Results 1 to 11 of 11
Thread: constant speed prop on Javron
    Jan 2010
    Las Vegas-Heber Ut
    4
    Looking at a Javron kit that's at the prop ordering stage. Going constant speed and very familar w/ mt and Hartzell trailblazer, what are you using that your ecstatic about?
    10,380
    What is the layout of the tubing in the front of the fuselage right behind the firewall? Does it form a V or an X. Mine in a TCOW fuselage made by Javron, it is in the form of an X. The X blocks the installation of a governor which is needed for the constant speed prop.
    If your's is an X and the engine is not larger than an 0-320, this Airmaster has potential: https://www.supercub.org/forum/showt...airmaster+prop
    11,293
    Does the have the option of front mounted governor? He didn’t specify engine model?
    3,269
    Front mounted governor is actually a more simple install. Less parts to hang on the aircraft.
    Jan 2010
    Las Vegas-Heber Ut
    4
    [QUOTE=mike mcs repair;780213]Does the have the option of front mounted governor? He didn’t specify engine model?
    Sent from my iPhone using SuperCub.Org[/QUOTE
    Sorry for the delay, work and all...
    I'm a 20 year Husky owner looking at trying something else. Looking at a project a friend is doing that's in need of a prop. Mission requires the cruise speed of a constant speed.
    Flown behind the MT's on mine and the Hartzell Trailblazer, like them both but hoping to get some feedback on any exp props that you might think deserve a look.
    O-360 220hp.
    10,223
    Why not a ground adjustable and save a lot of weight and money.
    19,821
    Randy Goza raved about his Whirl Wind constant speed on his SQ2.
    Thanks hardrock thanked for this post
    5,322
    Whirl Wind 200A works for me but it's in their STOL class. If you want speed there may be better options. I cruise at 100mph on 35s so not slow in the Cub world.
    Jan 2010
    Las Vegas-Heber Ut
    4
    Can I ask what your powering it with? Did you consider their 284? My experience on the Husky is the Trailblazer and Ultra are the best short field props and also have the best cruise speeds.
    5,322
    Thunderbolt 10-1 IO-390.
    Your friend would likely appreciate the ram cooling this prop has. I'm pleased.
    Jan 2010
    Las Vegas-Heber Ut
    4
    It's not him I'm worried about.
    Thanks for the feedback.
  1. Whirlwind 284 Constant Speed on Javron PA 18 measurements
    By Lowleveldevil in forum Experimental Cubs
    Last Post: 11-29-2019, 07:15 PM
  2. Constant speed prop STC's
    By SC88C in forum Member to Member
    Last Post: 01-12-2012, 04:50 PM
  3. Constant speed prop on a PA-12
    By Speedo in forum Modifications
    Last Post: 03-13-2005, 09:42 AM
