Results 1 to 6 of 6
Thread: pa18a-150 header tank
    Jul 2014
    Norman wells, NT
    38
    Hello all, would anyone happen to have a picture of what the front header fuel tank looks like on the ag model? I have been told they are a different set up than the standard cub but don't have access to my plane to have a look. Does anyone have experience adding the defrost kit on an ag model? I was also told that it would have to be changed to make room for the defrost ducting...I have no reason to doubt my mechanic but just curious. I'm also debating on putting the standard header in vs the headerless system at this time.
    Thanks in advance.
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,411
    Should be no difference from a standard 18 in that area.
    Likes Brmoore liked this post
    Jul 2014
    Norman wells, NT
    38
    I was told the header tank sits at an angle, not sure if that's vertically, horizontally or both.
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    780
    They are the same in position and plumbing as the standard cub for the front header.
    The rear is the same but set further back
    lf keeping put in the Atlee heavy wall unit.
    Ed
    White City, Oregon
    920
    The rear is behind the cross tube instead of in front of it.. otherwise identical fuel systems... we took out our rear but left in the front at rebuild, gave us an area to but in an extended “hat” shelf for lightweight items..
    Brian
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    780
    [QUOTE=Steve's Aircraft (Brian);776946]The rear is behind the cross tube instead of in front of it.. otherwise identical fuel systems... we took out our rear but left in the front at rebuild, gave us an area to but in an extended “hat” shelf for lightweight items..
    Interesting idea Brian, which I like. Don’t have to modify the right tank with fitting, etc.
    what guidance is used, or does the STC allow for that? Assume you still need fuel selector change to run on both.
    Ed
  1. FS: $85.00 3169-1A FRONT HEADER TANK and 3169-2 REAR HEADER TANK
    By davidv.lewis in forum Parts and Pieces
    Last Post: 05-25-2020, 04:09 PM
  2. PA-11 header tank
    By Ken Kennedy in forum Cafe Supercub
    Last Post: 05-15-2009, 08:54 PM
  3. Header tank
    By arizcub in forum Member to Member
    Last Post: 05-03-2007, 03:08 PM
  4. Pa 12 header tank
    By skysigns in forum Cafe Supercub
    Last Post: 12-07-2004, 03:59 PM
