Results 1 to 11 of 11
Thread: 1940 J4A Master Brake Cylinder
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    184
    Anyone happen to have a source for a used in working condition master cylinder? A new one is quite pricey. Thanks.
    7,595
    I heard they can be rebuilt with an auto master cylinder repair kit.
    I rebuilt a pair of UPF-7 masters - it was NAPA kit#1.
    10,829
    Which one?
    21,168
    Yep, fixed the leaking master cylinders on the Hamilton Metal Plane over at New Holstein the year of Sloshkosh with that kit.
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    184
    Thanks guys. Will check into which cylinder Glenn.
    Nov 2007
    HIXTON,WI
    127
    seems like the last time i did mine the kit was for a 58 chevy.
    4,070
    Will those seals handle petroleum products like 5606?
    Wag2+2's Avatar
    Nov 2011
    West Michigan
    184
    Looks like it might be the top one Glenn.
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    702
    Isn't the J-4 supposed to use DOT-3? Mine did.
    -Cub Builder
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,431
    5606 worked fine in these brakes for me. The old Wagner cylinders with Napa seals could stop double puck Clevelands with bushwheels on a dime and give you change.
    Likes AkPA/18 liked this post
    7,595
    Yes to Dot 3. Ours came with 5606, so I stuck with it.
    I have been using Dot 5 on the J3s, but it s now $40/pint, and since both use MS O-rings everywhere, I may succumb. I will, however, use inverted flares until they are no longer available.
  1. Accessing master brake cylinder
    By L18C-95 in forum Super Cub Sick Bay
    Last Post: 08-16-2018, 04:39 PM
  2. Toe brake master cylinder
    By pitts12driver in forum Experimental Cubs
    Last Post: 06-15-2013, 09:03 PM
  3. brake master cylinder
    By marc in forum Member to Member
    Last Post: 08-24-2008, 01:07 PM
