Results 1 to 7 of 7
Thread: Sensenich adjustable
    Mar 2005
    Thompson Falls, Mt.
    153
    Have many cubbers tried the 72" Sensenich adjustable prop? If so, how does it compare to a Borer or Catto in take off performance? Does it weigh the same as a Catto? Goods, bads and uglies?
    7,168
    Interesting question. Is it approved for certificated Cubs?
    We expect metal props to perform better than wood, generally - but I flew an Airknocker with O-200 and a "different" Sensenich wood prop - no metal tips,and "clipped" in appearance. It would turn rated rpm on climb out - an honorary Cub.
    For smaller Cubs, there was the gorgeous Beech-Roby. You could adjust it in flight. No idea why it didn't catch on - Univair has the type cert.
    supercrow's Avatar
    Dec 2008
    399
    I can't speak to the abilities of that particular prop but, generally, I think you have to get into lengths of at least 80" to compete with the props you mentioned. For cruise alone, I am sure a 72" prop can be made to really get the job done. But for takeoff and climb performance the shorter props don't seem to be in the same league as the longer ones.
    Likes Doug Budd liked this post
    Mar 2005
    Thompson Falls, Mt.
    153
    I had an aeronautical engineer tell me a long time ago that you wanted as long of a prop as you could get for takeoff efficiency. The 72" isn't long and I didn't buy a super cub for cruise.
    Rochester, NY
    127
    Just put one on. 76”. Really works great but at the highest pitch setting I can still over speed it.
    Jim
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,424
    What engine are you running?
    Sensenich offers two 76” GA props for smaller HP engines and a 82” GA for the 320/360 range.
    Mar 2005
    Thompson Falls, Mt.
    153
    If you can over speed it at the biggest bite pitch setting, what is it doing with a flatter pitch setting as to exceeding the tips speed of sound, or even over about 83%, which then looses efficiency fast, I understand? I believe when you pitch your 82" Borer to give you 2700 at about 60 mph on climb out you are loosing climb performance.
  1. The Sensenich ground adjustable prop info
    By scottsville in forum Cafe Supercub
    Last Post: 02-22-2020, 04:30 PM
  2. Sensenich ground adjustable STOL prop
    By Bender in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 01-28-2020, 10:01 PM
  3. Sensenich ground adjustable prop
    By TcraftF21 in forum Products, Purchases, Reviews & Prices
    Last Post: 01-17-2017, 10:41 PM
  4. Sensenich 2EK Ground Adjustable Prop
    By R. JOHNSON in forum Experimental Cubs
    Last Post: 12-04-2008, 01:13 PM
