Results 1 to 39 of 39
Thread: Mag issues
    Feb 2006
    Cortez Colorado
    105
    Mag issues
    It appears that my left mag is getting tired. My 0-320 engine was getting hard to start so had the plugs changed last annual which helped some. However the rpm drop increased for the left mag with the new plugs, a little over 100 rpms. It is still hard starting sometimes.
    My question is should I have the mag rebuilt or go with a certified e-mag? Anyone have experience with the SurFly ?
    Thanks suntiet thanked for this post
    Nov 2002
    Fargo
    742
    What mags do you have now?
    3,623
    When is the last time these mags had a 500 hr inspection?
    Likes mike mcs repair, G44, astjp2 liked this post
    7,327
    One Super Cub around here was getting those "lemme see a photo" annuals. I had to ferry it from a local airport one day, and noticed it was climbing poorly.
    Mags had worn in the cam and point area, causing the timing to be seriously retarded. Cams were worn to the point where it was difficult to get them set correctly.
    Overhauled both. Fixed.
    2,231
    What mags do you have? Slicks are natorious for having intermittent starting problems. I dumped mine for a set of Bendix and have been very happy. If you have Bendix mags send them to https://www.aircraftmagnetoservice.n...hoC5gMQAvD_BwE for rebuild/overhaul, they are great people to work with.
    Likes G44, suntiet liked this post
    10,841
    Mags have ignition points like old cars. Over time the points and the follower wear a little. This changes the internal timing of the mag. If the points are in otherwise good condition just retime them to E-gap (the point of the highest magnetic flux prior to TDC) of the rotating magnet. You feel E-gap with your hands. All it takes is a 1/2" wrench, a screw driver, a piece of paper and a few minutes of time.
    Likes mike mcs repair, DENNY liked this post
    Jan 2017
    Utah/Alaska
    208
    The older ones were horrible, the newest ones are better... I just have my customers send them to Aircraft Magneto Service, they are tested after overhaul and have a warranty. I am not a fan of the Kelly Aerospace products either. Tim
    Valdez, Alaska
    656
    Just had my mags redone for the second time in the last 100hrs. Had a shop in Anchorage do mine...was a complete rebuild in theory...points were shot and coil was not new along with other internal parts....cost a bit over 1500$. This place did not stand behind their product/work...they did offer to rebuild them again for $500 each... I went with a different business...
    Kodiakmack's Avatar
    Sep 2020
    winters in Utah, Summers in Idaho
    88
    Minimum 500 hour inspection by an informed A&P. Otherwise overhaul or replace. Not to be ignored.
    HAVE FUN. DON'T DIE.
    2,231
    SOOOOOOOO, winter has arrived because now we are posting about is flying a sport stuff. Just for giggles what is involve in a 500 hour inspection. I know what I want but what is involved in an AD for the Bendix mags? If you do have a mag issue go to post #5!!
    10,841
    Quote Originally Posted by J5Ron View Post
    Quote Originally Posted by Kodiakmack View Post
    I'm not picking on you two. Every time the topic of defective mags comes up, it appears that the universal solution is to "send them out". Mags are one of the simplest accessories to work on and to keep operating properly. Seldom does one need enough work which takes a long period of time to fix. The most complex tool needed is a gear puller. Short of needing a major part (like a coil), a mag can be returned to peak operating condition in not much more time than removing and reinstalling the cowling.
    All Powerplant mechanics are trained in magnetos. Why do what appears to be a large number of them insist on sending them to someone else to "tune up"? Are none of them old enough to remember how to "tune up" a car?
    Sorry for the rant. Mags are Soooo simple to tune up.
    Sep 2006
    Maynard,MA
    1,237
    I agree Pete
    Likes supercrow liked this post
    20,366
    Quote Originally Posted by astjp2 View Post
    Define older.
    Valdez, Alaska
    656
    I don’t disagree at all, however when some thing does need rebuilt and you pay for work, IE, new everything inside, you expect that...once my IA and I pulled mine apart, after having mag issues it was obvious that there were old parts still in this rebuilt mag...that is why I returned it...was just disappointed in the workmanship of this business, and their unwillingness to stand behind their work. My “rebuilt” mag needed new points, bearing and coil ....
    Likes Bill.Brine liked this post
    10,841
    Understood, With the mags coming back with old parts and a dissatisfaction in the call to the shop, the next call would be to Mr.FAA. That type of "workmanship" is uncalled for. I would have just ordered the replacement parts and done the job myself. Perhaps one hour's labor.
    Likes J5Ron, Brandsman liked this post
    20,366
    The 500 hr AD on Bendix is only applicable on the 540s now. Here is a copy of the 500 hr inspection instructions for the Slicks. Might not be the latest revision. https://drive.google.com/file/d/1pCA...ew?usp=sharing
    Likes DENNY, mit greb, cubpilot2 liked this post
    Kodiakmack's Avatar
    Sep 2020
    88
    Didn’t say just send it out. 500 hr inspection can be done easily by your a&p. If he sees garbage that needs a full overhaul you’re gonna send em out. Yeah, they’re simple to tinker on (a&p not owner), but a full blown overhaul why not use a shop who specializes?
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,044
    I just did both mags on a IO-540 in a Maule. The aircraft had around 500 hours TT and is nearly 20 years old. This plane is on floats and has been most of its life. Slick’s on it. So as in most cases there is more to consider. I talked it over with the owner and here is what we came up with. The airplane sits most of the winter, the mags are old , they spent most of there lives around water, they will spend the rest of its life around water, it gets flown to remote area’s when braking down is very bad.
    So we decided to replace both with new, under $3000.00 , good to go for many years.
    Just a quick note on the FlyRite mag’s we talked that over and the owner didn’t want to go electric because of the environment we operate in. Also keep in mine they recommend replacing the wiring harness with the mag.
    Hard to go wrong with new.
    Jan 2017
    Utah/Alaska
    208
    I have all of the best manuals in the world, I don’t have a machine to run and test them so therefore they get mailed to a certified shop who tests after repair, without the test, imho, the 500 hour is not complete. Tim
    Thanks Bowie thanked for this post
    Likes mike mcs repair, Bowie liked this post
    20,366
    I don't see anywhere in the 500 hr inspection where is calls for a bench check. Adjusting e-gap, inspecting and wiping out carbon is pretty straight forward.
    10,841
    That's the difference between a mechanic and a remove & replace technician.
    Likes wireweinie, cubpilot2, Stankasica liked this post
    Jan 2017
    Utah/Alaska
    208
    One paragraph in the beginning of the Slick manual that says if you open the mag you need to test it, my pmi called me out on it so to eliminate any issues I farm it out. On my own airplane is one thing, paying customer it is just easier to let someone else have the liability. Same thing with carbs. It’s not that I can’t, it’s that I won’t. I got away with a lot more **** in Alaska, not the same rules in some FSDO districts so not much rogue in the lower 48 without the possibility of a whiner customer who runs to the feds over their bill because they get a real annual and not a walk by. You can take on anything you want, I just don’t want my pmi asking me, how did you test it, per the manual?” Besides looking at revision numbers and dates for my data. Tim
    3,623
    Legit question.
    Do they specify how the testing is to be accomplished or any special equipment required for testing?
    Jan 2017
    Utah/Alaska
    208
    Legit question.
    First page last paragraph.
    After any inspection or maintenance is done on Slick Magnetos, the testing procedures in Section Eight should be performed completely.
    part of that should, shall, will, may argument. Not one to argue with my pmi over
    3,623
    Okay, so what are the testing requirements in section eight? Can you put up a pic of the page or a link to the manual?
    Jan 2017
    Utah/Alaska
    208
    8.0 POST-ASSEMBLY TESTING 8.5
    LONG TERM TEST (OPTIONAL)
    Complete Magneto Reassembly, Section 7.0. Ensure that the T-118 Timing Pin has been removed.
    A.
    B.
    4300 Series Magnetos
    1. Test run the magneto for a minimum of three hours. Operate the magneto at 1725 RPM for the first two hours and 3400 RPM for the remaining hour.
    2. Regular and consistent firing of the spark gaps is required during the entire test.
    6300 Series magnetos
    1. Test run the magneto for a minimum of three hours. Operate the magneto at 3000 RPM for the first two hours and 4500 RPM for the remaining hour.
    2. Regular and consistent tiring of the spark gaps is required during the entire test.
    TEMPERATURE TEST
    8.1
    A.
    B.
    8.2
    A.
    B.
    8.3
    A.
    B.
    8.4
    A.
    PRE-TEST PREPARATION
    Mount the magneto on a suitable test stand in the same position as installed on the engine.
    Install a Slick High-Temperature Ignition Harness on the magneto and connect each output led to a 5mm spark gap.
    IMPULSE COUPLING
    Rotate the test stand drive pulley in the same direction of rotation as stated on the magneto data plate.
    The impulse coupling should engage the stop pin in the magneto frame below approximately 200 RPM. If the impulse coupling pawls slip past the stop pin or engage intermittently, the impulse coupling is not operating properly,
    COMING-IN SPEED
    Determine the lowest speed at which the magneto can be turned and still spark all 5mm gaps without missing.
    The test gap must fire consistently at 200 RPM maximum on non-impulse magnetos and 350 RPM maximum on impulse coupled magnetos.
    HIGH-SPEED TEST
    1. Operate the magneto at 1000, 2000 and 3000 RPM for five minute at each speed setting.
    2. Observe sparking regularity at the spark gaps. Magneto must produce a consistent spark at all speed settings.
    8.6
    CAUTION: DO NOT OPERATE THE MAGNETO UNLESS THE IGNITION HARNESS IS INSTALLED AND THE OUTPUT LEADS ARE CONNECTED TO THE 5mm GAP.
    Measure the temperature on the outside surface of the magneto frame during the long-term test at the highest RPM setting. The magneto will generate heat during normal operation. Maximum temperature on the outside surface of the magneto frame is 175°F when tested at room temperature.
    8.7 PRESSURE TESTING - PRESSURIZED MAGNETOS ONLY
    After magneto assembly, install a pressurize
    Likes Bowie liked this post
    3,623
    Notice the word (optional) in line two. Obviously not even a moron would send a repaired/reassembled mag go without a test run and test flight. But the whole page you posted is marked optional by the magneto manufacturer.
    20,366
    Non regulatory logbook entry. A decision each mechanic makes on his own.
    Jan 2017
    Utah/Alaska
    208
    The optional was for a long test, it really did not post well in the forum. Section 8.5
    3,623
    Do you have a manual number or title where I could pull this up?
    11,733
    Mag issues
    I don’t mess with them either or carbs as I have many options of shops that specialize in just that within a 20 minute drive. Mags and carbs. Those thing will bring you out of the sky(and I’m the guy that doesn’t care if your wing is ripped off, I’ll make it fly home safely) not worth it for me to learn and tool up for it to do one every few years... gave away all my test equipment I had. drop it off get a yellow tagged one back. As far as the anchorage shop, not sure if same shop. But Orville said the best thing for his business was pilots doing a bunch of inflight mag checks.... he had the accessory shop on Merril field decades ago.
    May 2017
    799
    Actually it says “should”, not “must”. That should for testing holds as much weight as the should for using only parts from Unison and should not use PMA parts.
    May 2017
    799
    Here is the subject manual
    http://eaa105.org/Useful_Info/Docume...haulManual.pdf
    Jan 2017
    Utah/Alaska
    208
    I had to pm you the link, tim
    3,623
    I do the same. For me, it's been a convenience issue not a regulatory one. I hand off a mag to the shop and work on the rest of the project until I need to reinstall it. Then it's waiting for me to pick up. The mag shop is faster than I am and lets me work on other stuff while it's being repaired. But I know that I have the ticket that allows me to work on them if I want to.
    20,366
    Everybody is different. To me a 500 hr inspection is pretty simple as is checking internal parts with an ohm meter. I do maintenance so that is my job. I have manuals, tools, parts and experience. I hate waiting on vendors if I don't have to.
    Likes hotrod180, irishfield liked this post
    11,733
    ..I do maintenance so that is my job. .. I hate waiting on vendors if I don't have to.
    I manly do rebuilds/builds.... so there's not a time issue for me...
    windy's Avatar
    Dec 2005
    Utah
    725
    Mag issues
    I agree. But when you get a mechanic who’s just a parts changer, it’s better to send the magnetos somewhere where they maintain them for a living. When your mechanic recommends that you send them out for inspection, do it, because they’re telling you something.
    Jan 2017
    Utah/Alaska
    208
    Quote Originally Posted by windy View Post
    I will always recommend the 500 hour and I know a couple owners who will run a mag to failure. We had a mag on a lycoming fail earlier this week, 300 rpm drop and it was retimed 2 weeks ago for the same problem. The junior mechanic grabbed a mag off the shelf, I opened up the as removed one and looked at it. I found the brush was good, but the points were worn and the cam was shot. It will get parts and put on the shelf. I am not personally liable if I follow company policy so I do what the company manager wants and it will go on the shelf to be used another time. We have 50 airplanes so that is the most time efficient way to make them profitable.
    Has anyone priced a mag tester? They are $15k for a new one and not many used ones around. Tim
    Likes mike mcs repair, BC12D-4-85 liked this post
  1. ADS-B Issues
    By mvivion in forum All Things Electrical
    Last Post: 02-04-2020, 06:56 PM
  2. Replies: 3
    Last Post: 02-01-2018, 11:40 AM
  3. GPS issues?
    By mike mcs repair in forum Cafe Supercub
    Last Post: 05-02-2010, 07:28 AM
  4. 0-320 Issues...
    By SimonK in forum Super Cub Sick Bay
    Last Post: 11-23-2004, 05:32 PM
