Results 1 to 5 of 5
Thread: Cub crafters 3x3 landing gear experience
    Oct 2018
    50
    Looking at putting a 3" extended gear on my super cub. Looking to see if it would be worth putting 3x3 extended landing gear on instead of the standard 3" gear!
    Thanks in advance for any info!
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    328
    i would if your cg is forward
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,954
    Agreed. If you have a 360 and a Borer prop, it's a good choice.
    DJ's Avatar
    Jan 2009
    Bolivia
    219
    It will make an in-flight forward CG worse with big tires.
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    355
    If your CG is forward that is one way to fix it only on the ground for braking. You could also balance the plane and correct the CG and performance by removing weight on the nose, move the battery farther back in the fuselage if it is the old Gill, add weight in the tail section, extended baggage put your tools ropes, extra heavy stuff way back in it.
    Just another way to fix the problem.
    Been there and have the hat!
    Likes DENNY, skywagon8a liked this post
  1. Cub Crafters 3x3 gear
    By pittsdriver in forum Modifications
    Last Post: 01-31-2016, 09:17 AM
  2. cub crafters 3x3 gear
    By green horn in forum Cafe Supercub
    Last Post: 04-18-2015, 08:50 PM
  3. cub crafters 3 inch extended gear
    By jsawyer in forum Cafe Supercub
    Last Post: 04-28-2011, 07:56 PM
  4. Cub Crafters 3 Inch Extended Gear
    By Brian T in forum Cafe Supercub
    Last Post: 05-30-2008, 05:37 AM
