Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
Thread: Borer prop benefits pros/cons
  1. #41
    10,490
    I understand that point and wouldn't disagree.
    I just would like an honest/direct answer because in person across a picnic table at the 2013 New Holstein Pig Roast, Craig told me they were working on it and it was two, maybe three years away.
    The good news in now there are several certified alternates really in the works.
    Perhaps since 2013 he changed his mind? In my reading of the certification requirements, it certainly doesn't appear to be very difficult to accomplish. Particularly for a wood core prop. Maybe he had a chat with his insurance agent?
  2. #42
    Meanwhile,...
    5,286
    I should have noted that since then I and others have called and stopped in their booth at OSH but I gave up 3 years ago.
  3. #43
    19,917
    I spoke with them recently. They put it on hold to do a big project for Boeing and one for NASA I believe. I can guarantee those paid better and created more of a fun challenge than certifying a prop with the FAA.
    Thanks OLDCROWE thanked for this post
  4. #44
    3,183
    Getting anything accomplished with the FAA is difficult-- just ask Boeing re 737 Max.
    Try doing something simple like just getting a replacement airworthiness certificate sometime from a less-than-helpful FSDO rep,
    maybe it'll give you a different perspective.
    Somebody I know watched Bushwheel Bill's video about the QMI hockey-stick-repair kit,
    "wow, three thousand bucks seems like a lot".
    Considering the horror stories I've heard from people trying to get an STC or any other kind of FAA multiple-airplane approval,
    or even just a one-time field approval, $3K sounds very reasonable.
    Likes RaisedByWolves, OLDCROWE liked this post
  5. #45
    RaisedByWolves's Avatar
    Feb 2005
    4,126
    "wow, two thousand bucks seems like a lot".
    or even just a one-time field approval, $2K sounds very reasonable.
    I haven't done one but i'd imagine it would be labor intensive to replace the stringer. 2 guys needed to rivet, then touch up paint work on the fuselage, vs bills it seems like a one man job
    Likes OLDCROWE, Djfly liked this post
  6. #46
    Penguin's Avatar
    Jul 2012
    KFLY
    92
    Has anyone purchased a Borer in the last year or so? If so, can you verify the paint pattern of a factory new one? 2x 2" stripes? Or the fat stripe with the 1/2" below it. Mccauley doesn't seem concerned with my queries.
  7. #47
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    721
    About a year oldClick image for larger version.
    Thanks mydoghasa170 thanked for this post
  8. #48
    Dec 2016
    Canyon, tx
    596
    Catto would know. They paint a few with that same scheme.
  9. #49
    Binty's Avatar
    Jan 2005
    South Island, New Zealand
    381
    Anyone running a 84/43 Borer ?? on a 150?? Whats it like? Is this too much. Whats involved in cutting down to 82.
    If you force it, it will fit
  10. #50
    10,490
    An old rough rule of thumb: adding one inch of pitch is equivalent to subtracting one inch of diameter and vice versa. So, cutting an 84/43 to 82 without changing the pitch should give roughly the same performance as an 82/45. Sounds like an intermediate to cruise prop to me.
    For an example I've used an 80/46 with good performance results. Using the above rule of thumb with your 84/43 cutting to an 80 would give you an 80/47 equivalent.
    Cutting is basically a hacksaw, file smooth and balance.
  11. #51
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,985
    That's going to be too much prop for a 150. For a standard/stock 150 hp O-320 an 82/42 is about all it wants to swing.
    Likes Oliver, BC12D-4-85 liked this post
  12. #52
    Dec 2016
    Canyon, tx
    596
    Quote Originally Posted by Binty View Post
    Is there an 84” McCauley that bolts on a -320?
    Thanks Brandsman thanked for this post
  13. #53
    Meanwhile,...
    5,286
    I run an 82x 43 on a 160hp, runs good likely only loose a few RPM in climb and won't over-rev as quick ( one learns to pull it back as you're leveling off). I've heard rumor they can be cut down below 82 in a pinch, call a prop shop for 84" cut down options.
    What else ya need?
  14. #54
    10,490
    The 1A175GM which is the "Borer" prop, is approved by the Type Certificate P-857 on the 0-320 series up to 160 hp at a diameter of 78"-82".
    Why would you want more than 82"? That does a good job.
  15. #55
    Jan 2005
    Fowler, Ks
    584
    i run a 82/41 on my 150 hp 18. Its static is 2425 and climbs at 2550
    It will exceed reline (2700) flat out at 3000 msl
    Seems perfect for my wants. Pitch is prop shop verified
  16. #56
    Dec 2016
    Canyon, tx
    596
    Pete,
    I think you misinterpreted my question. I’ve never heard of an 84” Borer and was making sure it was a typo and not something I’ve missed. I’ve heard guys talk about Pawnee props on cubs but not an 84” Borer.
    That said, I’ll take an 84” Catto over an 82” if my mission is stump pulling. This is an apples to oranges argument when comparing Cattos to McCauleys so I won’t waste much time. If there was an 84” Borer you can bet I’d try it if it didn’t cost as much as gold and weigh more!
  17. #57
    19,917
    My 150 hp 320 swung an 8243 just fine.
  18. #58
    10,490
    Kevin, I've heard this talk too. They may use what they wish, I tend to look at the type certificate and found some diameter vibration limitations with that prop which suggest it is not a good idea. Perhaps it is just a matter of what official testing was done?
  19. #59
    Jun 2006
    Alaska
    364
    Quote Originally Posted by J3Jim View Post
    Hey guys,
    I need an education on borer props and the benefits on a Pa-18-150. Is there a big ROC increase? What are measurable performance benefits?
    I know nothing about them. I’m also curious as to the prop clearance issues as i understand owners will add gear leg extensions or larger tires for prop clearance. And is it all worth it for a grass strip flyer!
    Thank you I appreciate it!
    Looks to me like it was worth it. Ought to be able do all those mods for less than $15k too.
    Catch the fish, to make the money, to buy the bread, to gather the strength, to catch the fish...
  1. Airstrip Registration, Pros and Cons
    By Jacob Papp in forum Cafe Supercub
    Last Post: 08-13-2016, 06:00 AM
  2. Jackscrew Vs. Trim Tab Pros and cons?
    By pipercubnut in forum Modifications
    Last Post: 05-03-2010, 10:09 AM
  3. Widebody Pros and cons
    By Jeff in forum Cafe Supercub
    Last Post: 02-18-2007, 02:59 PM
