Page 1 of 2 12 LastLast
Results 1 to 40 of 42
Thread: Oil
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,084
    Oil
    I use 15/50 Shell oil. I’ve been doing that since I hung a valve in an O-300 in the eighties and was using Phillips oil. The good old boy who fixed my cylinder (I was on my way to SNF) told me I shouldn’t use that because they had all sorts of valve problems in their O-200’s (same cylinders) and they switched to Shell 15/5O. I did and no more problems. I’ve learned that since then Phillips did recognize a problem and changed their formulation and their 20/50 gets good reviews.
    My new to me C170B which sat for 13 years and flew less than 5 hours a year for many years before that, has had two stuck exhaust valves in the first 15 hours of flying. The first was an away game so it was left for the local FBO to do a cylinder change caused by an ignorant repair shop, but not important now. The second one happened at my home field. This airplane has 250 SMOH but a lot of years. It has always used Shell 15/50.
    After several consulting calls and measuring the valve springs from the cylinder that was replaced (which were out of spec weak) we decided to do the rope trick on all the others and clean the guides and replace the springs on intake and exhaust. It turned out that two cylinders had exhaust valves so tight they could not be moved by hand with the springs off. The rest of the cylinders were ok. The A&P working with me used to build engines for Mattituck and I have known him for years and respect his opinion. We cleaned the guides and stems and all good.
    He tells me the Shell 15/50 is known to cause sticky valves and I should switch to 20/50 Phillips. So we have come full circle. I’m curious if anyone here has heard this. I know oil choices are very subjective sort of like guitar strings and bourbon, but I welcome opinions.
    Rich
    PS: I use MMO and TCP now, but of course have no idea what was done before.
    40m's Avatar
    Dec 2013
    Shoreham, VT
    461
    In the past and perhaps still Cub Crafters has recommended Phillips 20-50 with a splash of Camgard in the 340. When I asked Aero Sport prior to taking delivery the tech was adamant that I use Aero Shell 100P after break which I've done. I do like the idea of an engineered package. On the other hand I think it might be a little like "holy water", you wouldn't walk by without putting a little on but you're not sure it really works.
    From Genesis: "And God promised men that good and obedient wives would be
    found in all corners of the earth."
    Then he made the earth round... and He laughed and laughed and laughed!
    Thanks Richgj3 thanked for this post
    Likes BC12D-4-85, 5CT7 liked this post
    Cranman
    FLORIDA/WISCONSIN
    216
    I have used Phillips 20 W 50 for years with no problems. Because my 0 360 sits for an extended period I use cam guard with every oil change. A little MMO in the gas helps keep carbon deposits to a minimum.
    A gun is like a parachute. If you need one and don't have one, you'll probably never need one again.
    Jan 2017
    PNW
    72
    I’ve used Aeroshell 15/50 in my O360 since I purchased my plane 13 years ago. Recently changed to Phillips 20/50. A local engine shop with a good reputation looked at cylinders brought in by a local mechanic that had significant pitting. They claimed that Shell changed formulation of 15/50 and since that change the shop had found pitting cylinders. They recommended Phillips 20/50. I never fact-checked the formulation change but did switch. Maybe others have more/factual information.
    windy's Avatar
    Dec 2005
    Utah
    696
    I have religiously used Phillips 20/50 plus Camguard in my Lycoming O-360, which never sat still for more than a couple of weeks. After 1800 hours, I had three stuck exhaust valves & then decided to get all four cylinders overhauled. Only 450 hours later, I had a stuck intake valve and a bent push rod (stuck exhaust valve). I canít really complain, because the engine went past TBO, but five stuck valves seems odd. Phillips 20/50 plus Camguard was the only oil used in that engine once it was broken in.
    Jan 2017
    PNW
    72
    There was a good write up in AOPA (might have been EAA) magazine on stuck valves. What I got out of it was that valves stick because CHT’s are too low. The article went through the chemical reactions that occur and the temperatures required to achieve the desired reaction. Because Lycoming engines have sodium filled valves, the valves stay cooler. That makes it more difficult to get it warm enough to keep crap from building up.
    I guess my engine is doomed to experience stuck valves because I can’t get it to run hot enough to satisfy the requirements in the article. Until reading that article I was always happy that high cylinder temps were never an issue, even on very hot days. No issues so far.............1400 on the tach.
    windy's Avatar
    Dec 2005
    Utah
    696
    Oil
    Iíve had 5 other lycoming engines in various planes, a few of them that went past TBO, but never had a stuck valve on any of them.
    The O-360 with all the stuck valves tended to run on the warm side. I was happy if it ran cylinder temps as low as 360 degrees.
    Jan 2017
    PNW
    72
    Curious.......what oil did you run in the other engines?
    My CHT’s typically run 320 - 330 in cruise, mid 360’s at full power climbing 90 mph.
    2,063
    One of the major issues with valves is 100LL has 5 times more lead than the engines where meant to run. DENNY
    Likes hotrod180, TurboBeaver, cubdriver2 liked this post
    Mar 2016
    1,508
    Maybe it is me but I find the fuel used plays a big part with valve issues. Engines designed for 80 Octane fuel do not play well when run on 100 Octane. To me Mo gas might be a better choice with the low compression engines.
    Even the O360 with 8.5 compression is rated for 80 at least as far as the original data plate is stamped on the ones I have worked with.
    MMO has allot of value but can not cure every buildup in the guides.
    Regards, Charlie
    Likes hotrod180, DENNY, Pete Schoeninger liked this post
    Vermont
    325
    I read the article Mr. Ed refers to, damned if I can find it again. But with sodium pumping more heat out thru the stem, the stem is running hotter to keep the head cooler. We're talking about stems sticking, not the head. The stem should find it easier to support those chemical reactions. I think the article has it backwards, but I don't have it in front of me.
    What's a go-around?
    Likes mydoghasa170 liked this post
    windy's Avatar
    Dec 2005
    Utah
    696
    Oil
    Quote Originally Posted by Mr. Ed View Post
    My CHTís typically run 320 - 330 in cruise, mid 360ís at full power climbing 90 mph.
    Half of them ran Aeroshell 100, the other half ran Phillips 20/50.
    Likes Cattle cub liked this post
    2,348
    Regardless of oil type try idling while leaned out at higher rpm for a bit before shutdown. Don't just land and quick kill the engine. Let the valve and cylinder temps cool down and stabilize clearances some. Might help reduce oil cooking in the valve guides. Valves loose heat through their lip to seat contact so open valves might remain warmer.
    Likes TCE, TurboBeaver, G44 liked this post
    Jul 2010
    Elizabeth, WV
    583
    I think it was a recent article in AOPA by that Mike Bush character that claimed the deposits were not from oil and were from lead in the fuel and cool temps.
    Vermont
    325
    Gary brings up a good point. My cousin had an early Volvo turbo and would always idle it before shutdown. The plain bearing between the hot and cold sides of the turbo would coke up if the oil stopped moving. Some installed "turbo timers" so you could walk away from an idling Volvo.
    What's a go-around?
    Sep 2002
    Southern NH
    635
    I’ve owned my O-200 Cub for over 20 years, never a valve issue, never had a cylinder off. Ran a mix of Mogas and 100LL. 2 years ago I overhauled the engine, new Millenium cylinders. On my way home from AK last summer, noticed small stumble when reducing power (200 hours smoh). When I pulled the prop through, basically no compression in any cylinder with major leakage by the exhaust valves. Nurse it home, clean the guides and lap the valves. Large quantities of lead and/or carbon deposits on seats. Didn’t change anything from before overhaul except most fuel was 100LL. Respected local shop said he always checks the valve seats on new cylinders now as QC isn’t very good. If the problem comes back I’ll be pulling the cylinders and sending them to him. Very disappointing.
    10,989
    I believe that aircraft approved oils are all just fine. No scientific proof of that, but....
    Example: University of North Dakota ran all their piston aircraft on Aeroshell 15 W 50, after initial break in. These airplanes are run regularly, but run by pilots with a VERY wide variety of knowledge and understanding of engine operations. While I flew their planes at least, we just didn't have valve problems that I ever heard of.
    I ran several engines, both Continental and Lycoming, on Aeroshell 15-50, and never had problems. I also ran a few engines on Exxon Elite Oil, and some on Phillips 20 W 50 oil. I've run Camguard in all of these engines that I owned for years, and I believe that additive is well worth the price.
    Primary problem I've seen is that some engines don't seem to like Shell 15-50, and they leak oil. I've been told by some mechanics that may suggest the engine wasn't properly broken in. I've broken in several engines and followed the engine manufacturers recommendations on this process. Never had an engine broken in properly leak oil.
    Maybe I'm just lucky, but I just use good quality oils, and Camguard as the only additive. I would suggest that if you're having engine problems, it may not be oil related.....maybe.
    Thanks Richgj3, mam90 thanked for this post
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,084
    I’m not looking to blame oil. This airplane sat for 13 years without the prop moving. As I said in the original post, all valve springs were changed because the first set we removed Were out of spec. Two exhaust valves were not moveable by hand once the springs were removed. Once the Carbon was removed things are running well so far with good leakdown numbers and no oil leaks.
    My original question was posed because the mechanic who did the work was dead against using Shell 15/50 because “it sticks exhaust valves”. This is contrary to my 50 years experience owning eight airplanes, but as my old boss used to say: “Maybe he knows something we don’t know”. So I wanted to see what others have experienced. This being the place I go to get opinions based on experience. As you can see, the results are mixed. That COULD mean oil doesn’t matter.
    Rich
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,084
    Quote Originally Posted by mam90 View Post
    My brand new O-200 on my Legend Cub had two leaky exhaust valves in the first 200 hrs. Lead all over. Started using TCP and MMO and things got better. Still, once and a while one would stick for a moment. Maybe once every 50 hours. At least I think that’s what was going on. I sold it with 700 hrs on it with no other issues.
    Rich
    Thanks mam90 thanked for this post
    2,348
    Oil may not matter as much as what's in it. Once suspended by the ashless dispersant things like carbon, build-up materials, wear metals, and combustion byproducts can move around and get stuck to surfaces. Surfaces like hot valves and guides, pistons (ring lands, skirts, and bottom inside), or the inside the valve covers on springs and things. The oil can leave behind whatever it was packing around so change it often. Filters help but only down to a certain size of material.
    Likes Richgj3, RVBottomly liked this post
    cruiser's Avatar
    South Glens Falls, NY
    1,474
    Brand? Multi weight or not? Makes no difference. https://www.blackstone-labs.com/wp-c.../Aug-17-AC.pdf
    Thanks Richgj3, nightflyer, 40m, CharlieN thanked for this post
    40m's Avatar
    Dec 2013
    Shoreham, VT
    461
    Like most things buy quality from a reputable company and the results are likely to be similar. For me it about the length of time the oil is protecting the guts while sitting idle.
    Likes Richgj3 liked this post
    55-PA18A's Avatar
    Dillingham, Alaska
    639
    Good article from Blackstone. I'm a believer in oil analysis.
    Is is there a "Use by Date" for aviation oil? Would a case of oil that's been sitting on the shelf for a couple years be OK to use?
    Jim
    Mar 2016
    1,508
    The main thing I see in that document is how very poor the ring seal is in these engines resulting in the high level of lead in each sample. I would love to see the numbers from engines run on Mogas.
    I have seen the numbers from our race engines which have essentially no blowby. As in very little fuel contamination in the oil. These engines run fuels both with leaded gas and unleaded with octane ratings from standard pump gas to as high as 114 Oct.
    Regards, Charlie
    n40ff's Avatar
    Oct 2009
    WV
    966
    I know you all know this but the best thing for an engine is to run it. I just sold an old O235C1 run out and the log book was interesting. It was installed in a Piper Colt in mid 1964. It received many 100 hour inspections but only one annual in it's total life of 1944TT over less than two years. Nothing was replaced, the entire engine went to TBO. 80/87 gas and ESSO oil was used.
    Jack
    Likes CharlieN, DENNY liked this post
    2,348
    Also note the increasing trend level of silicon in the O-300-D at the end of the article. That can come from intake dirt bypassing the filter and airbox heat flapper...while parked or when running. Might be worth a look at that part.
    10,223
    4400+ hrs on C85, 2 C90, 0200 and a Lyc 0145 and never a stuck valve. 99.99% of it burning mogas, 22,000 gals of it and every oil out there, Aeroshell mineral, 15 50, w100 and Phillips 20 50. Everyone who I flew with burning 100LL has had a stuck valve, some more then once. We had a friend here with a R680 Stearman who had a stuck valve a couple times a summer, switched to mogas and never had a stuck valve again
    Thanks CharlieN, Skywalker thanked for this post
    Likes mam90, hotrod180 liked this post
    Mar 2016
    1,508
    Bingo
    Regards, Charlie
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,084
    I would love to be able to buy corn free mogas. Unless some laws change down state NY will not be able to sell it. Mogas comes to the oil terminals on LI without alcohol. It’s mixed in there. After Sandy, we could not get gas for our cars. There was plenty of gas at the terminal, but the alcohol barge was stranded somewhere. In the few days it took to show up, the politicians had almost thrashed out an exemption but couldn’t quite get it through. Idiots. It would only take the stroke of a pen to get alcohol free mogas at the airports. Great alternative to 100LL for us low compression guys. Even the boat yards here have to sell gas with alcohol.
    Mar 2016
    1,508
    Conn is under the same requirement as you. I expect more areas around there than I have looked at. Makes it hard to have a hobby with boats or older cars since many aspects of them are damaged by the alcohol. In the summer I drive a 48 Yo car. All the rubber parts in the fuel system do not withstand the alcohol. The fuel pump diaphragm stiffens up and obviously it stops pumping.
    This is no different with any mid 90s or older vehicle be it a boat or plane.
    The rubber composition in aviation hoses will not withstand the alcohol.
    Granted there are those that fly with E10 and say it works fine. Not with me onboard mate.
    When I need to buy a jug load of E10, time permitting I pour a small amount of water in the jug and let it sit. The water draws the ethanol to the bottom. I then pour off the gasoline from the jug. Works best in the winter when the water/ alcohol turns into a slush-ice lump on the bottom.
    Regards, Charlie
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,084
    Charlie
    John Talmage a farmer out East in Baiting Hollow made himself a rig as you describe to make alcohol free mogas for his Kinner powered Bird biplane.
    It would seem to be a no brainer to allow aircraft that can use car gas to be able to get alcohol free gas. The amount of pollutants caused by no alcohol in airplanes would be un measurable against what comes out of cars running alcohol gas. And the reduction in lead should make the environmental people happy. Sooner or later there’s going to be no more leaded av gas. While there needs to be an alternative for higher compression motors, car gas without alcohol is all we need.
    Rich.
    Mar 2016
    1,508
    As he does separating gas is not hard to do. He clearly understands what is needed to generate the volume he needs.
    A few years back there were plenty of places down your way to get "Pure Gas". Obviously that got taken away. If anyone of those who took that fuel away knew what was used they would be on a rampage.
    There is no reason any recip can not run on the non alcohol fuels we have available. I have no issue with buying a choice of 100, 114 or 116 Oct non leaded fuels. Heck we would love it if there was a greater market for our race fuels so the price could come down closer to what av gas is. Some of our fuels are well over double the cost of avgas.
    Ultimately the only change an aircraft would benefit from changing to unleaded fuel is a change in pistons to run thin profile rings. This would allow for a far better ring seal and stop contaminating the oil.
    Regards, Charlie
    Vermont
    325
    Mogas just needs a little stabilizer and it lasts. I proved it in a plane with a rear tank I used mostly for CG. Only switched into it to see how it burned, only noticed higher EGTs after nearly 3 years. Still burned fine in the tractor. Add an electric pump if you have a long taxi in Texas. Last weekend my little outboard did fine on last years two stroke mix with stabilizer. The literature says two weeks for oily gas. Bull. But contaminate it with alcohol, all bets are off.
    What's a go-around?
    10,223
    Rich I burned straight ethanol gas for about a year ( 1000 gals) if you don't let it sit and be a sponge for moisture it's ok. Only problem I ever had was the Ford model A fuel gauge in my rear tank would leak sometimes. Then I discovered StarTron and I never had any problems after that, even letting it sit. Burned 2 or 3000 gals with StarTron. Great stuff. I still carry some with me on floats.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,025
    Trivia: aviation oil is dated. An FAA rep came into the shop I was working in and told us that we had to throw out the oil neatly arranged on a shelf because it wasn’t dated. He pointed out that the case was where the date was and the only way to tell if the oil was OK! Yes true story.
    2,348
    Shell used to stamp a code on the bottom of each plastic bottle. Not sure if it was for production or expiration date. Probably the first one.
    Mar 2016
    1,508
    Those are production dates, industrial and automotive lubricants are dated as well. There is no government required expiration but the date code allows the manufacture to be released from liability after a specified time period.
    Regards, Charlie
    2,348
    What's the shelf life?
    Vermont
    325
    A recent AeroShell bottle says "Retest date 4 years after date of manufacture".
    What's a go-around?
    Mar 2016
    1,508
    Exxon-Mobil states 10 yrs on plastic bottles.
    Online searching I have done shows there is no loss of functionality to old oil.
    One statement referring to Mobil 1 is the oil will outlast the container in storage.
    I do have a jug of chainsaw oil that the container crumbled when I went to pick it up early this year. I think some sun got to it in the shed.
    Regards, Charlie
    Likes RVBottomly, BC12D-4-85 liked this post
