Results 1 to 23 of 23
Thread: Dakota Cub adjustable brake rod assembly?
    Jul 2014
    16
    https://dakotacub.com/index.php?rout...product_id=200
    Has anyone used these from Dakota Cub? Just looking for an opinion them. I was thinking to try them to see if taking out the slack helps with braking....before I go ahead with a brake booster kit. I have 26's on my plane and the breaks struggle to hold the plane back when I do a run up at 1800 rpm.
    Thanks for input.
    1,982
    Have you tried doing the runup from the back seat? That would take the front linkage and pedals out of the equation.
    Jul 2014
    16
    Thanks I'll give that a go when I get it out of the barn for the first time this spring...should be soon.
    Jul 2012
    Montana
    437
    I have them and like them
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    158
    Just put them in my 18A along with the AA / North River brake boosters. Love them. Work really good. I had to replace my brake pedals and decided to install them instead of the steel rods from Univair.
    RaisedByWolves's Avatar
    Feb 2005
    4,009
    Sometimes the front pedals get bent from soft brakes and pushing hard. Check them too. Iíve put the dca rods in a few and the master cyl kits in a bunch of airplanes.
    Jul 2006
    AK
    77
    I put the Dakota brake rods in last fall and like them. I am more careful about not stepping on them getting in and out because they are spendy. If your brakes arenít holding I donít think the Dakota rods will fix the problem.
    Likes DENNY, mike mcs repair liked this post
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,953
    Try pre-charging the system through the bleeder ports. Works great.
    Jul 2014
    16
    Sometimes the front pedals get bent from soft brakes and pushing hard. Check them too. I’ve put the dca rods in a few and the master cyl kits in a bunch of airplanes.
    thanks ill have a look at that too. which master cylinder kit do you recommend?
    Nov 2015
    Pelham NH
    175
    Peter, We just finished putting Dakota Cub High pressure masters in my SC. As you know I had no brakes if any. Now with the masters changed and the adjustable rods the plane does not move all the way up to full static run up. Thanks Tom for the advise. Pete if you want to try the difference contact me and we can meet. Chip
    Nov 2015
    Pelham NH
    175
    farm_boy252,
    I read the thread to fast and thought you were the other farm boy (NY). Sorry
    Jul 2014
    16
    Quote Originally Posted by Chip D View Post
    farm_boy252,
    all good! I'm a long way from NY too, NWT Canada lol.
    Just to update the from the rear - the brakes hold on run up, the front pedals don't look bent....so for now I ordered the adjustable rods. I suspect I will still order the booster kit and install at next annual. Does anyone know do the lower brake lines need to be changed too? I see cubcrafters kit comes with the main high pressure lines.
    Nov 2015
    Pelham NH
    175
    Raised by wolves can give you a better idea of what was needed to do mine. I have single piston clevelands on my 95.
    10,085
    Quote Originally Posted by farm_boy252 View Post
    Do you still have the original type flexible brake hoses? They were designed for low pressure. The original master cylinders only put out 350 psi. As a result when you push more pressure through those hoses they swell up instead of applying brakes. Change your hoses to the high pressure type with reinforcement. Doing just this will direct all of the brake fluid to the brakes rather than just swelling up the hoses. This alone will help.
    Likes 39-J3, DENNY liked this post
    cubdrvr's Avatar
    Jan 2002
    1,161
    Cut and thread some old tailfeather flying wires.......did mine years ago.
    Likes DENNY, RaisedByWolves liked this post
    Jul 2014
    16
    Thanks for the tip. do you have any leads on where to get the hoses? I think I saw on Univar they were like 160 a piece!
    1,982
    local hydraulics shop can usually make whatever length you need.
    3,024
    Just make sure they use AN fittings and not automotive.
    Likes DENNY liked this post
    10,085
    Where are you in NWT? Near any big town where they can supply you with hose? Is there an aircraft maintenance shop where they can make up some hoses for you? The original hose had no fabric reinforcement in the hose, just a plain rubber hose which was crimped to a fitting. New ones can leak at the crimp. Most any hose with embedded woven reinforcement will be capable of the higher pressure.
    Web's mention of AN fittings is the best. Whatever you use it must match up with what you have. The original was just a commercial fitting to a copper tube with 1/8" pipe at the master cylinder..
    Jul 2014
    16
    I'm in Norman wells so no such luck with that...
    Just saw this posting now and already went ahead with ordering parts. I ended up getting the adjustable break rods from Dakota cub and the brake booster kit from cubcrafters....which also came with the brake lines. Looking forward to seeing how it all pans out. I ended up talking to my AME (busy and hard guy to get on the phone) and his opinion was this - the cubcrafters or north river boosters are the easiest to install, but the Dakota ones are the best - and worth while installing if its at the time of a total airplane rebuild.
    Nov 2015
    Pelham NH
    175
    The reason I could go with the Dakota Cub High pressure master cylinders is that I have a metal belly pan and it made it easy to install. I have been out a few times with them and stopping is great. Good luck with your new set up, it is nice to have good brakes.
    krines's Avatar
    Feb 2012
    Billings
    63
    Installed Dakota Cub high pressure masters on mine. Requires making 2 small holes in the fabric to get a wrench in as I recall. Simple little patches to the fabric then.
    Likes Rotormech liked this post
    19,488
    I would return the Cub Crafters boosters. If your mechanic is concerned with the ease of installation get Steve's Brakes. They bolt on like the Cub Crafters but are vented and don't require adding and taking away fluid to have good brakes. Ask anyone here who has had the sealed brakes and they will complain about having to service them quite often. Not that big a deal to put holes in for the Dakota Cub master cylinders either.
    Likes MT12 liked this post
  1. WTB: Wanted: brake pedal assembly parts for my 18...
    By daedgerton in forum Parts and Pieces
    Last Post: 12-31-2019, 10:48 PM
  2. Brake pedal assembly
    By Farmboy in forum Super Cub Sick Bay
    Last Post: 04-12-2019, 05:40 PM
  3. Accessing the forward brake assembly levers
    By Jacob Papp in forum Super Cub Repair Facilities
    Last Post: 06-08-2003, 05:51 PM
