Results 1 to 18 of 18
Thread: Proposed 0-360 Superior Air Parts Crank AD
    behindpropellers's Avatar
    NE Ohio
    6,771
    Mar 2016
    1,235
    Wow, I am sure that is not the right word.
    Curious in that so far I have not seen any problems with the Continental-Titan built engines. I have felt they might be better but could well be wrong.
    6,952
    Looks like a small percentage of the total out there. Haven't we seen about four ADs like this? My crank has a 25 hr. inspection regime.
    10,748
    https://www.avweb.com/aviation-news/...ankshaft-nprm/
    AkPA/18's Avatar
    Big Lake Ak
    683
    Thanks Mike,
    It appears mine was manufactured just prior but in the same year. Really hope they don't expand part numbers and gather me up.Safe for now.
    Would like to know if these are solid or hollow cranks. I missed it if said.
    http://thrustline.com/
    nanook's Avatar
    Aug 2002
    northern alaska
    1,679
    So when figuring out the whole cost basis for replacing these cranks, they state that they didn’t include 77 experimental installations? Am I reading this right?
    Likes jrussl, mike mcs repair liked this post
    Mar 2016
    1,235
    Quote Originally Posted by nanook View Post
    Yup
    5,092
    It's interesting that they say the AD isn't applicable to the experimentals. That's contrary to what my DAR told me (in no uncertain terms) and subsequently what the FAA guys told me during my repairman interview. ADs on certified parts do apply to experimental installations is what I was made to understand.
    Likes mike mcs repair, CharlieN liked this post
    nanook's Avatar
    Aug 2002
    northern alaska
    1,679
    Yeah I’m not sure what the message is that the FAA is sending by excluding experimental installations? It’s either OK by them that your crank fails or the cost of replacing the crank isn’t important to them. Bit of a head scratcher there...
    Likes CharlieN, mike mcs repair liked this post
    Mar 2016
    1,235
    To me if you pay $10K for a crankshaft and it turns out it can kill you. It should not matter what plane's engine it was installed in.
    If an EX crankshaft is half the money because you are not obligated to pay for the cert, it should still be warranted by the manufacturer. But they are not half the money.
    If detonation is causing failures which sounds like a scapegoat, maybe it is time to actually put an hour or two of R&D into these engines which has not been done in 50 years.
    5,092
    The FAA document specifically identifies a materials problem. That's not the same as what the 400 recall was about, at least that's not what they told us, and the NTSB report on the fatality IO-400 accident indicated detonation, not crank material failure.
    Superior did right by 100+ exp engine owners with the 382/400 recall. I wouldn't panic too much about this until it all settles out.
    If memory serves the last Lycoming crank recall affected 3800 engines. I never heard how many Continental had to replace. This isn't an unprecedented problem.
    Mar 2016
    1,235
    Yes but will Lycoming?
    I have a curiosity who Continental sources it's "Lycoming" cranks from now?
    Thanks windy thanked for this post
    5,092
    Will Lycoming what?
    Mar 2016
    1,235
    Will Lycoming what?
    Sorry for the delay, power has been out the past 8 Hrs,
    Will Lycoming stand behind the EX cranks or as they have done to many time recently to make the owners pay for the exchange.
    5,092
    Lycoming doesn't use Superior's cranks in their engines. These cranks would be in Superior's engines or in engines overhauled by others using a Superior crank.
    I'm pretty sure Lycoming paid for replacement when their crank problem happened. When it happened to my 180 Continental paid for the crank replacement parts and labor. Hopefully Superior helps those affected by this AD. Time will tell.
    Mar 2016
    1,235
    Then what does this first sentance from the AD proposal state,
    The FAA proposes to adopt a new airworthiness directive (AD) for all SAP Model IO-360-series and O-360-series reciprocating engines and certain Lycoming Engines (Lycoming) Model AEIO-360-, IO-360-, and O-360-series reciprocating engines with a certain SAP crankshaft assembly installed.
    5,092
    I interpret that to mean Lycoming engines included in Superior's AML that may have had replacement cranks installed. From the FAA document-
    These SAP crankshaft assemblies are installed as original equipment on SAP Model IO-360-series and O-360-series reciprocating engines and as a replacement part under PMA on certain Lycoming Model AEIO-360-, IO-360-, and O-360-series reciprocating engines.
    Likes mike mcs repair, AkPA/18 liked this post
    n40ff's Avatar
    Oct 2009
    WV
    936
    Ditto. That is exactly what I was also told by the FAA guy when I got my repairman.
  1. Superior Air Parts Free Book Offer
    By stewartb in forum Tips and Tricks
    Last Post: 08-14-2017, 04:24 PM
  2. Superior Air Parts in trouble
    By bowhunter in forum Cafe Supercub
    Last Post: 01-16-2009, 11:09 AM
  3. Need 24 hour reply - O-360 with hollow crank or solid crank?
    By GeneHerzog in forum Super Cub Sick Bay
    Last Post: 08-21-2006, 09:06 PM
