Results 1 to 32 of 32
Thread: You donít see this plane everyday... Yamaha 1300 engine
    Aug 2020
    2
    Hello all,
    As my first post I thought I would share a bit of humor I saw on Craigís list today.
    https://cosprings.craigslist.org/avo...180493693.html
    My name is James Iím in the process of buying my first plane. Iím a corporate pilot and got introduced into the back country a few years ago and Iím finally pulling the trigger on my own plane. I have a lot to learn but canít wait to get in the air and start flying. Thanks!
    Jun 2006
    Portland, ND
    146
    Wow--a twist throttle and the engine in sideways? Interesting for sure!
    WWhunter's Avatar
    Aug 2003
    1,478
    You can even shift gears!
    Mar 2016
    1,515
    Frightening, absolutely frightening. And what size belt is that from the motorcycle sprocket to the propshaft.
    Regards, Charlie
    Aug 2015
    Indianapolis
    160
    Vroom!
    3,408
    Whole new twist on the term 'rice rocket'.
    Likes scotthayd liked this post
    Vermont
    332
    If yer gonna keep everything out to the output shaft, you have to keep the cush drive in the driven hub. Most motor cycles have some kind of rubber cushioning back there. But there's no need to do this now that Yamaha has done the conversion for us by putting them in snowmobiles.
    I didn't realize you could make a Zenith even uglier, I guess you just have to keep at it.
    What's a go-around?
    Cub junkie's Avatar
    My Moms basement
    2,117
    Good thing thats a STOL plane with good low speed and glide characteristics, somebody is going to need them.
    Nov 2009
    Edmonton, AB
    112
    I love the the way the carbs are welded right to the intake runners, which are welded to the cylinders.....wow
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    174
    Those air filters are from a Honda lawnmower. Very creative for someone who has built "race winning cars several times".
    I'm genuinely curious how well the gear shifting with a prop works. I would think it would be kind of like a constant speed until I remembered that props spin out and lose efficiency after a design RPM.
    irishfield's Avatar
    2,987
    LOTS of those belt driven "redrives" out there in the experimental world... still haven't road in one !
    RVBottomly's Avatar
    Sep 2017
    868
    Long ago I read about an early Italian design that used a three-speed transmission and a sports car shifter. It seemed very clever until they figured out that turning the prop at higher speeds defeated the purpose. Prop tips going supersonic, etc.
    Vermont
    332
    The belt might have a chance if a larger driven pulley is used and the gearbox put in a higher gear. That tiny driven pulley is going to give the prop way too much leverage against the belt during stop and start mayhem. Soft motor mounts hide a multitude of sins.
    What's a go-around?
    Mar 2016
    Reno, NV
    79
    I too would have a health problem after test flying that hardware store special, note soldered copper pipe with galvanized pipe cap at rear of engine.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    174
    Another gem is the distributor somehow welded onto the end of the valve cover probably driven by a shaft welded onto the end of the camshaft. I dare say the stock electronic ignition would have probably been far more reliable.
    Oct 2002
    90
    Spot on!
    I think the ad is absolutely correct, "It won't last long!"
    RVBottomly's Avatar
    Sep 2017
    868
    Quote Originally Posted by Roger Gross View Post
    I've been needing a laugh lately. Thanks!
    Cub junkie's Avatar
    My Moms basement
    2,117
    That does it. Every time some 20 something screams by me on a crotch rocket from here on I'm thinking airplane.
    Likes jrussl liked this post
    Mar 2016
    1,515
    That motor is not from a crotch rocket, the 1300 was a sport tourer. I question if that plane has ever flown not to mention being documented for flight testing. Taxi tested yah.
    My concern on the belt drive is that looks to have two L series belts, these are square tooth profile about the size we used to drive our old style dry sump oil pumps. They have no where near the torque capacity for driving a propeller. No one in their right mind would run those belts for a critical drive system nor even an oil pump drive in a car. A comment was there about him building race cars, you will notice that car is in singular, not multiple. I truly hope no one ever garners enough curiosity to try to fly that thing.
    I hate to seem harsh, Over the past 40+ years I have built many very high performance "toys" I have a very good record of making things that do not hurt anyone. The only way this thing will not hurt someone is if it never gets off the ground in the condition it is presented.
    Regards, Charlie
    Cub junkie's Avatar
    My Moms basement
    2,117
    Thanks for correcting me professor, its the details that make a difference.
    nd
    3,619
    people fly around in these things with some wear and tear, i dont see nuthin wrong with that plane.https://www.ebay.com/i/293619509206?...SABEgIfffD_BwE
    5,477
    I'd like to talk to the DAR who issued this plane an airworthiness certificate. IF one was issued.
    Nov 2003
    Thun Field, Washington
    791
    Yep. And the local EAA members who couldn't pour piss out of a boot if the instructions were on the heel, who say "yeah that's a great idea".
    S2D's Avatar
    Montana
    4,212
    If you stop and really think about it, this is annexcellent brain twister. The gear shift wouldn't be to make the prop go faster as you speed up, but to make the engine turn slower and prop turn the same as you speed up. But would it work that way?
    Now put a constant speed prop and gear shifter on it and really tie your brain in knots.
    3,408
    Two tachs?
    RVBottomly's Avatar
    Sep 2017
    868
    I was pondering that very thing, but I kept running into the question of whether a slower engine with a faster prop would be more efficient. I don't think so.
    One little empirical touchstone I have is my long-ago 72 Subaru. It had 5 speeds and would get 42 miles per gallon on level roads around 58 mph (this was during our national speed limit craze). Once I crossed Snoqualmie pass going east and had to stay in 3rd gear to get up the hill. I forgot to shift until Spokane so I ran that poor thing around 200 miles in 3rd gear. I still got 42 mpg.
    So my brain is twisted right from the start.
    10,520
    Quote Originally Posted by Carey Gray View Post
    Years ago a fellow showed up at Oshkosh with a licensed airplane which resembled a flying outhouse with hardware store bolts and house door hinges on the controls. As I recall he flew it from Arizona and then back again. It created a lot of discussion and raised eyebrows but did comply with the amateur built requirements.
    Cub junkie's Avatar
    My Moms basement
    2,117
    That was Merl Replogle. The name of the airplane was Gold Bug, painted with house paint and a brush.
    Penguin's Avatar
    Jul 2012
    KFLY
    92
    According to the owner the Zenith has an experimental airworthiness. It's last flight was last fall. And, it just sold.
    10,520
    Quote Originally Posted by Cub junkie View Post
    That's him, I couldn't remember his name.
    Aug 2020
    2
    Quote Originally Posted by Penguin View Post
    Some one actually bought it?
    nd
    3,619
    we had a impelment dealer that had a salesman that could sell dead horses and convince you they could still pull a plow, just gotta tell people what they want to hear, real simple, and he sold a lot of them.
    Thanks dustinjames thanked for this post
  1. White Tshirt 998 x 1300
    By RSharma in forum Travel Log
    Last Post: 10-06-2015, 12:59 PM
  2. 1989 Yamaha outboard
    By Tanner in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 07-01-2014, 06:47 PM
  3. Water in fuel EVERYDAY!
    By SteveE in forum Super Cub Sick Bay
    Last Post: 03-21-2008, 11:45 AM
