Masking tape and a razor blade when dry.I think the silicon might be a bit messy when tighten down.
I used AN525 washer head #8 screws with rivnuts. Single piece of Lexan bent in a brake. Used some foam padding between the frame and Lexan and where the Lexan overlaps the fuselage. Also a strip of aluminum at the front edge. If I did it again I would probably do aluminum trim all the way around the perimeter painted to match the fuselage.
It looks hinged on the front? I've pondering doing that instead of on top. Still not sure which I want. How do you like it?
What ever you do. Do not use lock tite to try and keep the screws lose. The lock tite will crack the glass. And continue to crack even when you walk away.
I learned this the expensive way. Thanks for confirmation of why... seemed like a great idea at the time .....
