Results 1 to 8 of 8
Thread: Madras wing tip broke
    Jan 2017
    Utah/Alaska
    143
    So I have a customer with Madras wing tips. One was damaged pretty good. I know they are not made anymore so my options are to repair the fiberglass and repaint or replace. What other options are out there for replacement tips that I can swap them for? Thanks, Tim
    40m's Avatar
    Dec 2013
    Shoreham, VT
    438
    I have a one which came off a Pacer what side do you need?
    From Genesis: "And God promised men that good and obedient wives would be
    found in all corners of the earth."
    Then he made the earth round... and He laughed and laughed and laughed!
    10,998
    check with CAC Plastics in wassila
    Jan 2017
    Utah/Alaska
    143
    rightClick image for larger version.
ID:	49723Click image for larger version.
ID:	49724Click image for larger version.
    10,998
    fix it... that's not bad
    mask tape outside
    pop rivet metal strips on outside to hold it temporary,
    repair inside
    drill out rivets & remove strips & tape
    2,149
    Do them a favor and replace. Lots of options fit the rib. Demers' are heavy. Had them on my Champ.
    10,099
    Quote Originally Posted by astjp2 View Post
    I thought you said "One was damaged pretty good."?
    10,998
    I forgot to mention first step. Take cutoff wheel an cut a small gap at all cracks to get rid of the overlap.
  1. madras tips
    By L16abe in forum Experimental Cubs
    Last Post: 07-06-2020, 06:48 PM
  2. Madras wing tip replacement
    By txfirefighter628 in forum Modifications
    Last Post: 11-21-2015, 12:18 PM
  3. Removing Madras Tips
    By Bouncer in forum Cafe Supercub
    Last Post: 10-11-2011, 11:50 AM
