RaisedByWolves
FRIEND
Tx
Almost sounds like it wasn't programmed. In a nutshell, was it programmed with aircraft info (length, width, weight) and set to nexnav GPS info? This should be all that's needed to turn it from a transponder into an ADS-B out unit.
Yes. Tried the other options for gps source as well. These were the settings supplied by trig
Switch OFF
Press and hold FN for 5 seconds while you power ON. (You should see a screen that says ‘Press ENT to enter setup menu’)
Press ENT
Use FN to skip pages, use the right hand knob to alter setting and ENT to select.
Set the following;
GPS Source: Nexnav
Baud rate: 19200
GPS Cert: Level C
NACV: 10
