Results 1 to 9 of 9
Thread: Old U.S. Gauge Oil Pressure and Temp. Combo
    May 2019
    12
    Hi folks,
    I have some trouble with an U.S. Gauge Oil Pressure and Temperature indicator. Oil temp. never worked since we purchased the plane, the previous owner cut the capillary line and added an ugly VDO temp. instrument. Oil Pressure worked fine on our U.S. Gauge instrument.
    Since we wanted to clean up our panel and make a new one I sent the U.S.Gauge to the U.S. for a repair. Repair plus 2 times shipping (Germany to US and back) plus taxes...I ended up with a >400$ bill and waitet over 7 weeks. Then it came back with a new capillary.
    I was surprised that the temp unit showed nothing (below 40°F) when it was here in my desk because I thought it should show room temperature. I contacted the guys who took my money and they said it has to be in the airplane to show the correct temperature...Well I installed it and took it for a flight, it still shows nothing. I'm a bit pissed at this point.
    The repair guys told me that it may have been shaken to much during shipping so it's calibration is way off and I have to send it back. Of course I am not very interested in having another 7 weeks downtime. Is it possible to calibrate it by ourself? Is this whole shipping bounced the calibration off scenario realistic?
    Thanks in advance
    Patric
    supercub's Avatar
    Apr 2002
    816
    Keystone Instruments in Lock Haven rebuilt that instrument for me a few months ago. So I know they can do it. They could probably answer your question regarding calibrating it yourself. Mine registered room temp without being installed too. Good Luck.
    behindpropellers's Avatar
    NE Ohio
    6,771
    I'm curious who repaired it?
    May 2019
    12
    I don't know who repaired it...I sent it to Wagaero and they sent it to somebody they work with. My only contact was with Wagaero
    Thanks bowenjo thanked for this post
    19,227
    Mine gets shakin' quite a bit being flown by me and it keeps working. I would keep after them to make it right. These people have always done me a good job. http://antiqueinstrument.com/
    Jul 2010
    Elizabeth, WV
    559
    A quick check is to put the bulb in boiling water and see if the gauge reads close to 212F. Test works if the gauge is in the plane or on the work table. I check them before installation to save a few cusswords.
    May 2019
    12
    Quote Originally Posted by N86250 View Post
    I tried that when I got it back...it showed nothing, the needle didn't move. I asked wagaero if thats normal, they answered that is has to be connected to the engine...didn't make sense to me but I tried it....nothing.
    NE Ohio
    6,771
    Quote Originally Posted by Patric_L View Post
    I would get my money back from Wagaero and send it to antique instrument.
    Jan 2017
    Utah/Alaska
    96
    capillary tube probably has a leak, they are filled with all sorts of temperature sensitive chemicals like Tricholoroethelene or ether which are nasty. No option to repair yourself. Good luck, Tim
  1. Looking for a Oil pressure/oil temp combo gauge.
    By supercub in forum Parts and Pieces
    Last Post: 11-01-2018, 11:18 AM
  2. Oil pressure/Oil Temp combo gauges
    By Jim Miller in forum Experimental Cubs
    Last Post: 12-04-2017, 12:09 AM
