Wag Aero vs Piper Heater box
Philly5G
England
I see the Wag Aero heater box has 3 connections: an inlet for the warm air from the Heat Shroud, one outlet to the cabin and another outlet to dump the warm air away from the cabin when the cabin heater/vent is switched off.
The Piper (PA-12) heater box has 4 "connections" an inlet for the warm air from the heat shroud, an inlet for cold air from a vent on the bottom of the lower cowl and an outlet to the cabin. Warm air is dumped away from the cabin when the heater is off, through a hole in the wall of the warm air inlet connection, which releases the warm air into the lower plenum area when the heater is off
Questions:
  • Which box is recommended when either are choices?
  • Does anyone use the Piper heater box for fresh/unheated air?
  • How "warm" is the air from the heat shroud via the box?
I have an original PA-12 box and based on the feedback to this question will either:
  • Connect it as per the Piper Parts book (although mount it to the firewall)
  • Modify it to just use 3 outlets as per the Wag Aero box
  • Buy a stainless steel Wag Aero box
I'm looking forward to the experiences and opinions :)
Thanks!!!
Use caution with Wag-Aero parts. Some are approved and some are not. They sell a lot of stuff to the experimental crowd. Sometimes it is difficult to determine whether the part they are selling is certificated for a particular airplane or not. Sometimes they imply that it is and it really isn't.
Thanks for this SkyWagon!! Any thoughts on the cold air connection stuff please? :)
