Thanks Thanks:  0
Results 1 to 5 of 5
Thread: Seat belt/shoulder harness attach bolt size?
    supercub's Avatar
    Apr 2002
    806
    What's the recommended bolt size to attach seat belts to the frame? I just bought new seat belt and shoulder harness's and the mount holes on the hardware are 3/8 inch. The mounts on the air frame are 5/16 inch. Should I make a bushing, or drill out the air frame fittings to 3/8 inch? What is typically done. Thanks
    2,685
    Normally have a small bushing that allows the seat belt triangle to swivel some. Each bushing should be slightly thicker than the piece it holds. And use a large enough washer under the head of the bolt to keep the triangle from slipping off.
    Also, think about welding a nut onto the back of the tab itself. This lets you install and remove the seat belts with just a socket wrench.
    10,675
    small bolts are fine with a bushing...
    if you break the small bolt with your body in a crash, you won't be around anymore anyway.....
    Minimum tensile strength 125,000 PSI
    125000/16 * 5 = 39062.5 Lbs
    thats probably not the right math.. but you get the idea...
    3,468
    For a 1/4" bolt - pi*.125^2 * 125,000 for double shear. Less than half that for simple shear because bending is also involved. I agree with Mike's conclusion - - -
    Likes mike mcs repair, CubCruiser liked this post
    Jan 2017
    Utah/Alaska
    84
    I went to the IA seminar in Anchorage many years ago, the did a speal on seat belts. There is a difference in auto vs. airplane belts, auto are designed to reduce the injury whereas an airplane is supposed to contain the body.
    Likes jimboflying liked this post
  1. WTB Lap Belt/Shoulder Harness
    By Hendoii in forum Parts and Pieces
    Last Post: 01-13-2019, 08:28 PM
  2. shoulder harness seat belt install minor alteration
    By montague in forum Cafe Supercub
    Last Post: 08-19-2008, 10:46 PM
  3. Remavable Rear Seat Crossbar and Pilot Seat Belt Attach
    Last Post: 03-10-2008, 06:23 PM
