Results 1 to 7 of 7
Thread: Fuel pods suit Widebody PA18 Super Cub
    Dec 2018
    63
    Looking for information on availability or details of suitable fuel pods to suit a Javron Widebody PA18. If any one has suggestions it would be much appreciated.
    tedwaltman1's Avatar
    Jul 2011
    Denver, CO
    486
    Have you looked at http://EAeroFab.com? Though originally designed for a SQ-2, highly likely it will fit any wide body Super Cub with very minor modification (maybe no modification).
    Thanks Lowleveldevil thanked for this post
    11,352
    Wouldn’t any normal one fit? just use longer straps....
    Jul 2011
    Denver, CO
    486
    Yes, “any” normal (certified) pod would fit using longer straps. However, the edges of the “normal” pod would be pressed up against just fabric, rather than being pressed up against the longerons.
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,339
    I'm not so sure it would fit. The left side has a pretty big filler extension that comes right up next to the fuselage. You would have to offset the pod I think and that might not work very well. Furthermore (if on floats) there is no way the wires would fit. They are quite close tolerance with little wiggle room.
    You can see the filler line here. The wide body fuselage does taper pretty quick back to "normal" widths so I may be wrong. It would really depend on the taper and where the pod sits relative to that. Bottom line....I don't know....but this is something to consider.
    Very Blessed.
    Thanks FdxLou thanked for this post
    Likes mike mcs repair, tedwaltman1 liked this post
    Dec 2018
    63
    Yes you are correct Bill thanks for the input.
    Oct 2018
    1
    Hey I took that picture!!!
  1. Javron PA18 Widebody wing and fuse frames for building
    By Lowleveldevil in forum Experimental Cubs
    Last Post: 08-18-2020, 01:46 PM
  2. FS: 2008 Widebody Super Cub $180K
    By Akbushrat in forum Airplanes
    Last Post: 07-13-2020, 06:37 AM
  3. PA18 widebody with 180 hp on floats 2200 or 2400
    Last Post: 04-20-2020, 10:19 PM
  4. wing suit flying
    By DW in forum Experimental Cubs
    Last Post: 02-01-2009, 11:37 AM
