Results 1 to 11 of 11
Thread: 31" ABW std vs heavy tread on a Cub
    Dec 2015
    New Mexico
    52
    What's the consensus here? On a 180, heavy tread is a no brainer. On a lighter airplane like a Cub with an already forward CG does the extra $400 and 16lbs make sense to do?
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    181
    Curious about this as well.. I'm looking at 29's with heavy tread. 80% grass / other... 20% pavement...
    Jul 2020
    1
    I just put a set on a new to me PA-18 when I picked it up so I cant tell you what the difference is, but I do love them. They are $200 more per tire and weigh 4 pounds more per tire. I'm interested to hear what others think that have run both. At my home airport KIUA, I taxy on pavement but take off and land on grass. I opted for the heavy tread hoping they will last longer. I started out running them at 10.5psi and am now down to 8.5psi trying to find the sweet spot for everyday use. Any advice on the best tire pressure?
    Dec 2015
    New Mexico
    52
    Quote Originally Posted by daedgerton View Post
    The 29 was really designed for a heavier airplane - you won't get all the sidewall benefit out of a bushwheel on a light airplane like a Cub. I did fly a set of 29's on a Bearhawk Patrol but it was a mild environment.
    Thanks daedgerton thanked for this post
    Dec 2015
    New Mexico
    52
    Quote Originally Posted by Gamagoat View Post
    I misread the fine print, you are right at 4lbs/tire so it's only 8lbs, not 16.
    nd
    3,575
    Quote Originally Posted by TxAgfisher View Post
    thats ok, thats the way all my fishing stories are.
    Mar 2020
    11
    My impression is the AKB 31’s seem to wear or scrub quicker at lower tire pressure.
    Certainly need more effort needing to move at lower tire pressure.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    125
    Standard tread if you're roughly 30% or less on pavement, Heavy tread if you're up to 50% on pavement. Any more than that and you shouldn't be using Bushwheels.
    Likes Eddie Foy liked this post
    May 2015
    Eagle River, AK
    98
    I think ideal tire pressure depends on how much off-airport work you’re doing. I run mine at 6psi, but do quite a bit of off airport flying/landing. If I know that I’ll be landing on particularly rough sites, I might go lower than that.
    2,063
    No downside to the heavy tread Bush wheel unless you really think you are good enough to notice/need the performance difference of 1 1/2 gal of gas!!! If they extend tire life by 4 or more years!! You will save a lot of money. IF you really need to own a cub under 1,000 lbs get standard tread. I have and fly both pressure is mission dependent not tire.
    Denny
    Likes jrussl, G44 liked this post
    188
    I wonder: About 30 years ago there used to be an outfit in AK they resurfaced the ballonies with rubberbandages. My 26"ers started showing material. So I send them to that outfit. They very nicely glued rubberpieces arround the surface. I ran them until I bought my 31"ers. The abrasion in that time was less than 1/2". It was very good. I do not know why you cannot find such thing annymore
    The wandering raven
  1. Replies: 14
    Last Post: 05-25-2020, 02:53 PM
  2. FS: New 29" Alaskan Bushwheel with extra tread.
    By ChickenCub in forum Parts and Pieces
    Last Post: 01-06-2020, 08:01 PM
  3. "Heavy Duty" MLG Arm?
    By 180_jeff in forum Cessna: C180/C182/C185
    Last Post: 04-16-2018, 10:44 AM
  4. Replies: 1
    Last Post: 10-13-2014, 06:06 PM
