Okay found pics from a little while back. Don’t mind all the crap hanging off the window and the old shoulder harness.
Red is aileron, blue is flaps.
Aileron tube is in front, and has two quick disconnect pins to the push-pull tubes in the wings. Those obviously go to a bellcrank to the control surfaces.
Cables run from the attach point to the side, aft on an angle to a rear mounted pulley about mid height fuselage, to then angle frontward down to a bottom mounted pulley, so it can run forward up to one last pulley under the pilots floor outboard before attaching to the stick.
The flaps are electric. Plenty of naysayers but they are simple and work great. Actuator is internally mounted in the right wing, with a carry-through tube running through the cabin just aft of the aileron tube to attach to the left side. Again with a removable center section for wing detachment.
Flap control is a smart 3 button unit that allows 3 preset positions (up, mid, down) of your choice, or by using two buttons at a time you can infinitely move it to any position in the range of travel.
Transmitted from my FlightPhone on fingers...
