Results 1 to 12 of 12
Thread: XM
    Meanwhile,...
    5,204
    XM
    I have an antenna I swap back and forth between airplanes with my 796 and its getting intermittent and causing a bunch of static on the audio circuit that goes away when you unplug the antenna. Guessing the antenna is breaking down, any thoughts?
    2,981
    Sounds more like the cable or the connector.
    Meanwhile,...
    5,204
    Thanks I’ll snoop it.
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    484
    I go through about 2 antennas a year. They get bad at the ends where they go in the plug and the antenna. They dont like any twisting. Breaks wires at the ends inside. Especialy if its magnet mount and you pull it off by the cord.
    "There are 3 kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves." Will Rogers
    10,905
    Add a pigtail to do the connection to???
    Oct 2016
    MT/SD
    484
    I run equipment so im constantly moving radio and antenna, if the riggs you are using your xm in are you own, the cheapest, bestest alternavive is to buy an antenna for each vehicle. Xm antennas on my cars ive never replaced. I go through two or more a year at work though because evryday its moved.
    Meanwhile,...
    5,204
    Quote Originally Posted by Cub Special Ed View Post
    Wouldn’t that require multiple subscriptions?
    Oct 2016
    MT/SD
    484
    No. Subscriptions go with the radio not the antennas. I velcro the radio in whatever im using it in. If i put it in my personal vehicle, there are already antennas there to hook to.
    2,981
    Oldcrowe
    Have a new connector crimped onto the cable. Not expensive and it's at a point of high stress.
    Feb 2004
    Mt.
    1,323
    On the Garmin Aviation units subscription goes with the antenna. On my hockey puck 496 xm antenna’s the cord eventually breaks right where it goes into the antenna. I’m thinking of mounting the antenna and some cord to a base made of plastic, wood or aluminum then if it breaks it will be out in the cord away from the antenna and easy to splice. I’m on my 4th antenna since the 496 came out and my original unit still works perfect. I have no idea how many hundreds of thousands of tight turns it has on it with 14 years of Supercub and Ag flying but the electronic attitude indicators are still perfect all day every day.
    Dave
    Meanwhile,...
    5,204
    Oldcrowe
    The antenna on the 796 it uses a goofy 90 degree connector, any idea where to get one?
    2,981
    Got a bag of them right here
