Page 1 of 2 12 LastLast
Results 1 to 40 of 54
Thread: Spalled Camshaft
    windy's Avatar
    Dec 2005
    Utah
    671
    Spalled Camshaft
    My Cub’s O-360 engine is in the overhaul shop. Today, they told me that the camshaft is unserviceable, rejected. Cam lobes for cylinders #1 & #2 are spalled. Recently, immediately prior to the engine going in for overhaul, #4 exhaust had a bent push rod and #3 had a stuck intake valve, both at the same time. 450 hrs before the decision to overhaul, all four cylinders got reworked, because exhaust valves on #2, #3 & #4 were stuck, but no bent push rods.
    The previous engine overhaul was done by LyCon and a brand new camshaft was installed. They also reshaped the cam lobes to give the engine extra pep.
    I’ve religiously changed the oil (Phillips 20w-50 x/c) & filter at 50 hrs (or less) throughout the engine’s 2250 hrs SMOH, along with 8oz of Camguard at every oil change (except during break-ins). The camshaft has the CentriLube STC that spritzes the camshaft with oil during operation.
    My questions are these - is it normal for camshafts to spall when the engine reaches its overhaul time, especially a camshaft that started out brand new? Could all the valve sticking have caused the damage to the camshaft? Isn’t the extra oiling from the CentriLube and Camguard supposed to prevent this kind of damage to the camshaft? Could the coating that was put on the camshaft after the cam lobes were reshaped have been the failure that caused the spalling?
    I’m just wondering what I could have done differently to have a better outcome. Although I did wear out the engine fair & square.
    Thank you for your thoughts and advice.
    windy
    10,905
    My guess... the reshaping.
    1,968
    I had to replace my cam at about 1,300 hours. The plane did sit for 18 months without being flown, but it had a teardown 1 year after that for a prop strike and the cam looked great. Lycomings just seem to have some issues with the cams, some do some don't. I used the same oil/Camguard treatment and changed every 25 hours. I think reducing the amount of Lead in your fuel helps with the stuck valve issue, along with MMO in the fuel occasionally. While I was waiting for my SI to get done I was providing the plane with full tanks to some friends just to keep it flying.
    Thanks windy, 62E thanked for this post
    Apr 2009
    AK
    114
    Why so many stuck valves? Don’t usually see that much on -360’s- even running straight avgas for 2000 hrs... I’d also have to suspect the reshaping/recoating/hardening process- not that these engines can’t benefit from a different cam profile, but it just seems you’re gambling any time you do anything to a cam after its left the manufacturer...
    Thanks windy thanked for this post
    G44's Avatar
    Oct 2011
    SW Michigan
    513
    Quote Originally Posted by windy View Post
    windy
    What was the calendar time interval between your oil changes? This is just as important as tach hours.
    Likes algonquin liked this post
    TirolCub's Avatar
    Sep 2006
    Austria
    208
    Windy, which year was your last overhaul and did you had some metallic particles in your oil filter after examination?
    There was a Lycoming SI No.1543, dated February 23 2012 out there relating a batch of faulty tappets.
    And look out for „Airworthiness Bulletin AWB 85-014“ from the Australian Civil Aviation Safety Authority !
    ... Investigations by various Lycoming engine overhaulers have found that in the majority of cases the filter contamination was directly attributed to severe spalling of the now superseded Lycoming tappet body P/N 15B26064. These tappet bodies were supplied from late 2009 until mid 2012 ...
    I had severe spalling of my camshaft two years after major overhaul in 2011 (Lycoming O320) because of these tappets.
ID:	48435   Click image for larger version.
ID:	48436   Click image for larger version.
ID:	48437   Click image for larger version.
    Thanks windy, jrussl thanked for this post
    Likes AkPA/18 liked this post
    Dec 2016
    Canyon, tx
    514
    Quote Originally Posted by G44 View Post
    I think Windy’s oil change interval is usually about two weeks or 50 hrs I’m also wondering if flying across N America 27 times could have attributed to some of the wear? That stinks either way!
    Likes SJ, OLDCROWE, windy, jrussl, mike mcs repair liked this post
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,965
    Wendy's engine certainly sat less than many of us combined - although it could have been that two week break when she went to Antarctica.
    Likes windy, jrussl, mike mcs repair liked this post
    19,364
    I would contact LyCon and see if your cam had the DLC coating. I am told since Lycoming started doing it they have ended their spalling issues. Up until the DLC coating it has been a crap shoot from my experience on cams spalling. I inspected my cam when I topped my engine back in the fall, luckily I have the roller cam that is not to prone to spalling.
    Do you have an engine monitor Wendy?
    Thanks hman442 thanked for this post
    windy's Avatar
    Dec 2005
    Utah
    671
    LyCon had overhauled the engine in late 2011, so I’ll have to do some research to see if the offending tappets had been installed in my engine. I’ll also call LyCon to see what I can find out about what coating they used. 450 hrs ago, when the cylinders were out on vacation, the camshaft looked ok, from what could be seen. Those are good leads to follow up on. Thanks!
    In the summer months, I’d usually change the oil & filter about every month and maybe go as long as three months between oil changes in the winter (like when I went to Antarctica, not in the Cub).
    On the most recent oil change, there were a few, and I mean a VERY few, flecks of silver metal, non metallic. This was the first time I’d seen anything other than a few carbon globs.
    I have an 8-point EI monitor, with all four CHTs and EGTs monitored. The EGTs run in the 1200-1350 range & the CHTs run in the 350-375 range in the summer (30-40 degrees cooler in the winter). The first batch of stuck valves occurred in summer & the second batch happened in winter.
    The stuck valves had me perplexed. I’d have thought that getting the valve guides & exhaust valves replaced 450 hrs ago would have solved that problem. I used MMO intermittently during the last 450 hrs. Over the engine’s service life, I’ve used 100LL almost exclusively, except the times I was in Baja and had to use a tank of ethanol-free mogas to make it to the next Avgas stop. At least having multiple simultaneous stuck valves has made the decision making process a bit simpler.
    I’m not complaining about the work that LyCon did on my previous engine overhaul. It was a strong, reliable engine for 8 years, until the very end. I’d have wished I could have flown it more hours before having to get it overhauled, but I did indeed get my money’s worth out of it and a priceless amount of fun.
    For the current engine overhaul that is underway, I think I will definitely decline any option to reshape the cam shaft lobes. Another question: other than cost, is there any advantage one way or another for the replacement camshaft to be brand new or certified reconditioned?
    Thank you all for the feedback
    windy
    19,364
    Reason I asked about the engine monitor was if you saw any indication before or during the stuck valves. Curious if it was running rich, cooler etc.
    I would go new cam kit no question. Seen to many spalded cams and on a reconditioned there is no way to no how deep that hardened layer is. Tony changed his just after OSH this year for the exact same thing and he flies almost as much as you. Ken tells me he has seen no more spalded cams since Lycoming went to the DLC coating.
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    720
    New cams for me, from now on
    Likes windy, mike mcs repair, OLDCROWE liked this post
    windy's Avatar
    Dec 2005
    Utah
    671
    Spalled Camshaft
    On the first batch of stuck valves, the EGT (and CHT to a lesser extent) told me exactly which cylinders had the stuck valves. On the second batch, it was a bit more subtle. The #4 EGT was running a bit cooler than it should have, which made me suspicious, but not sure. That’s the one that had the bent push rod, so maybe it was making a little bit of power. The #3 intake valve was stuck part way open on this last round, but the EGT looked completely normal, although the CHT was a bit lower than normal, but not enough to make me suspicious. And I get suspicious pretty easily.
    P.S. I ALWAYS lean after I get leveled off after takeoff. Even when flying at sea level. Even though I have the engine monitor, I lean the old fashioned way - lean to peak RPM, then enrich a half turn. My plugs are always gray when I take them out to clean them.
    2,096
    Some of us that have had valve sticking wondered "why me". Years ago the various service letters and bulletins either hadn't been developed or were not commonly available before today's online access, especially for we owners. Here's a quick summary: https://www.tennesseeaircraft.net/2007/12/15/422/. Others are available from Lycoming.
    Note that in addition to combustion byproducts and lead, intake air dirt combined with available lube can eventually collect in valve guides. That plus offset valve stem to guide wear leads to sticking as clearances are lost.
    If at 50 hr oil changes even with filters you see the oil's built up more than the usual lead and carbon from increased blowby consider reducing the time between oil changes. Oils cheaper than fixing things in the long term.
    Used oil analysis (UOA) can benefit if it's done over the life of the engine. Here's an example. Click on the Sample Reports for an example of implied guide wear:https://www.blackstone-labs.com/engine-types/aircraft/ If intake dirt bypasses the filter element or carb heat flapper silicon can increase.
    Likes windy liked this post
    Jan 2005
    Fowler, Ks
    561
    When i overhauled Josh at Colorado airparts suggested the DLC ( diamond like carbon) cam and tappets
    He said they were tearing down tbo engines and the cam/lifters were still like new
    His number is 970-275-2900 if you would like to visit with him
    2,096
    When valves start sticking rocker arm, cam, and lifter body face pressures rise. It would be nice if there were a facing that would outlast a bent pushrod event.
    10,905
    one other thought...
    if valve is sticking open some... then the lifter is NOT riding up the cam as normal, and the cam is striking the HARD LIFTER with the HARD CAM... maybe chipping/knocking parts of face off, like in cold starts......... ?????
    Jan 2017
    Utah/Alaska
    123
    Jan 2017
    Utah/Alaska
    123
    Stuck valves probably caused all of the problems. Just like a Hammer on the cam and lifters.
    2,096
    https://www.lycoming.com/content/ope...ticking-valves
    Advice like this and periodic oil analysis can help give a picture of the combustion process and deposits in the oil. Eventually deposits can cook off and form. The cylinders should be inspected at the recommended intervals suggested by the manufacturer (see #14). TBO isn't free.
    Thanks OLDCROWE, windy thanked for this post
    Jan 2017
    Utah/Alaska
    123
    According to that lycoming document, baffling can also contribute to stuck valves. See Gary, I still read! Lol
    2,096
    Tim it's baffling that anybody today reads and actually believes what they see. Nothing's 100% I admit, but when valve sticking happens it's quite real. I had it twice and the second cost me an overhaul that might have been prevented or delayed if we knew then what's available now.
    First sign of spalling was silver sheen in the drain oil. Nothing at that time in the screen.
    10,001
    Quote Originally Posted by astjp2 View Post
    Not unless the hydraulic lifters exceeded their travel.
    2,096
    Hydraulic lifters....not sure about aircraft but on Harleys it can take up to 10 minutes for a lifter to bleed down under pushrod and spring pressure when doing cam changes. When running I suspect an instantaneous valve sticking event may not allow for that bleed down and the cam/lifters get at the very least high surface pressures if not hammered over a portion of their travel. Would depend on where the valve stuck in its travel as well. Hence the bent pushrods that can happen when two inches of metal try to fit into one inch of space.
    behindpropellers's Avatar
    NE Ohio
    6,781
    I'm fairly certain they are also making carbide lifters. I forget the company that has the STC.
    windy's Avatar
    Dec 2005
    Utah
    671
    The spalling is on cylinder #1 intake & exhaust lobes and one of the cylinder #2 lobes (the exhaust, I think). Interestingly, cylinder #1 was the only cylinder that never had any sticking valves.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    979
    The hardened lifters I used in a 360 were from LyCon. I think they called them diamond coated, they are said to keep the cam clean and resistant to spalling. Not sure but I think they are made by Lycoming.
    2,096
    This is worth a read on valves, guides, and CHT temps: https://www.supercub.org/forum/showt...coming-Engines
    2,096
    Adding a preoiler pump to the lube system can bring up pressure before starts. I had one on a PA-12-180 and there was no delay in indicated system pressure on startup.
    Edit: It also had the drilled cam STC mod to let some oil out on the lobes.
    And: Straight weight oils can stick around longer while sitting. I did a test on a bare piece of steel outdoors one summer. Shell 15-50, Shell 50W, and 20-50XC. The 50W was the last to leave the surface exposed to sun and rain.
    Likes algonquin, DENNY liked this post
    G44's Avatar
    Oct 2011
    SW Michigan
    513
    Which oil was the first? My guess would be the 15-50. Right? Wrong?
    Kurt
    2,096
    Kurt
    Yes the 15W-50 went soon after application and rust formed within a month. That was the earlier formula. Later they added the Lyc anti-scuff or whatever else to fortify the product and I redid the test later. Same results. 1st to go 15W-50, then the 20W-50XC, last was the older white can 50W but not the current updated Aeroshell W100, or even better yet their W80 or W100 plus with even better anti-wear and corrosion add packs. I have no interest in Shell products-disclaimer.
    Base was my 500 gallon fuel tank. I sanded off the side coating to bare steel and cleaned with alcohol. I then applied an equal amount of the three oils about one ounce from a shot glass and let them run down the tank's side. The 15W-50 ran the fastest and furthest, followed by the 20W-50, and last the aeroshell 100. The 100 never rusted much and the 20W-50 was also better than the early 15W-50. Temps were Fairbanks summer and it rained. Lasted over two months and by winter the straight 50W was still holding hands with the steel and had flies stuck to it. The rest were gone.
    Thanks G44, skywagon8a, 8GCBC thanked for this post
    Likes G44, skywagon8a, 8GCBC, FdxLou liked this post
    2,096
    This is not another oil thread in respect for the OP's problems. But recall that these engines were certified on straight weight 30-50 oils un-compounded without additives or not later when ashless dispersants were available. Then the magical world of multi-vis oils were then offered and whatever changed as far as wear patterns blew out like a sneeze. A history of cylinder and valve wear over the span of the available lubes would inform. I use what was offered back when they were developed and certified.
    10,001
    This is telling us that the stuck valves and potential hammering was not the cause of the cam failure.
    Likes DENNY liked this post
    2,096
    Robinson R-22 and R-44's have a rigorous inspection protocol. That includes the valves. If interested go search when and why. They are aware of potential problems and how to diagnose and hopefully prevent. Example: http://www.covehelicopter.com/robins...d-maintenance/
    Jan 2016
    31
    Did Aviation oils back then contain any Zinc?
    I know they quit using zinc in today’s car oils (epa), so a lot of these classic cars, older vehicles, and race engines would ruin there cam shafts from lack of zinc, especially fresh rebuilt engines. So now they make a “zinc rich” oil specially blended for these cars.
    Vermont
    306
    There's zinc and also the detergency issue. Multi-vis oils tend to have detergents added, the purpose is to carry crud to the paper-element filter. No paper filter, no hi-detergent oils allowed. You're strirring it up and circulating it.
    What's a go-around?
    10,821
    It's a disservice to the engine manufacturers, Lycoming in this case to suggest that they haven't improved their engines since they were first certificated.
    Do you seriously believe that Lycoming isn't aware of the changes and improvements in lubricants over the decades? These engines have in fact changed significantly in many ways most of us will never know over the years.
    And, that's not to suggest that every one of those changes has been a stellar success....
    But, believe me, Lycoming is well aware of the additives in modern oils.
    2,096
    Ash from detergents, antiwear additives, and combustion byproducts can form and promote piston ring and valve sticking in some engines. Antiwear zinc was tried and discarded in one aviation oil as it allegedly caused problems according to some feedback from users. There's aftermarket additive products available that claim antiwear anticorrosion properties with minimal ill effects. And the point about detergents and filters liking each other is true.
    As far as factory improvements as Mike notes I suspect that's true, but the potential issue for valve wear and/or sticking remains (or Robinson's maintenance schedule in #34 wouldn't be as rigorous). Surface coatings like nickel, chrome, valve rotators, added supplies of cooling oil can help if the engine or components are modern in design. But for some of us flying ancient engines (small Continentals) there's only a few options for improvement like ECI implemented before they left the building.
    High localized cylinder heat is an enemy that can be both detected and observed...CHT/EGT/oil temp and pressure/surface paint discoloration/borescope exams/...all can build a case for proper air/fuel delivery with sufficient cooling oil to the valve train and airflow over the cylinders. And even then if the cam and lifters spall or valves stick who is to blame despite the operators best efforts to prevent?
    9,268
    Very good point Mike! What is funny is how many aviation folks keep thinking that utilizing all the new electronics and such would be a great improvement in engines... while the working owner/operators with big diesels tend to curse all the new engine 'improvements'. There are fishermen looking for older engines to install in their boats after having brand new engines 'code' a problem and shift to limp mode forcing a return to port in a time critical fishery. Stories of this happening to multiple engines, and multiple times to the same engine reinforces the need for simplicity in my aircraft.
    And Windy, misery loves company. My engine has been red tagged due to the camshaft. Life is not easy all the time.
    10,821
    Another point: Back when Continental discovered a bad batch of crankshafts in their big engines, some resulting in accidents, I ran into Paul McBride, Tech Rep for Lycoming, and congratulated him on dodging that bullet. He smiled and said “Actually, we didn’t”. Turns out there was only one foundry in existence that made crankshaft blanks for aircraft engines. They produced ALL the crank blanks for Continental and Lycoming. Lycoming lucked out in that none of the “bad” cranks in their engines had been sold to customers before Continental discovered the problem, and Lyc recalled all the engines.
    Which begs the question: How many outfits out there making cam blanks, valves, etc for these engines?
    This was precisely the problem Frank Robinson encountered early in his helicopter business: outsourcing parts, in his case rotor blades. He fixed that by taking everything back in house except engines. Paul McBride told me that when Frank called Lycoming, things got done, since he was the biggest user of their engines.
    But some of this stuff makes one ponder manufacturing defects on outsourced parts....
  1. FS: 0-200 626608 Camshaft & 530535 Camshaft Gear For Sale
    By fabricman in forum Parts and Pieces
    Last Post: 12-22-2018, 10:58 PM
  2. Reground camshaft? Educate me please
    By skukum12 in forum Cafe Supercub
    Last Post: 01-26-2016, 09:18 AM
  3. Yellow tagged camshaft or new
    By PA-22/20-160 in forum Cafe Supercub
    Last Post: 03-11-2014, 11:22 AM
  4. O-235 Camshaft
    By wyndzer in forum Cafe Supercub
    Last Post: 01-15-2013, 02:22 PM
