Results 1 to 19 of 19
Thread: Using self locking nuts on drilled shank bolts
    Dec 2019
    COLLEGE STATION, TX
    54
    Is it acceptable? I understand it may be sloppy but...
    8GCBC's Avatar
    Nov 2011
    Oahu
    1,786
    Any heat involved?
    In tension or shear?
    2018 R44
    IA/A&P, ATP, SES, CFII, MEI, Rotor PPL (2500 TT)
    http://www.youtube.com/watch?v=SXI48e1heuo
    11,283
    Quote Originally Posted by sdischer View Post
    Doesn’t bother me as long as not a rotating joint.
    But much more expensive bolt than undrilled bolt.
    I stock both in good quantities finally.
    Dec 2019
    COLLEGE STATION, TX
    54
    Quote Originally Posted by 8GCBC View Post
    Any heat involved?
    No
    Shear.
    I just ordered the wrong boltS and I don’t want to wait three more days for them to come in LOL
    Dec 2019
    COLLEGE STATION, TX
    54
    Thank you everyone for your opinions.
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    679
    No issue at all using self locking nuts on a drilled bolt.
    Likes mike mcs repair, ak49flyer liked this post
    3,610
    So long as the drilled hole is not in the grip portion of the nut. 43.13 as something on this, that is more exactly stated.
    Jan 2008
    Arlington, WA
    679
    Can you point to the exact section of AC43.13 that states this Gordon?
    3,610
    Well, I may have egg on my face. I can't seem to find a pertinent reference. I know I've read that stipulation somewhere - maybe not 43.13. Seems section 7-34 and following sections would apply. Anybody able to help clarify this?
    Jan 2008
    Arlington, WA
    679
    Yeah I can clarify it. It’s standard practice to use a bolt with a drilled shank and a self locking nut if a bolt without a drilled shank isn’t available. As Mike pointed out it’s slightly more expensive. But it moves things along.
    Charlie
    A&P/IA
    3,610
    Charlie
    A&P/IA
    Agree. How can it possibly be wrong? But it still bugs me to find an official reference. Arlington and Toledo aren't that terribly distant - we should touch base one of these days.
    10,358
    "Here is another reminder about self-locking fiber nuts (reminders are sort of rules, too). Do not make a habit of using a self-locking fiber insert type of nut on a drilled bolt smaller than 5/16" in diameter. If you do use a drilled bolt, be sure that there are no burrs around the cotter pin hole that could tear into the elastic insert. Maybe they make too much of this rule but then again, who wants to drive around with slashed tires even if they do hold air?"
    http://dad.walterfamily.org/rv/TonyBingelis/Are%20You%20Using%20Aircraft%20Hardware%20Correctl y_.html
    S2D's Avatar
    Montana
    4,195
    Thats the only part i remember about their usage.
    Jan 2008
    Arlington, WA
    679
    I think we were both at the aviation trade show in Puyallup a few years ago. I ran into Eric there but didn’t see you. Stop by my hangar in Arlington sometime and check out my project. I am right next to the Castle & Cooke gas pump.
    5,306
    So it's okay to use castle nuts on bolts with burrs???
    19,798
    Piper did it when they moved from castle nuts to self locking nuts. After seeing some bolts in tension fail at the cotter pin hole I make sure I don't do it.
    10,358
    I too have seen that, but generally consider the bolt was too short for the application. As long as the cotter pin hole is outside of the threads of the nut even though inside the elastic stop, the bolt should not break.
    Likes bob turner, mike mcs repair liked this post
    19,798
    I don't remember the application, many years ago on a warbird. I have a good collection of hardware so try and use the corresponding bolt to match the nut.
    Jan 2008
    Arlington, WA
    679
    Yeah I have a pretty good collection of hardware too. When I run across it I’ll try and change the hardware cause it hurts my eyes.
  1. Con-rod nuts and bolts
    By jon s. blocker in forum Cafe Supercub
    Last Post: 01-17-2013, 05:48 PM
  2. Screws,Bolts,Nuts and Cotter Pins
    By Flying Miss Daisy in forum Cafe Supercub
    Last Post: 05-22-2007, 07:13 AM
  3. nuts and bolts
    By Laz in forum Experimental Cubs
    Last Post: 11-14-2006, 10:04 PM
