Results 1 to 6 of 6
Thread: Wag Aero vs Piper Heater box
    Jun 2018
    England
    404
    I see the Wag Aero heater box has 3 connections: an inlet for the warm air from the Heat Shroud, one outlet to the cabin and another outlet to dump the warm air away from the cabin when the cabin heater/vent is switched off.
    The Piper (PA-12) heater box has 4 "connections" an inlet for the warm air from the heat shroud, an inlet for cold air from a vent on the bottom of the lower cowl and an outlet to the cabin. Warm air is dumped away from the cabin when the heater is off, through a hole in the wall of the warm air inlet connection, which releases the warm air into the lower plenum area when the heater is off
    Questions:
    • Which box is recommended when either are choices?
    • Does anyone use the Piper heater box for fresh/unheated air?
    • How "warm" is the air from the heat shroud via the box?
    I have an original PA-12 box and based on the feedback to this question will either:
    • Connect it as per the Piper Parts book (although mount it to the firewall)
    • Modify it to just use 3 outlets as per the Wag Aero box
    • Buy a stainless steel Wag Aero box
    I'm looking forward to the experiences and opinions
    Thanks!!!
    Every day's a school day
    nd
    3,493
    i dont have one of these guys heat boxes but next time i will.http://www.aviacompinternational.com/heatboxes.html
    Jun 2018
    England
    404
    These are the ones Wag Aero sell and also Aircraft Spruce etc. They have the warm air in and out connections only, hence my question about the cold air connection on the Piper box? Is it just to provide another source of cool air into the cabin, or something else?
    9,982
    Use caution with Wag-Aero parts. Some are approved and some are not. They sell a lot of stuff to the experimental crowd. Sometimes it is difficult to determine whether the part they are selling is certificated for a particular airplane or not. Sometimes they imply that it is and it really isn't.
    Jun 2018
    England
    404
    Thanks for this SkyWagon!! Any thoughts on the cold air connection stuff please?
    9,982
    Sorry Phil, can't help with that.
  1. PA-12 Heater Box
    By evroosevelt in forum Cafe Supercub
    Last Post: 10-26-2015, 10:01 PM
  2. Heater Tricks
    By NunavutPA-12 in forum Modifications
    Last Post: 09-28-2009, 03:28 PM
