sesaviation
SPONSOR
Turner ,MT
Is there paper work out there to install the super cub dogleg on the Pa-11 baggage aera
Thanks! No that is teak & holly marine plywood. The dark is teak and the light is holly. I drew up the floorboards in CAD then cut and adjuted them about 4 times using cheap luan ply. once I got them fitting perfectly I sent the CAD files to a marine plywood house and they have a CNC router and they cut them out for me.Grant,
Did you use pin strip tape to give the wood boat look? I like it, well done 3.
Are you looking for an approval on what you have or do you want to install a dogleg like a Super Cub?No that's the baggage floor just above bel crank
