked this post
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,005
    Quote Originally Posted by Hardtailjohn View Post
    JH
    Yes the PW radials are pretty easy prop. Low compression and plenty of flywheel. You also get lots of choices on prop position. Nine, over the course of two revolutions.
    Marion, MT
    813
    The most fun one was underneath and behind, while on floats.
    JH
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,005
    What could possibly go wrong.....? Besides the engine starting as you subsequently fall off.
    2,533
    I did it once on a Beaver floatplane 2-blade. Dumb me had let the battery get low or it was too cold +20F and snow. Rope with loop over one blade pulled a few times facing into the shore. Started because we put a coleman cook stove under the engine with tent tarp over the top. The battery was old plus still in the rear and the chief pilot thrifty.
    Likes Cubus Maximus liked this post
    Sep 2002
    Southern NH
    719
    180 on floats while drifting downstream rapidly on the Skwentna River... Not intentional and not fun....
    3,529
    But very motivational.
    jnorris's Avatar
    Wisconsin
    865
    I used to hand-prop my 180 hp Pitts all the time. Metal prop, so no problem. Piece of cake actually. It started easily, usually on the first or second blade. Not a problem at all.
    Joe
    Fortis Fortuna Adiuvat
    Oct 2006
    Seldovia, Alaska
    190
    JH
    I had occasion to hand prop a 985 on a beaver with a three bladed prop, on floats from behind. Teaches a guy not to make a long taxi with the landing light on and a generator that won’t keep the battery up.
    Likes mam90, jnorris, Cubus Maximus liked this post
    Marion, MT
    813
    Read it again...I was in the water, behind the prop. Worst part was as the spreaders came over my head, I had to go almost all under water. Good hot day, not in Alaska!
    JH
    Dec 2014
    87
    I have never operated with a starter. Skis and tires. From a stock and 9.5:1 c90 Pa11 to stock and 10:1 320 to a stock 360. All with cattos. I’ve started a few and flew probably 2 hrs worth of cubs that have had them. Feels weird pushing a button. I can look at my 360 with long catto and it will start. Second to 3rd blade EVERY time unless it’s sat for a few weeks which it just takes a couple more pulls. No primer lines either. Learning how they like to start is key. Hot or cold etc as both are different. After flooding it about 3 times you will have it figured. Where a glove. It’s easy. Most don’t even know how to start their rig if the battery dies in the field. Lord help them. I will admit though for a height challenged individual it may be difficult and may have to index prop differently. Have ran Bendix and Slick. I like Bendix better with just the one impulse on the left side. I’m 6’2 and with 6” gear 35” and TL I do have to reach up fairly good to grab mid- 3/4 prop. Ditch the weight. Not needed. Just be aware of what your doing and where body is.
    Likes KevinJ, Hardtailjohn, marcusofcotton liked this post
    Snert's Avatar
    Mar 2006
    Raleigh, NC
    1,763
    Quote Originally Posted by jnorris View Post
    Me too. 180 and 200 both with high compression. I did a 540 on a Pitts with a three bladed MT a couple times. Probably will not repeat.
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    783
    I had a lot of people offer to swing the prop on my 200 hp Pitts - once. After that, it was, "I'll guard the throttle for you."
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    Don't forget to have a machinist trim the starter mounting boss off of your engine cases to save that extra 10oz. If you're gonna be crazy about weight you gotta go all the way!
    Dec 2014
    87
    One can shed much weight w/o carbon and w/o getting too crazy really. Headliner, panels, flywheel/ring gear, battery (even light) starter (even light) alt (even light) all the wire, solenoids so on. Throw a composite wheel on and one can shed 50lbs easily. Your typical who isn’t staring it 15x a daily..it really is not a nuisance at all. Get in a routine. A very basic light c90/0200 PA11 is a phenomenal single man plane and can work very short areas with the wallet thanking you. To answer the mans question, yes no elec 150 Hp at 750-800 lbs is doable and would
    be a fire breathing animal that most heads would turn at.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    On a supercub with flaps and 150 horse I could see 950 or even 900 with heroic measures but I really don't think 750-800lbs is possible. Game on though, I'm building just such a plane right now so I guess in a year or two (hopefully, maybe) we shall see.
    Dec 2014
    87
    All depends on what a guy is willing to rid. And how deep pockets are. 31’s? Oratex? What ribs? So on. Be tough yes. The word “super cub” is broad it seems. I once saw pa11 weight at 830. About 10 coats of paint. Bla bla. Many areas of it to have dumped weight. I just noticed the man mentioned more wing...if so, not a chance.
  1. Hand propping a 0-320
    By tempdoug in forum Cafe Supercub
    Last Post: 10-18-2011, 06:57 PM
  2. Hand propping a 0-360
    By ksecub in forum Experimental Cubs
    Last Post: 09-10-2006, 10:56 AM
  3. Hand Propping
    By StewartB in forum Cafe Supercub
    Last Post: 08-19-2004, 07:20 PM
