In 1of my cubs has. Lot of slop in it from side to side any advice to make it tighter
Too bad you guys can't throw out that 1940's technology with something modern like this. Have it in my Cub and it is perfect--absolutely no slop.
http://fly2ak.com/PDF/PreciseFlight.pdf
You'll need to find out if the wear is on the bolt or in the bushings in the stub. I would just replace the bolt anyways while you're in there. If the bushings in the stub are worn the choices are; replace it, or build up the worn bushings. Replacing is self explanatory. Building up the bushings will mean either having them welded up and then reamed back to size OR reamed to a larger size and then press in bushings that will have the correct ID to hold the bolt. Going to have to be your call, but you should talk to your A&P before you decide.
