Results 1 to 17 of 17
Thread: Pa18 hd gear
    Jul 2009
    13
    Pa18 hd gear
    What's the pro and cons of airframes vs atlee hd landing gear?
    5,091
    I've had both. They're equals to me. Atlee was better for adding welded ski fittings.
    My exp has Airframes Super Duty gear. With 35s the welded in mid step is more useful than I would have thought. I also have a long step but it's too high to reach from the ground.
    19,226
    Atlee gear is aligned correctly, unless Airframes has recently changed their jigs theirs is not. Attach fittings and axle alignment. Through my conversation with the CEO at the time (July) Airframes was working on some issues with their welded parts.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,908
    My Atlee 3" extended is perfect. It sits with just a touch of positive camber, and the toe is apparently correct based on tire wear.
    6,952
    Heavy Super Cub on 6:00x6s, used only on pavement for student training. What do you guys think of stock gear legs while I recover the HD legs?
    This one is 1200 empty, almost - in part because the previous owner needed every heavy mod he could get his hands on. All my stock gear legs have the 1/2" square tube welded in, but we use them mostly for J3s.
    Thanks hman442 thanked for this post
    6,952
    By the way, we measure toe by simply taking measurements front to back on the tire ridges. Zero is best, but the aircraft tolerates a half inch difference (toe in) on 8:00x6 or 4.
    3/4" toe in seems to make landing a bit more exciting . . .
    3,505
    Perfect. Good visibility over the nose, and a little lower CG for those inevitable excursions.
    6,952
    I think HD comes in stock length? I will measure today.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,908
    Even 1/2" is a LOT on a tire of that diameter.
    RaisedByWolves's Avatar
    Feb 2005
    3,927
    Sure would be nice if they add some brackets for the brake lines on the gear, you know like piper and everyone else does.
    19,226
    Who's gear doesn't have brackets for the brake lines?
    Feb 2005
    3,927
    Airframes, and they came powdercoated so i didn't want to weld some on. Ended up using adel clamps, but the welded on clips look much cleaner on uncovered gear. I didn't notice the lack of brackets until the gear was on and i was running the lines
    5,091
    Wen I bought Atlee gear the brake line tabs were right in the way of the long step. They made me a custom long step to get around it. My Airframes gear has no tabs and I'm glad. They wouldn't have fit my brake lines.
    19,226
    Didn't realize Airframes had no brake line tabs.
    Dec 2016
    Canyon, tx
    499
    What brake lines did you run?
    5,091
    Stratoflex 111.
    1,880
    Airframes will do tabs if you want.
  1. PA18 Gear on a 12
    By streetreamer in forum Cafe Supercub
    Last Post: 09-21-2015, 08:52 PM
  2. J4 gear versus pa18 gear
    By Floatin_around in forum Modifications
    Last Post: 03-14-2007, 10:15 AM
  3. PA18 Gear leg length
    By Propeye in forum Cafe Supercub
    Last Post: 04-10-2004, 05:54 PM
