Results 1 to 38 of 38
Thread: Help! How Do I Get this 35" BW Off the Wheel?
    19,818
    Have a Cub on 35s that has a small place showing cords and want to flip the tire around so it can make a trip to it's new home where it will go on 31s. I used two pry bars, silicone spray, two of us jumping up and down on it. Don't want to tear up the tire or the wheel. Wish i had a tire machine for once in my life.
    2,063
    Wait until you have to change a Beaver bushwheel. Have you tried putting 1 psi in the tire?
    Jul 2010
    Elizabeth, WV
    583
    Likes mike mcs repair, BC12D-4-85 liked this post
    2,342
    Here's a goofy one...lay a bag of ice on the rim. Might make it move vs rubber? Too much coffee.
    Sep 2019
    6
    Steve
    With the tire deflated, lock the brake with the wheel and tire mounted, and try to spin the tire on the wheel by hand. Worked on 31s to break the bead...Might work on 35s.
    Mike
    10,218
    1st, let the air out.......
    Try shop vac hose pressed tight over valve stem hole?
    Dec 2016
    Canyon, tx
    566
    Maybe since it’s a carbon cub they can afford to just buy a new wheel and tire setup? I’ll dispose of the old
    Thanks flynlow, barrow pilot thanked for this post
    behindpropellers's Avatar
    NE Ohio
    6,802
    Add some kroil to the bead of the tire and work it in.
    T
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,630
    Take it to a tire shop!
    2,063
    On a bushwheel the center gets bigger when you add a bit of air, making a vacuum makes it smaller. It don't seem right but that is how it works.
    2,342
    Interesting. If the tire moves with a +- air change then do that a few times? I like the Oky tire changer in #3.
    May 2006
    k2w6
    29
    Try a tire bead breaker ( slide hammer type) with a small quantity of gas as lube. The gas soften's the rubber and helps it release. Anyone that changes truck tires or equipment tires should have one . I'm not a fan of the mall , they damage your rims. Hope this helps . Paul
    nd
    3,572
    just make sure you dont tell anyone what the tires worth before they start.
    Likes mike mcs repair, Steve Pierce liked this post
    Grant's Avatar
    At Work.....
    1,785
    Steve,
    I'm sure you have it off by now but if not, try shooting air from an air nozzle between the rim and the tire.
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,145
    I use a piece of 4x4 and the largest rubber mallet i can find to knock out the second wheel half. If both halves are still in the tire, use a wooden dowl through the bearing hole against the opposite wheel half, and a mallet of course.
    "Always looking up"
    3,611
    Redneck method - - lay it down flat and drive the front wheel of your pickup over the tire, tangent to the rim. Old timer taught me that about 5+ decades ago.
    Likes Willie, BC12D-4-85 liked this post
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,145
    And I thought my my method was shadetree.
    "Always looking up"
    3,611
    Quote Originally Posted by skukum12 View Post
    Haha! Yep, but I've done it - it works. Might have to lay a board over the tire as a ramp. Hey, if Steve P. is stumped, it's a truly tough situation!
    Mar 2016
    1,508
    If I am correct that tire has an integral tube? I expect said tube has bonded itself to the rim.
    Do you have a source of vacuum that you can attach to the stem, I would see if that might aid in getting the tube to release from the rim halves.
    Otherwise, how much air pressure can these tires withstand unmounted? A full pound or maybe two?
    With the rim unbolted this might or might not roll the rim halves out. At least get one side to unbond from the tire.
    Regards, Charlie
    10,369
    Only a small place showing cords? Fly it to it's new home where the new owner can cut off the tire since it is to be replaced anyway.
    Mar 2016
    1,508
    Or paint the area with the rubber coating others are using as a simplified retread.
    Regards, Charlie
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,630
    You can fly airliners with cord showing!
    10,218
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,619
    Herculiner bed liner works great. 2 or more thin coats rather then one heavy coat works best.
    Mar 2016
    1,508
    That's what it's called, Should have had a coffee or two before posting
    Regards, Charlie
    10,369
    Several layers.
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    174
    This worked for smaller tires: 5/8” plywood 16” by 24” with the center cut out just bigger than the size of the hub. May need bigger piece for the bigger tire, and a heavy guy or two.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,630
    Up to 4 at AA. How many cord layers are there on a Bushwheel?
    Several layers.
    Apr 2015
    Platinum
    267
    Bought one of these recently....Wonder if this would work?
    https://www.aircraftspruce.com/catal...clickkey=52413
    Sent from my iPad using Tapatalk Pro
    RaisedByWolves's Avatar
    Feb 2005
    4,080
    The 35’s really get stuck huh.
    I got a bead breaker from harbor freight. It goes inside the wheel hole where the axle goes. I think it’s for a lawnmower or small tractor. I can’t find it on there site though.
    Middleville, NY
    208
    Any tire shop should have a gallon can of Skid. ( Bead release fluid ) Pour it around the where the tire meets the rim and wait a minute or so. Should almost fall off.
    Mar 2016
    1,508
    Correct me if I am wrong but it is the built in tube that is stuck, not the tire bead.
    On a tire this size it would simply be easy enough to use a commercial tire mache's bead breaker. My older Hunter tire equipment can reach to the small rim sizes and in the act of pressing the bead it will make the tube portion roll inwards. On the release of pressure the tire will go right back but it may not be "bonded" not to mention one can spray WD40 or a juice of your choice so the tube may no longer stick.
    Brand new style tire machines may not be flexible enough to work with these "oddball" tire rim combinations.
    Regards, Charlie
    Meanwhile,...
    5,265
    If all else fails there’s always the black Sharpie pen method.
    Likes Steve Pierce, DENNY liked this post
    19,818
    I sent it on it's way yesterday, like Pete said, they can deal with it when they install the 6" wheels and 31s. If I damage the tire there is a chain of events that will result that would not be good. It had one small spot that just started to show. I did figure out it is really the rubber that makes up the area where you would install a tube on a conventional tire. I am going to try the bead release fluid acehercs suggested next time. Heard of some interesting ways of doing it using 4x4s to block up the tire and a shaft and skid steer bucket to push the wheel half out. Now I have an idea on a piece of all thread with some arms to do the opposite of what we do to get those wheel halves together when installing new Bushwheels.
    Likes skywagon8a, DENNY liked this post
    19,818
    Oh yea, I had to edit the title, I guess I held the shift key down when I typed the 35 and it made it look like I was using an expletive.
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,619
    With my 29" Airstreaks, and my wheel skis, I deal with this every spring and fall. Before I discovered the "round rod thru the bearing hole, and tap the rim half and it will fall right out" method, I used to haul my wheels to my crane yard. With some blocks on the tires on either side of the wheel, I would put it under a outrigger and slowly lower it, and it'd pop right out, kind of like they do it at a tire shop, but I didn't have to buy another piece of equipment.
    40m's Avatar
    Dec 2013
    Shoreham, VT
    461
    [QUOTE=RaisedByWolves;779381]The 35’s really get stuck huh.
    Me, I just take them over to Tom. I like hearing his screams coming over the top of the Green's.
    From Genesis: "And God promised men that good and obedient wives would be
    found in all corners of the earth."
    Then he made the earth round... and He laughed and laughed and laughed!
    nd
    3,572
    piece of 6 inch long pipe or a rolled piece of 1/4 inch thick steel with seam welded with a 7 3/4 inch id. then lay the tire down below something solid. then lay a piece of 2x4 across the pipe thats centered over the wheel 1/2 and then use a handy man jack to push down from the solid support above. just an idea. only cost is a 6 inch long piece of tube.
  1. PA-12 wheel hub
    By Martin N4057M in forum Piper: PA-12 Super Cruiser
    Last Post: 04-01-2019, 02:31 PM
  2. left wheel, right wheel, left wheel, right wheel . . .
    By hikouka in forum Cafe Supercub
    Last Post: 09-09-2006, 08:42 AM
