Mi. ( Yooper)
Good points, the area within the lower air exit or tunnel, houses the carb airbox and skat tubing from muffler to carb heat/airbox, also, the exhaust mufflers, one each side, are just behind and below the rear two cylinders it is a Vetterman exhaust system. It is rather congested in that area, but still plenty of room for air to exit in my opinion. There really isn't anything I could do without major changes to alleviate the way this is. The lower firewall behind the tunnel has no flange, I removed the flange in the hope of allowing a smother transition for air to exit overboard. Again, no change. The lip or fairing on the tunnel, which I added, seemed to help some, I've tried it both ways and even tried different sizes and the one on there now seems to work best, temperatures are worse without the fairing. I agree with your assessment that the problem lies with the exit air side of things.What’s inside that bottom fairing? Is anything faired inside or is it open? I don’t think a Cub’s cowl cheeks are magic but they are in airflow that effectively draws warm air out. Given how you’ve baffled behind the prop I’d say your inlet air looks like a typical Cub but the outlet air is very different. That’s where I’d focus my efforts. If your side scoops are still there I bet you could close off that bottom outlet and see improvement. It’s easy to visualize that rear area in the lee of that large ramp profile being in an eddy. It may not be but with those scoops there it would be easy to test.
Sent from my SM-G988U using SuperCub.Org mobile app
