Results 1 to 17 of 17
Thread: Control stick play
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Control stick play
    In 1of my cubs has. Lot of slop in it from side to side any advice to make it tighter
    10,749
    Quote Originally Posted by skysigns View Post
    Shim stock on one side of bolt
    Or braze it up and team it back to size is better
    I wonder if anyone tried using the flap & aileron block STC’d repair there?? Same size hole....
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Thank u for the info
    2,796
    More info please. Is the play in the torque tube? In the bolt through the stick stub? Or just loose cables?
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Play in the stick not the cables
    2,796
    Ok. Is the play in the cross bolt that the stick stub rides on?
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Yes that is we’re the
    ay is
    2,796
    When you push the stick from side to side, does the bolt stay stationary as the stick moves? Or does the bolt AND the stick move?
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Not sure will check on it thanks
    tedwaltman1's Avatar
    Jul 2011
    Denver, CO
    410
    Too bad you guys can't throw out that 1940's technology with something modern like this. Have it in my Cub and it is perfect--absolutely no slop.
    http://fly2ak.com/PDF/PreciseFlight.pdf
    Likes Farmboy, RVBottomly liked this post
    RVBottomly's Avatar
    Sep 2017
    719
    Quote Originally Posted by tedwaltman1 View Post
    Perfect timing for me. I'm about ready to start working on my control assembly. I like that design.
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    345
    I replaced the bolt that goes to the ailerons and it was worn and beat up. added a washer and tightened, removed one spacer on the tube, then went to the front stick and the pivot bolt was rusty and worn, replaced that one and greased on assembly tightened as needed.
    Wow what a difference it made in the take up of the sloppy of the stick
    Doug
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Found the plat is in the stick stub
    2,796
    You'll need to find out if the wear is on the bolt or in the bushings in the stub. I would just replace the bolt anyways while you're in there. If the bushings in the stub are worn the choices are; replace it, or build up the worn bushings. Replacing is self explanatory. Building up the bushings will mean either having them welded up and then reamed back to size OR reamed to a larger size and then press in bushings that will have the correct ID to hold the bolt. Going to have to be your call, but you should talk to your A&P before you decide.
    10,749
    There’s no replaceable bushing there. It’s a welded tube.
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Thinking about replacing it with a nsa bolt
    2,796
    Nothing wrong with an NAS or close tolerance bolt for this. But do some checking to see if a new bolt will completely fill the bushing. If the bushing wear is minor, the new bolt will work well. If the wear is bad, the new bolt will help but not solve the issue.
  1. Pa 18 Control Stick
    By supergoose in forum Cafe Supercub
    Last Post: 01-02-2019, 10:30 PM
  2. Control stick?
    By n9843q in forum Member to Member
    Last Post: 11-30-2016, 11:15 AM
  3. Getting the top off the control stick
    By BritishCubBloke in forum Super Cub Sick Bay
    Last Post: 05-19-2003, 04:58 AM
