Results 1 to 8 of 8
Thread: 0320 egt probe location
    Dec 2016
    7
    What cylender should a egt probe be on a 0320 a2b super cub
    i but a new lees exhaust on and it does not want to fix on the same tube as the old e
    10,998
    19,505
    Usually put the CHT probe on one rear cylinder and the EGT probe on the other rear cylinder. Some discussion here. https://www.shortwingpipers.org/foru...amp-EGT-Probes
    Thanks stknrddr thanked for this post
    1,987
    On a hard climb my #2 is the hottest, the reason I know this is I have a 4 cylinder EGT/CHT. Without that you don't know what you don't know! A single probe is about as useful at tits on a boar hog. Every plane/engine is different. Get a 4 cylinder EGT/CHT it will save you money in the long run.
    May 2012
    SE Montana
    204
    The best thing about EGT gauges is to be able to troubleshoot/monitor individual cylinders. Impossible to do with only one probe. Put one on each cylinder.
    cubflier's Avatar
    Nov 2003
    1,284
    Is it just my imagination or do people with 4 point monitoring systems have more cylinder problems than those with single point systems.
    Jerry
    If it looks rough...it is!!
    3,027
    Only if they switch to digital tachs at the same time!
    Likes cubflier liked this post
    1,987
    Jerry
    They both have the same amount of problems. It is just without a 4 cylinder EGT/CHT you have to wait until issue has caused enough damage that you notice it. Burning a valve from an intake lead, CHT'S over 420 due to a crack primer line making mixture rich, bad plug over 2000 rpm, MAG timing issue, Poor baffling, ect. All of this and more is easy to pick up and fix early if you know what you are looking at. One of the problems is finding an A&P/IA that understands what they are looking at.
  1. Sutton Exhaust EGT probe location
    By Gilbert Pierce in forum Modifications
    Last Post: 01-08-2018, 11:31 PM
  2. Outside Air Temp Probe Location
    By Mush in forum Modifications
    Last Post: 04-28-2013, 10:12 AM
  3. CHT probe location
    By NimpoCub in forum Tips and Tricks
    Last Post: 06-26-2012, 11:17 PM
  4. EGT/CHT Probe Location
    By Captain Ron in forum Super Cub Repair Facilities
    Last Post: 01-12-2006, 11:02 PM
