TurboBeaver
Northern Maine
If your experimental the options are endless. I tryed to think up the simplest way possible to do the crossbar without welding or bolting anything.
1" aluminum tubing with .125 wall, weight 15oz. ( 24" piece)
Milled out one side, cut out the original .710 cross tube,( weight 8oz)leaving 1.75" stubs. Installed new tube with two 1/4" SS /QD pins. Net weight gain 7 oz. Cut out faces rearward, so the pin goes through TWO sides. Done.
Dogleg welded in backasswards by the former rebuilder!!! Oh well.
