Well....
- During my sojourn in Texas, got totally biased in favor of indirect stick-burner smokers in particular and burning charcoal or wood in general
- Have had in the past a wide variety of grills and smokers; never got quite enough interest to compete with my buddy's $50,000 competition rig, but if I had the right magic wand..... on a trailer, gas starter, water tight storage bins for charcoal and sticks, very heavy (i'm thinking 5/16") smoke chamber and grill, etc.
- Current smoker fleet is made up of a "Jumbo" or whatever it's called Weber Water Smoker, a Weber Genesis (yep, original, not II) Gas Grill, and a Weber 22" basic grill.
- Previously had a Lyfe-Tyme indirect .....should never have given that one up, but it was a big chunk of iron to move from Ewe-stun to Los Anchorage
- Have heard great things about the BGE but can't bring myself to spend the money that they want for a BGE up here in Los Anchorage.
- Were I in the market and presumably not considering a $X,XXX or $XX,XXX semi-custom smoker from Pitts & Spits or Lyfe-Time or ???, I'd look seriously at: BGE (it's unique), Traeger (pellet grill, with the pro's and con's of that sector), or Oklahoma Joes for an indirect smoker. I think there are comparable gas grills to Weber, but Weber (IMO) is just a notch, small, but nevertheless a notch above others...and for indirect smokers, Oklahoma Joes is the only one that I'm familiar with that has heavy enough plate and (relatively) tight enough construction in the mass-produced segment to give a good smoke.
- Also IMO, if one is going to go with a stick-or charcoal smoker (leaving aside the BGE), Charbroil, Pit Boss, or similar variants are just too light of material for doing a good smoke..which is all about trapping and holding heat and moisture.
- As others have said, it's more about the user and effort applied and less about the equipment....
- Very much FWIW, but since I'm tasked to smoke 30-40#'s of brisket at least twice a year and 3-4 turkeys at each of Thanksgiving and Christmas up here in Los Anchorage, I have put together a modular smokehouse (2x4's, plywood, rigid foam insulation, canvas opening) that I put in place about 1-November: something's needed when more often than not, the turkey smoking occurs in below zero weather and/or when the winds want to keep the smoker cool...the brisket's are usually a 8-10 hour event and the turkey's are typically 4-6 hours. Something is needed if that falls in November - February.
