Results 1 to 15 of 15
Thread: Lycomming io-233 or o-233 issues
    Mar 2020
    4
    Are these engines any good? What issues have they had and have they been resolved? My search on the web has not returned much information.
    Forrest
    19,951
    I am told by a flight school operator that the electronic ignition last 100 hrs and then has to go back to Champion for repair consistantly.
    Mar 2020
    4
    Thanks Steve.
    Does anyone else have any feedback?
    Forrest
    10,504
    I don't have any experience with this engine. However, based on what Steve said I would wait until the bugs were worked out before committing to using one. Having to send the ignition back every 100 hours is basically limiting you to the home traffic pattern, to say nothing of the inconvenience.
    I am a fan of electronic ignition. It must be totally reliable to be useful. 100 hours is not reliable.
    Mar 2020
    12
    Further to Steve’s input, I concur the Ignition is unique to this model engine and problematic! .... so unable to change out to something with proven reliability...
    19,951
    If it is experimental you could install mags or what ever. The one I exampled is an SLSA used in a flight school and Lycoming maintains the ASTM standard and they would have to approve the change if SLSA is retained.
    Likes SJ liked this post
    Mar 2020
    4
    This engine has been out for several years. Not having the issue resolved by now doesn't look good on lycoming or champion. In my business there would be Managers and Engineers fired for this. I wonder how they are keeping it under the radar? You would think that one would be able to find more information on the web about the proplem.
    Appears to me that anybody that bought this engine has a plane that has the value of one needing a new engine unless they sell it to an uninspecting sole.
    I'll stay away.
    Regards,
    Forrest
    Jun 2015
    156
    I have the 233 in my S-7 and have about 275 trouble free hours on it. I chose that engine because Lycoming called me and asked if I would make exhaust systems for it. During the building time they sent me at least 3 new ignition systems and the engine hadn’t been started yet. I really didn’t want to be a tester for Champion so I installed a dual lightspeed setup. It’s been trouble free and a proven system.
    JimParker256's Avatar
    Aug 2015
    Farmersville, TX
    391
    Quote Originally Posted by Ffoster View Post
    Well, Champion managed to keep their spark plug problems "under the radar" for over 10 years until enough of the aviation forums "outed" them that they were forced to fix the issues... I suspect there just aren't enough airplanes using this engine to have achieved "critical bad PR mass" to raise the attention of Champion management.
    Frankly, at this point, they've sullied their corporate reputation to the point I just avoid anything the company manufactures... It's one of the reasons I now fly a Rotax-powered airplane – it's just not easy to avoid Champion products if you fly Lycoming or Continental engines...
    Jim Parker
    2007 Rans S-6ES
    19,951
    Forrest
    So what are you planning on putting this engine in?
    Mar 2020
    12
    “If it is experimental you could install mags or what ever. The one I exampled is an SLSA used in a flight school and Lycoming maintains the ASTM standard and they would have to approve the change if SLSA is retained.”
    Thanks Steve, that is a much better way of explaining it. I was referring to LSA category.
    Likes pfm liked this post
    19,951
    Quote Originally Posted by redfin View Post
    ELSA or SLSA?
    Mar 2020
    4
    Experimental. Salon, wanted to know if one should stay away from an slsa with this engine.
    Thanks for the replies!
    Regards,
    Forrest
    19,951
    Are you going to instruct in it? If not no reason not to convert to ELSA
    Aug 2009
    Cent. CA
    8
    We have yo-233 in our Super Legend-first failure at 180hr, replacement from Champion, which we waited for several months to receive, failed 35hr later. 2 mags is not an option as the accessory case only has one hole. Champion comped us a Slick mag (Champion again), added a single Lightspeed. Only about 10 hours on this setup. Working ok so far. Needless to say, this has been very frustrating. Champion management knows ALL about the situation.
    Thanks marcusofcotton thanked for this post
  1. Replies: 3
    Last Post: 02-01-2018, 11:40 AM
  2. GPS issues?
    By mike mcs repair in forum Cafe Supercub
    Last Post: 05-02-2010, 07:28 AM
  3. New Lycomming
    By OLE Yeller in forum Cafe Supercub
    Last Post: 09-11-2005, 12:23 AM
