Results 1 to 3 of 3
Thread: super cub corrosion.
    May 2020
    3
    Hi all,
    Has anyone experienced any corrosion of any kind on their supercubs? specially under the seats and down the back of the tail or spots where you cant see unless you pull everything out. My 69" super cub is just about to go for its annual and want to check for any corrosion before i take it outback.
    pictures would be amazing too
    happy flying
    10,082
    Look at the very aft end of the fuselage above the tail wheel spring. That area tends to collect dirt and moisture rusting out the cluster of tubing. This is a consideration in all steel tube fuselages not just Cubs.
    Likes n40ff liked this post
    19,476
    I would look at this thread. https://www.supercub.org/forum/showt...oor-Frame-Rust
    In addition clean all the dirt and debris out from betwteen the fabric and tubing. Most all of the corrosion I see is from dirt holding moisture against the tubing and abraiding the primer like sand paper.
    Likes Pete Schoeninger liked this post
  1. Corrosion 47 PA-12
    By utb 44E in forum Super Cub Sick Bay
    Last Post: 06-06-2018, 01:58 AM
  2. Corrosion
    By CubDriver218 in forum Cafe Supercub
    Last Post: 07-26-2014, 07:02 PM
  3. Tubing Corrosion
    By FlatSideShovel in forum Super Cub Sick Bay
    Last Post: 04-08-2011, 01:47 PM
