Results 1 to 12 of 12
Thread: Tricky "Landing" in Califorina
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    15,028
    One commenter said the prop came off and windsheild was covered with oil. Looked to me like it was still making power, but maybe just really fast.
    10,998
    Runway behind you....
    Sep 2004
    Illinois & Wisconsin
    680
    Well, yeah—the prop would come off and windshield be covered with oil after he hit the embankment.
    Cub junkie's Avatar
    My Moms basement
    2,104
    Looks like a VW powered CX4
    347
    Understand that it's a different paradigm than a Cub on a short strip, but wonder why so fast with so much runway in the rear view mirror?
    Back In Alaska
    RVBottomly's Avatar
    Sep 2017
    787
    The pilot said he lost his propeller and had oil on the windshield before getting to the runway:
    https://abc7.com/upland-plane-crash-...reser/6269647/
    He was going fast. Almost looks like it was a smart thing to pull up before hitting the road at the end of the runway.
    Cub junkie's Avatar
    My Moms basement
    2,104
    80 and ready to get back in the saddle, good show. Hope he safeties that prop on the rebuild.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,956
    If it was indeed a lost prop and an oil covered windscreen, that sounds like a broken crank.
    Mar 2016
    1,430
    What I read is when the "engine" broke he was too high and close but I got the opinion he chose to dive for the runway rather than try a circle for a more proper approach. I did that once, came out better than he did but he got out OK.
    Regards, Charlie
    May 2014
    638
    Quote Originally Posted by Cub junkie View Post
    Good call.
    Always wondered how VW powered aircraft handle thrust forces on the crank.
    Maybe not so well..
    kudos to the 80 YO builder/test pilot, my hat is off to you sir!
    Cub junkie's Avatar
    My Moms basement
    2,104
    After looking at the pics on Kathryn's report thats probably what happened.
    Mar 2016
    1,430
    Quote Originally Posted by Oliver View Post
    Good call.
    Maybe not so well..
    The VW engines have many options for engine cases and crankshafts. On a heavily modified KR2 I did a re-design / build on. We used a big VW, 2340 or something like that.
    We had 2 case failures and 3 crankshaft failures before the plane was considered ready for any far reaching destinations.
    This was in the early 80s, the Claudes buggies cranks are or were a single shot forging, they only lasted a few hours. Scat makes good cranks but the prop adapter tried really hard to go on a solo flight. Then a Scat crank with the added bearing, that one worked. Then the case failures started.
    After a few years we determined that big a VW engine just should not turn as slow as a direct drive needs, the engine rally needs to turn up some RPM to get out of a harmonic range.
    Neat airplane though, I designed the changes right when I got out of collage, used the NLF 215 airfoil. Huge flaps and drooping ailerons, flaps reflexed as that airfoil calls out for. After an initial change to the horizontal airfoil due to the stupid high pitch moment of the wing the plane had superb control harmony.
    WOT was 175, cruise of 155 and approach over the fence was 30. Issue was, even with a wider and stretched fuselage, it just was not roomy enough for two. Wish we made it bigger. After a decade or so it was replaced by an RV6.
    Regards, Charlie
    Likes Oliver liked this post
  1. "SAFE" wheels down amphib landing (gear)
    By NimpoCub in forum Float Operations
    Last Post: 03-05-2014, 01:19 PM
  2. "Interesting" landing yesterday morn.
    By NimpoCub in forum The Art and Science of Flying
    Last Post: 07-07-2010, 07:42 PM
  3. How do you define "Short-field Landing?"
    By Aviator in forum The Art and Science of Flying
    Last Post: 10-14-2008, 09:01 PM
