Results 1 to 7 of 7
Thread: Poly brush on leading edge problems.
    supercub's Avatar
    Apr 2002
    848
    I brushed on 2 coast of poly brush to the leading edge. After cover one side, the fabric seam along the leading edge is someone what rough due to the poly brush being softened by the poly tak cement. I'm mainly talking about the area above the seam where the next fabric will cover. Any suggestions on how to smooth the poly brush out? I've tried brushing a little reducer (MEK) is not available here) and that had little effect. Looking for suggests. Was thinking of brushing some poly brush and seeing if the leveled the older poly brush. I've also tried an iron with minimal results Any suggestions? Thanks
    Thanks flynlow thanked for this post
    11,091
    Parchment paper and an iron?
    supercub's Avatar
    Apr 2002
    848
    Ok, thanks Mike
    11,091
    Quote Originally Posted by supercub View Post
    Ok, thanks Mike
    not my idea... I learned it from someone else on here
    supercub's Avatar
    Apr 2002
    848
    As soon as I read your post I remembered using parchment paper before for the same thing. I still have a roll. My memory just needed jarring. You know what they say, memory is the 348th thing to go LOL. Thanks again.
    Oct 2010
    Lakeland, Fl
    128
    I use a piece of thin sheet teflon, smooth finish and wipes clean with mek. 12" square lasts years. Found it in the aircraft parts dept of McMaster.
    Likes mike mcs repair, CharlieN liked this post
    Hardtailjohn's Avatar
    Marion, MT
    769
    Had a student give me one of these about 3 years ago... they're awesome!
    https://www.amazon.com/Teflon-Sheet-...6260464&sr=8-2
    JH
  1. Stitts Poly Spray and Brush for sale
    By pittsdriver in forum Parts and Pieces
    Last Post: 12-02-2019, 12:08 AM
  2. Leading Edge Cuff
    By ksecub in forum Modifications
    Last Post: 07-11-2019, 09:38 PM
  3. Leading edge
    By STEEL in forum Experimental Cubs
    Last Post: 03-15-2017, 06:49 AM
  4. Leading edge protection
    By Jerry Gaston in forum Cafe Supercub
    Last Post: 04-29-2004, 07:05 PM
