Results 1 to 20 of 20
Thread: Lift strut dent
    jimboflying's Avatar
    May 2005
    544
    Lift strut dent
    I had a jack slip and wound up with a dent in the rear lift strut. Is it possible to remove the dent and if so what is the best technique or does a dent require a new strut? The picture is a little dark but the dent is below the 3 white dots.
    11,297
    Before they were sealed, you would put air fitting in fork hole, air it up and soften dent with a torch, common... Be creative. Not going to finish the steps, but you get the idea.
    10,383
    mike, does just heating the strut with a torch harm the sealed struts? A welding rod could be welded to the center of the dent, then heat around the dent's edges while pulling on the welding rod. After the dent is out, cut off the rod and smooth the spot.
    19,821
    They are mild steel.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    125
    Definitely not a good idea to heat a sealed strut. Being sealed there is a fixed amount of air in there and if you heat it that air will expand and possibly bulge the strut tube.
    Plus I don't think you can pop a dent in tubing out like you would pop a dent out of a car door.
    I don't have the data in front of me but allowable tolerance for strut dent depth is somewhere in the range of 1/2 the wall thickness of the strut tube which is about .035 for front struts and .049 for rear struts. Don't quote me on it though, that's from memory.
    Best bet is to replace the strut if it's out of tolerance. After all it's the thing holding your wings on....
    Likes mam90, G44, moneyburner liked this post
    7,175
    Agree - although I flew for years with a slightly dented strut, probably not a great idea if you fly in heavy turbulence. A dent, or even a repaired dent, impairs the compressive strength. They are designed for limited compression anyway, and are really strong in tension.
    The only time you see real compression (other than flying inverted) is in heavy turbulence, or landing, or tied down in heavy wind.
    10,383
    That makes it sound like a viable solution for a small dent. It's unlikely that the expansion would cause a bulge unless you go overboard with the heat.
    Likes mike mcs repair, Southern Aero liked this post
    11,297
    you guys realize the strut started out as a ROUND TUBE, and was rolled through a series of dies to make it into the streamlined shape...... fixing a dent is NOTHING compared to how they are made.....
    Dec 2002
    Fairbanks, AK
    81
    I Once saw a cub with a belly tank which caught fire and burned. The heat made the lift struts round.
    Owned same cub for 36 years!!!
    11,297
    oil or air expands more????
    heat strut away from dent to pressurize, then heat dent perimeter to soften and remove dent...... carefully ....
    might want a hammer handy incase you over do it....
    Mar 2007
    Northwestern Minnesota
    118
    In the auto body world we use PDR (Paintless Dent Repair) techs to push hail and small dents out of damaged vehicles. In areas they cannot get behind such as the outer roof rails on your pickup or SUV they use a glue gun procedure. I have been amazed at how perfect the repairs have turned out. Each dent is unique and not all lend themselves to this procedure. Only an experienced tech would be able to determine if the repair has a chance to succeed. They typically approach the procedure from the standpoint they will make the dent disappear completely. They can sometimes be convinced to simply make it better which in my experience is amazingly good. And when they are done the paint is unscathed. No don’t go out and buy a glue gun. Ask around car dealers or autobody shops for a name of an experienced PDR tech. Hope this helps Good Luck. Rod
    Jan 2005
    Fowler, Ks
    569
    Is removing the dent for structural integrity or cosmetic
    If cosmetic...bondo
    I make a living sitting on tractors and horses
    behindpropellers's Avatar
    Feb 2003
    NE Ohio
    6,805
    I have read on this website about powdercoating and the oven caused the strut to look like a banana.
    11,297
    Lift strut dent
    No it makes them kinda round.
    Boodie (original airframes, they bought out) made bannnana shaped struts as they were originally getting rollers adjusted
    Jan 2017
    Utah/Alaska
    152
    I thought some of the suppliers were using 4130 for the streamlined tubing and once it was roll formed it had to be NDI'd for micro cracks, am I way wrong here?
    11,297
    Quote Originally Posted by astjp2 View Post
    pretty sure boodie(Airframes) was 4130, at least heavy duty rear one....
    https://www.airframesalaska.com/PA-1...af89498-02.htm
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    125
    Can confirm: Front struts are 1010 mild steel and rear struts (heavy duty) are 4130
    10,993
    It seems to me the question is: Is strength compromised by this dent? Since struts are stressed in extension, it seems to me that a small dent probably wouldn't effect strength.
    IF (note the big IF) that's the case, a little body putty and a rattle can spray job would seem to be the safest approach, rather than trying to re-form the strut.
    Maybe.
    Sep 2004
    Illinois & Wisconsin
    725
    If the lives and safety of you and your passengers are in the slightest doubt, why would anyone ever consider not replacing the strut? Isn’t the constant worry about possible failure and the prospect of lifelong guilt and economic ruin enough motivation to spend the few dollars necessary to properly fix the issue?
    Taking little shortcuts in safety now leads to a mindset of taking greater and greater risks until disaster is inevitable. Flying is dangerous enough.
    Replace the strut.
    Likes 1934A liked this post
    5,330
    I flight wouldn't bother me but in parking? I've watched Cub wings fold under from aft strut failure. I wouldn't want a compromised strut on my airplane.
  1. dent in wing strut
    By cub12 in forum Sportsman's Den
    Last Post: 03-18-2009, 08:35 PM
  2. Lift strut and Jury strut bracing
    By pa19guy in forum Modifications
    Last Post: 11-17-2003, 12:22 AM
