Page 1 of 2 12 LastLast
Results 1 to 40 of 70
Thread: Pa 18 dash
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    337
    Pa 18 dash
    Looking for ideas on a dash lay out show me your ideas
    Grant's Avatar
    At Work.....
    1,785
    5,306
    Oh what a difference a decade makes!
    Likes CamTom12, RVBottomly liked this post
    3,257
    That's like asking what's the best whiskey or who's the prettiest woman.
    Biggest rule is DON'T OVER DO IT! Keep it simple and small. And the ONLY panel equipment that absolutely must be installed are the items called out on the TCDS. These are oil pressure, oil temp, tach, altimeter, airspeed, and 'magnetic heading instrument'. These items need to be certified primary instruments, so no experimental stuff for them. All other panel items are your choice.
    My recommendations: CGR-30P for engine instruments. This will give you all of your engine instruments in one 3 1/8" hole. Winters altimeter and airspeed indicators as these units (see Wing & Wheels website) have light weight plastic cases, are available in 2 1/4" faces, and are used in certified gliders so meet the TCDS requirements. Winters also has a model with a 510º movement which gives wide spacing at the low speed markings.
    A few other things to consider: Use a key switch with 'start' position instead of toggles and/or push buttons, as you can get all functions in a single mounting hole in the panel. Keep your switches and breakers in a single row along the lower edge of the panel. Use switch breakers for items such as lights to combine the switch and breaker functions into a single hole. Use the small faced avionics such as Becker or Trig as they mount like a small instrument into a hole in the panel. Remember that Cub panels were never designed for tray radios. I always recommend a stand alone intercom to go along with the radio.
    As for the layout, the best I have used was designed by a HIGH time pilot up here. In your mind, imagine you're maneuvering in a Cub. Your left hand is on the throttle and your right hand is on the stick. If you place the PTT button on the stick, you can talk on the radio without moving your hands. If you slide your left hand off the throttle and straight forward, you should be able to punch the mixture knob to the full rich position. About 8" up the panel, place the carb heat knob. This arrangement allows you to control engine power with a minimum of hand movement. Another trick, from MCS Mike, is to place the key switch just above the primer. This allows you to push the primer while cranking the engine. And if you place the key/primer on the right side of the panel it frees up your left hand to control the mixture and throttle. Helps out on a hard starting engine or on cold days.
    And don't forget at least some type of panel lighting. Check out the little LED units made by Whelen that mount on the left or right overhead panels and shine down on the instrument panel. One model has both red and white light in the same unit. Nice to fly with the red light but load/unload with the white light.
    Get all of the info that you can and plan out your panel. Then re arrange it until you're happy that it will work well for you. Only then, start to cut metal.
    Thanks arcticairalaska, Charlie Longley thanked for this post
    Likes Toro liked this post
    storm_pilot's Avatar
    Feb 2004
    Casselton, ND
    151
    Buying parts is CHEATING!
    Likes stewartb, CamTom12, RVBottomly, motosix liked this post
    Sep 2007
    Fairbanks, Alaska
    99
    Paint white , night flying you want the instruments getting the light available.
    Sandy
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    750
    I guess I'm more of a traditionalist. The ram mount in the middle keeps me from being tied to any particular magic screen.Click image for larger version.
    Grant's Avatar
    At Work.....
    1,785
    Exactly what Web said.... IMHO He pointed out the key items. I would only add that I recently saw a Supecub with the airspeed way over on the right and the Altimeter way over on the left. It is just so non-standard that it could make it confusing when you need it to be intuitive. Dont get too creative is all i'm saying....
    3,257
    Quote Originally Posted by Grant View Post
    . . . the airspeed way over on the right and the Altimeter way over on the left. It is just so non-standard that it could make it confusing when you need it to be intuitive. Dont get too creative is all i'm saying....
    Lol! Seen a couple of those.
    With the CGR-30P and the small Altimeter and airspeed, you could leave those instruments in a cluster on the right, put the com, intercom, and even a transponder on the left, and have most of the center panel open. Gives you freedom to mount almost any kind of screen you like to fly with.
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    84
    Here’s mine.
    Thanks jrussl thanked for this post
    Likes AkPA/18, jrussl, LMartin liked this post
    AkPA/18's Avatar
    Big Lake Ak
    708
    Quote Originally Posted by nightflyer View Post
    Here’s mine.
    Could you educate me? The only electronic gauges I have are the EGT CHT and Horizon. You get your AirSpeed from the iPad? I haven't graduated to the cool stuff yet and don't understand most of it
    http://thrustline.com/
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    84
    [QUOTE=AkPA/18;782434]Could you educate me? The only electronic gauges I have are the EGT CHT and Horizon. You get your AirSpeed from the iPad? I haven't graduated to the cool stuff yet and don't understand most of it[/QUOTE
    The original airspeed indicator is there on the left side, CGR-30P for engine info, Trig radio and transponder, Garmin 796 in the middle, original altimeter on the right, and an RC Allen digital attitude indicator.
    Likes jrussl liked this post
    AkPA/18's Avatar
    Big Lake Ak
    708
    I just saw that LOL for some reason I thought it was the combo oil temp pressure gauge. Obviously I should not be allowed to have the cool stuff LOL
    11,283
    Here are some I’ve done. Probably outdated with all the new all in one stuff
    https://photos.app.goo.gl/BrNDAhxKLyGwMpnQ9
    3,257
    You mean like that row of E.I. gauges? Now you can install a CGR-30 and have more functions than all of those gauges combined, lol. One of the good changes, in my opinion.
    May 2014
    98
    7" tablet on left, Dynon D180 top center, Trig txn and radio bottom center. Standard width fuselage.
Name:	Panel Assembly Backside Tray v36.png
    Final installation came out very close to this model.
    Likes Bender liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    125
    The uninitiated could think we were talking about home theaters with all the screens on some of these panels. Less is more IMO.
    Feb 2004
    Mt.
    1,334
    Quote Originally Posted by AkPA/18 View Post
    I am with ya Mark, the cool stuff doesn’t seem to be as resistant to ejecting 3” mag empties bouncing off it. I guess I will never be cool but I hate things that are always needing a software update or give a different reading every startup, all I want is reliable info.
    Eyes Above
    Sep 2018
    SE NH
    3
Name:	pa 18 panel.jpg
ID:	51073Recent panel used for fish spotting. 496 runs marine charts and has xm weather and music. Bottom Furuno is used to convert Lat/Lon to TDs. Both come out at the end of the season. The Garmin 175 gps feeds the G5’s. Audio panel supports two VHF marine radios mounted aft and controlled by ram mics mounted over head. Transponder has ADSB out. iPad is connected to the 175 for data and WiFi connected to a stratus ADSB-in portable receiver for traffic.Only regret is that I didn't upgrade the transponder to receive ADSB-in. That would eliminate one the portable Stratus with its charging cable. Thinking of trying iLevel BOM for ADSB-in. That would get rid of the stratus portable. I hate doing things twice. It would have been cheaper to get the more expensive ADSB- in transponder in the first place. CGR-30P is by far the best addition to the panel. Fuel use is accurate to 1/2 gallon on every fill up. Plane hold 68 gallons.
    3,257
    Quote Originally Posted by mikeleary03844@gmail.com View Post
    I think it's safe to say that you and I have 'differing philosophies' on panel set ups.
    But a couple of ideas for yours. G5's have built in GPS. The only time you need external GPS input is if you use the HSI version to display GPS NAV inormation. If not then they can be stand alone. Also, Becker Avionics has a single control head that can operate multiple coms. With multiple coms and limited panel space, this works well.
    5,306
    The only guys who knock it are guys who haven't tried it. The G3X Touch is far superior to round instruments. I'm sure Dynon is the same. Amazing, simple, and intuitive.
    3,257
    Big difference between certified and experimental equipment available.
    5,306
    RaisedByWolves's Avatar
    Feb 2005
    4,072
    Off topic, are the garmin G5’s certified for airspeed replacement? Get rid of airspeed and altimeter?
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    125
    I too am a big fan of simple and intuitive
ID:	51093Click image for larger version.
    Likes LMartin liked this post
    3,257
    Attitude and HSI are the only certified versions.
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,422
    Transmitted from my FlightPhone on fingers...
    Likes 1934A, mike mcs repair, motosix, hottshot liked this post
    May 2014
    98
    "tHaT dAsH lOoKs To0 cOmPliCatEd"
    ...typed on a laptop via a wireless connection via HTTP across TCP/IP from your couch.
    A single tablet and a single simple flat panel display (that replaces 19 different mechanical round gauges) is way less complicated than it looks. You might actually even like it?
    2,062
    I love a big GPS screen mounted as high as possible (like the top pic in Farmboy post) This lets you keep an eye on the terrain map and look out with peripheral vision to avoid hard stuff. Low mounted GPS are fine if you know the area well or never scud run.
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,422
    Pa 18 dash
    Denny, I enjoyed that panel as well - those pics are both the same panel in my last cub.
    What people tend to not notice in photos is the side cutouts for better 45deg vis.
    Pb
    Likes mike mcs repair, DENNY liked this post
    Mikey's Avatar
    Everett, WA
    521
    iPad Mini w Targus rotatable mount (from Best Buy w covers removed)
    Appareo ADS-B transponder w Stratus II mounted on top of Appareo behind panel blank
    180TigerCub's Avatar
    Jun 2004
    Penn Yan, NY
    8
    Current panel upgrade in process...
    The 275's wont fit as they just touch the cross bar.
    Replacing with G5's as a result.
    180HP PA-18
    Likes Colorguns, AkPA/18 liked this post
    Waldo M's Avatar
    Jan 2018
    Finger Lakes area, western NY.
    70
    A little off subject because it is a PA-11 panel. I like simpleClick image for larger version.
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    367
    Time to clean it up and a few upgrades too.
Name:	pa12 panel.jpg
    Likes 180TigerCub liked this post
    3,149
    Quote Originally Posted by arcticairalaska View Post
    FWIW I don't think I've ever seen an airplane with a white panel.
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    679
    Here’s mine.
    How do you like that SIRS compass? I put one in a 172 this year. Seemed like a nice unit.
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    84
    Charlie, it doesn’t work worth a darn but that’s because of all of the metal that surrounds its, it’s only there for legal reasons. I imagine it would works great if it was in a different location though.
    10,988
    No compass is going to point accurately, mounted right between two steel tubes. Move that SIRS compass up to the upper portion of the windshield, and it'll probably work fine. I've had two in that area, that both worked fine, one in a Cub, the other in a 170. Neither had stock compasses that worked anywhere near the panel.
    10,988
    Okay, I'm just going to throw this out there, folks. There are some interesting, and pretty nice looking panel designs in this thread.
    One thing I'll add as a cautionary note, though:
    If you mount ANYthing that protrudes from or above the instrument panel of a Cub, it could turn into a lethal instrument in an accident.
    A good friend of mine was killed in a Super Cub many years ago. The proximate cause of death was a Garmin 90 that was embedded in his face. He had other injuries that likely would have killed him as well, but...... That Garmin 90 had been mounted on the left windshield post. The stall/spin ended in impact which threw him violently forward and left. The pilot was wearing seat belt and shoulder harness, but there's no way to know how tight they were. And, I'm not suggesting that he'd have survived if not for that GPS, but.....
    A year ago, I was in a left turn lane in my Honda Ridgeline here in BZN, in line behind another car. I was hit from behind by a gent who drifted out of his lane, and impacted my car at about 50 mph.
    My airbags did not fire....not sure why, but the only injuries I had were very sore ribs and hips from belts, and a very fat lower lip and left shoulder where I impacted the steering wheel. This apparently on impact with the car ahead.
    My point is, your body becomes very fluid (your body is, in fact mostly fluids) and belts, even fairly tight ones, may not prevent your head and shoulders from coming quite a ways forward.
    For that reason, I won't fly an airplane with "stuff" protruding from the instrument panel. Of course, your face may still come far enough forward so as to impact the instrument panel, but......why make it easier to impact installed equipment?
    Please give this some thought when equipping your airplanes......GOOD shoulder harnesses and seat belts can save your life in an impact, but your body, in a severe impact, is going to move around a lot, belts or no.
    Thanks mam90, RVBottomly thanked for this post
    Likes Farmboy, behindpropellers liked this post
    Aug 2018
    31
    This is what I’m working on in mine at the moment.
    Likes motosix, TxAgfisher liked this post
  1. What is this on the dash of my J-4A
    By Biotex in forum Cafe Supercub
    Last Post: 08-30-2014, 08:57 PM
  2. Placement of fuel valve on dash?
    By kirkangus in forum Experimental Cubs
    Last Post: 08-16-2008, 02:06 AM
  3. 0320 no dash # or suffix
    By lunchmoney in forum Cafe Supercub
    Last Post: 04-22-2006, 03:54 PM
