scottsville
Looking like I will need to replace my Mags soon. Any body running the electronic ignitions on there super cub? Thoughts? Brand? Performance?
Thank you!
Scott
Thank you!
Scott
My engine is has been loosing power over the past year or so. Just really noticed it the other day! Lost about 100 rpms on climb out than I had been seeing. Its not swinging the prop to the rpms it should be. Just seems to be getting worse the more I fly it. the mags are Bendix and are 2010 models. Going to check timing soon and hope that is the problem. I have owned the SC for about 2 years and it just doesn't seem to have the power it should and seems to just be getting worse. bought it with 200 hours on a Penn Yan over haul. About 500 on it now.
I have Elctroair in my exp cub. Replace one mag with electronic and kept one for redundancy.
I can tell you it starts in 1/2 a rotation hot or cold. Also put a MT prop on it at same time so take the performance gain with a grain of salt but it responds immediately to throttle commands. Fuel burn improved. If you can’t tell I love it. Can’t think of one negative thing about it.
The Electroair system is sweet but you do pay for it. I forget what the 4-cylinder system is with installation but a 6-cylinder runs about $8,500 in the Twin Cities area. It’s a great system, seems well-thought-our and has even impressed us grumpy mag devotees. It cut our demo 182’s fuel burn by about 1.8 gph and it it runs so smooth and starts so nice. Idles really slowly too, really nice for short strips and float operations. But, as SB mentioned, if you don’t have the variable timing you give up most of those benefits except your airplane will start better.
SureFly will be a great option once their electronic ignition has variable timing on it. It requires less modification to install and is cheaper than a mag. But, not sure when this will be done. I’ve been watching and waiting a while.
—Amy
What MT prop did you put on it? Yes definitely going with electronic ignition if I change them.
Thanks[/QUOT
MTV-15-B/210-58 with Nickle leading edge.
—Amy
SureFly variable timing is now approved for the PA-18 (see the AML, changed Aug. 2019 - no note 4 for PA-18 ).Get one with variable time or wait til SureFly gets it approved. The magic of EI is lost in the certified world.
Have you done a 500 hr inspection on your mags? It's time for it. Web
Anyone here actually have time running a Surefly? I'd like to here input on installation and operation.
I have zero experience with the electronic ignitions being discussed here, but my airplane, equipped with an O-360 does have a LASAR ignition system installed. I didn't install it, so have no before and after comparison.
But, this ignition does increase cylinder head temperatures about 20 to 30 degrees, near as I can tell. With many installations, that's not a problem, but there are a lot of tightly cowled airplanes out there that might not like that.
Again, I don't know if this is the case with other EI's, but I've been told that if you advance the ignition timing, you'll make more heat.
Use one of the fuel injector ports which are plugged on the top of the cylinder.The installation is very straightforward. It does require an unswitched circuit from the battery so depending on the airplane there is a little labor involved in wiring.
To utilize the advanced timing feature it obviously requires a manifold pressure connection. That means on a cub you are going to loose one primer nozzle unless you add a boss to one of the induction tubes.
Good call if you have them, I have only seen OEM's use the primer port. Of the two 4-cyl Lycomings in the shop right now one has them, one doesn't.Use one of the fuel injector ports which are plugged on the top of the cylinder.
