Results 1 to 13 of 13
Thread: Edo-aire Gascolator 33-199-105-3 parts list or diagram
    chadden's Avatar
    Jul 2020
    Ireland
    10
    I am servicing an Edo-Aire gascolator/fuel strainer on a PA18
    There is a top and bottom rubber washer seal for the outer can. The internal strainer mesh should be held in place with locking wire (but was not). However even when properly wired there is still clearance between the strainer cup and the top of the unit which suggests that there should be an internal washer seal on this too.
    Edo-Aire is no more and I cannot find much information other than e-bay images online. Has anyone encountered one of these units. Directions to where I might source a washer kit would be most useful. (I could try making a set of course)
    RaisedByWolves's Avatar
    Feb 2005
    4,407
    SA-3
    https://www.aircraftspruce.com/pages...gascolator.php
    chadden's Avatar
    Jul 2020
    Ireland
    10
    Thanks for the Spruce link but I don’t want to buy an alternative for $300+ when I just need a seal kit. This unit dates from the 60’s and the manufacturer no longer exists. I may end up hand crafting new seals...
    3,847
    You might be looking at $100 or more for gaskets. Why spend that much on gaskets when $300 will give you a safer higher quality item? It's your wallet.
    If you look at this parts diagram, it looks like Garwin was the original manufacturer. This unit looks identical except for the glass bowl.
    20,760
    What approval process was used to install the Edo-Air gascolator on a PA18? They were used on Cessnas and parts were called out in the Cessna parts manuals. The Steve's gascolator is a safer more maintenance friendly alternative and STC'd for almost everything.
    7,405
    I always made my own gaskets out of high quality cork, with a coating of Hylomar.
    A gascolator question came up today - I have always assumed that both inlet and outlet were 1/4" pipe. One of the locals is insisting that they are straight threads with a 37 degree seat. Am I mistaken?
    White City, Oregon
    951
    Quote Originally Posted by chadden View Post
    That gascolator is not factory.. I would be looking at the logs to see if there is a 337 approving that gascolator for installation.. otherwise you have an illegal part installed and therefore un-airworthy...
    I am the holder of the Steve’s Aircraft STC gascolator.. You will find that replace if that part with original from Piper would cost way more than my $285.00 charge...
    Brian
    White City, Oregon
    951
    Factory is 1/4 NPT pipe thread...
    Vilcanair (Partenavia) is MS straight fittings with O-Ring seals..
    Brian
    Thanks bob turner thanked for this post
    Jan 2017
    Utah/Alaska
    285
    Quote Originally Posted by Steve's Aircraft (Brian) View Post
    Brian
    Some might call that a minor alteration...
    mike mcs repair's Avatar
    11,773
    He probably has larger tanks and part of that STC requires a larger gascolator. It would be covered under that
    There was life before steve’s gascolator......
    11,121
    Guys, chadden the OP is from Ireland. Do we know what the approval requirements are in Ireland? All he wants is gasket recommendations.
    Likes mam90, mike mcs repair liked this post
    11,773
    Might try https://www.mcfarlaneaviation.com
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,428
    trimcraftaviation.com should have the gaskets. I think they are also a McFarlane dealer, also a good supplier. Shouldn't cost much.
  1. Parts List in a Spreadsheet
    By Aerodon in forum Member Projects in Progress
    Last Post: 10-17-2016, 07:28 AM
  2. Rib Lacing Diagram
    By Josh in forum Tips and Tricks
    Last Post: 07-06-2008, 01:39 PM
  3. Met-Co-Aire's Hoerner Wing Tips
    By Bill G. in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 11-07-2006, 02:48 PM
Tags for this Thread
