Flaugherpa12
I recently noticed on a PA 22/20 that the engine was offsite approximately 2 inches to the right when measuring from the leading edge of the wing to the centerline of the prop in the horizontal position.
My question is what is that same offsite for a PA12 with an 0320?
Is the prop in perpendicular to leading edge of the wing and normal to the center line of the fuselage?
Or does this offsite change/increase when you increase horsepower due to P factor?
