Results 1 to 22 of 22
Thread: Fuselage Cabane Attach Point - Modification
    Grant's Avatar
    At Work.....
    1,785
    Is there an approved mod/Beef-up that adds the saddle over the lateral fuselage tube that doubles up the thickness of this fitting?
    11,285
    i don't understand the question...(picture of bottom of cabane, but question about the top?)
    Sep 2002
    Southern NH
    633
    Click on the picture and put it up full size.
    Grant's Avatar
    At Work.....
    1,785
    Something like this. This would be a side view. Dotted lin would be the "Strap"
    11,285
    Would have to remove floor to install. Probably easier to just make upper safety cable lug catch both bolts
    Grant's Avatar
    At Work.....
    1,785
    It's a rebuild so it'll be easy to access.
    7,160
    Are these things breaking in rough service? I thought it was the bolts that were worrisome.
    I don't do safety cables, but my impression is that a properly installed set of safety cables would save you from almost any kind of gear failure.
    3,265
    Sounds like something that you can add during the repair.
    AkPA/18's Avatar
    Big Lake Ak
    708
    If I understand the modification correctly, you might have an issue with float installations.
    http://thrustline.com/
    supercrow's Avatar
    Dec 2008
    397
    Quote Originally Posted by AkPA/18 View Post
    Good Point. If you made the wrap of 4130X.040 you would add a considerable amount of strength and would only have to relieve a very small amount in the alum. float blocks. Even thinner would add a lot of strength to that area.
    Grant's Avatar
    At Work.....
    1,785
    This "Strap" would only double the Cabane V mount. The float fittings just attach to the MLG part.
    supercrow's Avatar
    Dec 2008
    397
    Agreed Grant. The alum fitting for the front cross wires would have to be thinned just slightly.
    supercrow's Avatar
    Dec 2008
    397
    If you're going around the outside only, would only need a little longer 5/16 bolt.
    11,285
    Yes the ears rip off.
    Top safety cable must be made to a tight fit for it to be useful, most aren’t
    7,160
    If this happens a lot, it seems like a "fix" would be off the shelf from Atlee or CC? Why has this not been addressed before?
    11,285
    that's what the Atlee upper safety cables were intended to fix.... just the implementation as of late is too loose....
    11,285
    now that I think of it... the "repair" of torn off ears also would have that problem.... weld back on ears then weld on thicker doubler beyond tear......
    2,342
    I like the double tab in #5. To make a straighter pull to the lower fitting it may take being a triangle with a third hole for the cable.
    19,818
    Airframes fittings are double thickness which can be an issue on some float installs. I was thinking a strap cut out and drilled between the gear attach and cabane attach fitting that simply bolts on. We discussed it here years ago.
    RaisedByWolves's Avatar
    Feb 2005
    4,080
    If I remember right CubCrafters has a bulletin for early carbon cubs and sport cubs to add a doubler on the fitting
    Aug 2017
    1
    Here's the CC bulletin. Looks straightforward to me. Can't
    speak to the float interference issue...
    http://cubcrafters.com/c/wp-content/...11/SB00010.pdf
    Randy
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    125
    Not necessarily "approved" but you can buy the doubler plates and bushings to weld on stock gear fittings to make them "heavy duty". Total parts cost about $50 per gear fitting plus your time for fitting/welding them on.
  1. PA-11/J-3 Shock Strut to Cabane Vee Modification
    By thegroundhog in forum Super Cub Sick Bay
    Last Post: 11-19-2013, 05:54 AM
  2. Cessna 172 PK2300 Attach Point Fittings
    By cubbiepilot in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 01-25-2013, 02:58 PM
  3. Cabane Attach Bolts
    By Jim Miller in forum Experimental Cubs
    Last Post: 02-25-2010, 08:27 AM
  4. problems found in foward strut attach point
    By RCharles in forum Super Cub Sick Bay
    Last Post: 02-04-2004, 10:13 PM
Tags for this Thread
