Results 1 to 21 of 21
Thread: Vintage Oil Temgerature Gauge?
    Sep 2015
    7
    I have a 1946 PA12. We just took an old, mechanical oil pressure gauge off of it because the probe has broken from the cable. The gauge is a 2 1/4 inch round U.S. Gauge Part AW1820AG01 apparently manufactured in the 40's. The casing for the gauge appears solid, not easy (possible?) to attach a new chord. Any suggestions? Vintage parts suppliers? My preference would be to replace it with another same part if I could find it. Google search yields nill.
    nd
    3,468
    when i broke mine i just replaced with one of these.https://www.aircraftspruce.com/catal...clickkey=10158 theres guys that can fix them, but not cheap. might have to make a adapter ring or buy one but thats easy, and these do work good.
    Thanks Flying Rev thanked for this post
    behindpropellers's Avatar
    NE Ohio
    6,772
    John Wolff Co will repair it.
    55-PA18A's Avatar
    Dillingham, Alaska
    624
    Is your original gauge a dual pressure/temp gauge, or just pressure? If you order a new gauge, make sure the threads will work on the sensor tubing. Search this forum for info on that problem.
    I ordered a new gauge and decided I didn't want to use it when I saw it was made in China. Don't know if the threads worked or not. I then sent the original gauge off to John Wolf and Co. It was expensive, but it was overhauled including new pressure sensor tube and temp cable, and the face repainted as original with the correct temp/pressure markings. It also got rid of that aggravating wiggle in the oil pressure needle.
    Jim
    Likes mike mcs repair, AkPA/18 liked this post
    AkPA/18's Avatar
    Big Lake Ak
    683
    http://antiqueinstrument.com
    Jim, Sounds like You had a lot of work done on yours. I had him repair the Bouncing needle when it went to a permanent hundred pound Oil pressure. That was a pretty reasonable bill. He does great work really knows what he is doing. He will do anything from a full-on restoration to just a repair. He was timely also
    If you can't tell I'm a big fan.
    http://thrustline.com/
    Thanks mike mcs repair, windy thanked for this post
    19,247
    Been using John Wolf Company for repairs for many years. Great service.
    Likes Flying Rev liked this post
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    636
    2,827
    LOL!
    Two thumbs up!
    2,944
    EI webpage sez this is a approved as primary gauge.
    I'm surprised, I'd think it would have to display both pressure & temp readings at the same time.
    That was my takeaway from reading up on EI's info re which primary gauges the CGR30 can replace.
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    742
    They’re both approximated real-time by the LED bars on the left and right. The specific number is selectable, but you’ve got current green/yellow/red indications at all times.
    Jan 2008
    Arlington, WA
    636
    It’s what I had in my 180 as a primary gauge. They’re relatively cheap.
    2,944
    Quote Originally Posted by CamTom12 View Post
    I didn't pick up on the arc of little led's on either side.
    Thanks for the tutorial.
    That's a pretty slick way to do it.
    I had an EI digital cht/egt in my first airplane.
    Hard to read as the number display constantly flickered up & down by a few degrees.
    Jan 2008
    Arlington, WA
    636
    It's a pretty good unit! I've put it in both of the Pawnee's I maintain.
    2,827
    As a general rule, E.I. gauges (except for the bar graph monitors) are certified for primary use.
    NE Ohio
    6,772
    The bourdon tube oil temp/pressure gauge will still be kicking when your electronic gadgets stop....
    2,827
    His didn't
    nd
    3,468
    most broken bourbon tubes are pilot induced.
    19,247
    Actually maintenance induced.
    nd
    3,468
    usually maintenance guys know better.
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    Steve do u have his info I have sets to send in
    19,247
    Quote Originally Posted by skysigns View Post
    What Mark posted. http://antiqueinstrument.com
  1. Vintage Airplane DER
    By d.grimm in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 10-13-2014, 03:19 PM
  2. Vintage Supercub Ads
    By j5mike in forum Cafe Supercub
    Last Post: 09-10-2014, 05:52 AM
  3. Vintage old Alaska photo
    By Christina Young in forum Cafe Supercub
    Last Post: 01-04-2007, 07:02 PM
