Results 1 to 21 of 21
Thread: Wing incidence
    Oct 2017
    45
    Wing incidence
    Ok here we go, my head is in a spin and already completed 20 turns. Lol.... I have read the wing incidence on a PA18-150 should be + 1.813 deg on the bottom of the root rib. Also have seen published +1 degree on the root rib. Of course the airframe level in the longitudinal and lateral axis. I have also been told the reading should be taking in line with bolts that attach the wing. Someone throw some more rudder in.
    This is an Experimental airframe, so if the incidence is measuring + 1 degree and should be + 1.8 how much will it effect flight?
    5,445
    .8
    Oct 2017
    45
    +.8 degrees? And where should you measurement?
    5,445
    Just being a dumbass. I don't know what it'll do but Id rather have .8 degrees more than .8 degrees less. Others would say the opposite. I'd expect your takeoffs will be a few feet longer and your cruise speed a few MPH faster.
    The best two guys I know to ask about rigging measurements are AKPA-18 and Cubflier, both who check in once in awhile.
    nd
    3,605
    2,408
    Nov 2002
    Fargo
    729
    Easiest way on a bare frame is to put 2 AN5’s in the wing fittings and use a 29-1/2” straight edge and a digital level, zero the level out on the 2 tubes between the front gear fittings and the rear fitting’s that should be inline with the horizontal reference line that all angles should be measured against, you can also use the firewall as an alternate. The number should be between 4.4*-5.3* with 4.8 equal to the 1.84* you are looking for, the closer to 5.3 the better.
    Oct 2017
    45
    PA-22/20-160
    That's one way I have checked and getting around 4.48* using this method.
    Oct 2017
    45
    My head is spinning!
    Nov 2002
    Fargo
    729
    Quote Originally Posted by Bucrepus View Post
    What’s confusing? You have a fuselage that meets piper’s spec On the low end but could fly a lot nicer if you fix it now.
    Likes DENNY liked this post
    Oct 2017
    45
    Here is an article on wing incidence that will raise some discussion.
    https://www.flyingmag.com/pilots-pla...ing-incidence/
    2,107
    It is not just the wind incidence you have to think about. Also the tail angles and engine thrust line. A higher wing incidence will give you a better view over the nose but now you have to adjust the tail for proper decalage, also the engine thrust line. Another thing to consider is are you doing big keller flaps and what effect do they have on the cord line of the wing when deployed and how does this effect the stabilizer decalage? Just more to ponder.
    Oct 2017
    45
    With a fixed incedence angle, the decalage is variable in respect to incedence, with the trim of horizontal stab. Just thinking out loud. Is trimming the aircraft nose UP and Down causing the decalage to go positive and negative?
    No tricked out plane here just building a widebody with standard wings.
    10,487
    decalage
    Vermont
    332
    Right, he should have said "longitudinal dihedral".
    What's a go-around?
    5,445
    Or angle of the dangle. Because we all understand what he was talking about.
    cubflier's Avatar
    Nov 2003
    1,301
    You are closer to the design wing incidence than you think. Read the thread posted by tempdoug. It is the one of the more accurate references to wing incidence and associated angles. As for using AC 43-16, be careful there, as you cannot read that document in literal terms. The wing incidence of 1.843 that Gordon Mandel is referring to is not a reference to bottom of the spar caps. It's a reference to the bottom cord of the wing rib. To convert to a spar cap reference you need to subtract .5 degrees. Another quick measurement is to see if there is a 2.5 inch difference between wing attach points in relation to the HR. In a perfect world you can take this from the tube that defines the bottom of the window to see if you are close.
    In the building process an easy way to add incidence is to use Javron's doublers that can add 1/4 to 3/8 inch as I recall.
    I am curious about your wide body fuselage. Is it new airframes or home grown?
    Have fun with your project.
    Jerry
    If it looks rough...it is!!
    Likes Bucrepus liked this post
    Oct 2017
    45
    Tempdoug,.
    Curious on how to arrived at 1.8 deg aft of the jackscrew tower. I keep coming up with 1 degree 3 minutes. my calculations were based on 9.574" from the hor. ref line to the center line of top longeron directly below the jackscrew (cluster) and the 10.125 from horizontal reference line at the tail post to top logeron.
    cubflier's Avatar
    Nov 2003
    1,301
    Tempdoug,.
    The thread is from another member SD2.
    Here is how I come up with his answer.
    Take inverse sine of ((16 - 5.438 )/29.438 ).
    Notice 10.125 does not extend to the HR.
Name:	Screen Shot 2020-09-25 at 12.01.20 PM.jpg
    Jerry
    Last edited by cubflier; 09-25-2020 at 03:16 PM. Reason: fix the smiley face error with sunglasses from 8 next to )
    Oct 2017
    45
ID:	51303Click image for larger version.
    Jerry,
    The print on the right is North Land Drawing, print on the left is other Drawing.
    If you look at the difference in the reference line there's an .437" difference.
    Left Drawing
    angle= 1.897 deg
    Right Drawing
    angle= 1.048 deg
    This is also the reason in another thread I couldn't use the factory aft horizontal support bracket and had to use the other.
    Jerry Thanks for inadvertently pointing me to the reference line. Now the million dollar question how much will this affect flight?
    If I use the other aft stabilizer support bracket I have the correct amount of Trim Travel 4 degrees down 2.5 degrees up.
    Oh the unknown
    Ignorant is Bliss!
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,029
    Look at the difference between the -18 -12’s , i can’t remember the difference but it might give you an idea how it will fly.
  1. Wing Incidence
    By NunavutPA-12 in forum Cafe Supercub
    Last Post: 04-24-2015, 06:10 AM
  2. Pa-12 Wing Incidence Mod
    By bushwannabe in forum Cafe Supercub
    Last Post: 02-12-2014, 09:31 PM
  3. Wing Incidence
    By joecub in forum Cafe Supercub
    Last Post: 04-09-2009, 11:25 PM
