Results 1 to 8 of 8
Thread: L21 Windows and Skylight
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    184
    I see Atlee sells an STC to convert a standard D window fuselage to L21 glass and skylight. Is it really necessary to have an STC if it’s on the Type Certificate? Shouldn’t this be just a minor with a logbook entry?
    PA-12 N418BS
    2,796
    Yes. The STC is sometimes used as an easy way to be able to market an aircraft item.
    10,749
    I would think just log & 337 for welding
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    184
    That’s what I’m thinking as well. Not even really a minor because it’s on the Type Certificate. Maybe just “Welded new L21 windows per Piper Drawing xxx. All welding IAW 43.13 etc etc.... “
    PA-12 N418BS
    2,796
    Just make sure you talk to your IA. If he doesn't like it after you do the change, it's darn inconvenient to find another IA.
    6,952
    Talk to your IA first. If he/she doesn't like it, consider finding another IA. This one seems like a no-brainer.
    I have been known to insist on field approvals to put PA-11 parts on a J3, but L4 windows do not bother me in the least. The window configuration varies all over the place. We just reference the Piper drawing.
    Likes mike mcs repair, Southern Aero liked this post
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    184
    Not a problem. I sign the first block and have a friend sign the second. I probably should get my IA after 28 years. Just don’t do enough work to justify keeping it current.
    PA-12 N418BS
    9,748
    Quote Originally Posted by KJC View Post
    As long as you have your friend you are good. If not, all you need is to take one of the on-line recurrent courses. Simple.
  1. Skylight
    By jimboflying in forum Modifications
    Last Post: 07-24-2019, 04:23 AM
  2. Side Windows and Skylight
    By Jim Miller in forum Experimental Cubs
    Last Post: 08-05-2011, 06:51 PM
