Results 1 to 8 of 8
Thread: Fuel Caps are difficult/impossible to remove and replace
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    157
    Plane is a CC EX-2. Has extended range tanks if that makes any difference. Fuel caps are standard vented caps like these: https://www.aircraftspruce.com/catal...?clickkey=7373
    Problem: the fuel caps are almost impossible to remove and then replace. I cannot take them off by hand and have made a tool just for the caps. Can the gaskets be lightly lubed with something?
    3,801
    Fuel Lube
    Likes mike mcs repair, ak49flyer, algonquin liked this post
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    157
    Thanks, that's what I suspected, but being a newbie wanted to make sure.
    mike mcs repair's Avatar
    11,773
    They quit making fuel lube long time ago I think. This is the newer stuff. https://www.aircraftspruce.com/catal...?clickkey=9406
    Likes ak49flyer, algonquin liked this post
    7,372
    Sometimes a shop will put one of those toilet tank gaskets around the tank neck, and it can interfere. I think the little rubber doily is supposed to be flat - maybe 3/32" thick rubber.
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    157
    Yes you are correct Bob, and I do have the toilet tank gasket but have verified it is not interfering. The caps are straight from the factory so probably just need some lube. Going flying tomorrow so will grease it up then.
    20,643
    Sometimes you have to take a screw driver and spread the lock tabs away rom the cap as well. I see this on a regular basis.
    Likes Grant, mike mcs repair, Gordon Misch liked this post
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    157
    Good point. The tabs also seem to be dragging (more than usual). Thanks
  1. fuel caps
    By Mwilcox in forum Member to Member
    Last Post: 01-23-2018, 09:32 AM
  2. Fuel caps
    By Zk Boy in forum Cafe Supercub
    Last Post: 10-03-2011, 06:42 PM
  3. Fuel Caps on 150 HP PA-12
    By MikeJ in forum Modifications
    Last Post: 01-29-2004, 12:19 AM
