Page 1 of 2 12 LastLast
Results 1 to 40 of 72
Thread: PA-12 cabin heater box and other firewall forward jobs :)
    Jun 2018
    England
    388
    Cool PA-12 cabin heater box and other firewall forward jobs :)
    I'm about to start on the removal of the old O235-C and fitting of the new O235-C2C engine in my 12 and will be doing a number of fixes and upgrades whilst the original engine is out. I would appreciate feedback on any and all of the following please
    1. The exhaust muffler looks like it's either for another aircraft or it's been fitted upside down, as the port that looks like it should go to the heater box is pointing down and straight onto some metalwork below, can anybody please post a pic of their 12 muffler, preferably connected to a heater box, so I can see what the arrangement SHOULD look like? I'd also really appreciate a pic of a 12 heater box, as there was something that looks like a heater box which I found in the storage bag behind the rear seat when I bought the aircraft, but I'm not 100% sure
    2. Although all the baffles appear to be there, a lot of them have very big holes and gaps in them, particularly the rear top one. Should the baffles sit tight against the engine and cowls? and could anyone please put up a photo of a complete and "how they should look" PA-12 baffles set for an O235 so I have something to aim at. Some in situ pics would be REALLY helpful too As you'll see in the pics below, some of the baffles have a kind of foam attached to their edges, is this standard? (By the way the tape around the Rocker covers is heat resistant tape that I used when troubleshooting the source of the oil leaks!!)
    3. I exchanged the mags for new Slick 4370/4371 and also a lovely red Kelly harness When I looked under the cowls again yesterday, I noticed that the (at least the lower plugs) have a 90 degree fitting on the original harness, but the Kelly has a straight fitting. I can swop the Kelly out if necessary, but wondered what other people are using? I'm assuming that with the appropriate clip placements the straight fittings can be positioned to loop around and stay away from the exhausts?
    4. As the engine I'm fitting is zero timed and essentially new, in addition to the straight oil we'll be using for the break in period, I'm thinking of starting on the right foot and using CamGuard or similar, what's the collected opinion on the value of this kind of treatment?
    5. Again, because the engine is new and lovingly just inspected and painted I'm considering fitting a spin on oil filter, I know this has been covered in other threads but I'm thinking Casper, I'd appreciate opinions on this and whether the Casper will actually allow the tacho cable in the pic to route straight past?
    Thank you in advance and I'm sure there'll be more questions before much longer
    Philly
ID:	46750Click image for larger version.
ID:	46751Click image for larger version.
    Last edited by Philly5G; 01-31-2020 at 01:51 PM. Reason: Pics and Spin on filter question added
    Every day's a school day
    May 2017
    574
    Just an FYI, I got a field approval to put a Sutton exhaust on my PA-16 with an O-235. 6 lbs lighter, and gets rid of the muffler AD. The O-235 is 3/8 narrower at the exhaust ports than an O-320, so it takes a little playing around to get it to fit without ant stress on the pipes and muffler. Havenít run it yet, looking forward to that, but likely will be a while as Iím just at the beginning of the restoration.
    10,675
ID:	46753Click image for larger version.
ID:	46754Click image for larger version.
    10,675
    Jun 2018
    England
    388
    Thanks for this Mike
    I do have both the digital and printed versions of the parts catalog. I use them a lot and find them very useful, although Iím really looking for the photos Iíve asked for to get the real detail and exact relative positions of the various bits and pieces
    10,675
    some firewall pictures in this album of mine, https://goo.gl/photos/PuiR5ha2aBDbkUBS8
    but it had a short mount/different heat system(Pa-18?)...(Mckenzie? STC)
    40m's Avatar
    Dec 2013
    Shoreham, VT
    410
    CamGard, perhaps a little like Holy Water you're not sure it really works but you would never walk by without splashing a little on.
    But if you do, not before engine is well broken in.
    From Genesis: "And God promised men that good and obedient wives would be
    found in all corners of the earth."
    Then he made the earth round... and He laughed and laughed and laughed!
    Likes Philly5G, DENNY, hotrod180 liked this post
    Jun 2018
    England
    388
    Quote Originally Posted by 40m View Post
    CamGard, perhaps a little like Holy Water your not sure it really works but would never walk by without splashing a little on.
    Great tip, thank you 40m, I hadnít realised yet that Cam Guard is post run in cycle
    1,832
    Baffles should be tight to cowling all the way around (I prefer felt). All small gaps on metal baffle closed with RTV or similar stuff.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,892
    The Caspar oil filter works fine with the standard /straight tach cable. At least on the 320 it does, that's what I have.
    Jun 2018
    England
    388
    Thanks Denny and tight up against the engine too?
    Jun 2018
    England
    388
    WOW!!! Thanks for all this Mike!!! there's some BRILLIANT detail stuff here!!!! (nice shirts by the way) I can see what looks like a heater box at the bottom of the firewall with its control cable coming from behind and down the starboard side of the firewall, but I don't see where the heat comes into the cabin? There seems to be a blanking plate on the cabin side of the firewall where the heater box would be, does it have a firewall forward scat tube or similar to duct the heat in somewhere?
    A general question, does the engine mount bolt through the firewall into the holes at the 4 corners at the front of the fuselage frame?
    Thanks again and looks like a LOT of work being shown in the pics
    Likes windy liked this post
    9,658
    Phil, That felt is the original baffle seal material. All it really does is to keep the metal baffle materiel from chewing on the cowl. It doesn't really maintain the sealling characteristics under all conditions. I like the wide Silicone baffle seal material. When care is taken to ensure there are no puckers in the installation, it lays down smoothly and does an excellent job of improving the cooling. https://www.aircraftspruce.com/searc...h.php?s=baffle
    I have seen improved cooling when changing to the silicone.
    19,109
    That is pretty funny from you Mike concidering a certain J3 thread.
    Jun 2018
    England
    388
    From looking at the Spruce photos it looks like the silicon attaches to the metal part of the baffles and fills up the gaps without need of the foam stuff, so itís basically just the metal frame and the silicon, is that correct?
    9,658
    Quote Originally Posted by Philly5G View Post
    From looking at the Spruce photos it looks like the silicon attaches to the metal part of the baffles and fills up the gaps without need of the foam stuff, so it’s basically just the metal frame and the silicon, is that correct?
    Yes. Just lay the silicone flat before drilling holes. Do not twist it so that it puckers between the fasteners. This is easy to see when you are working with it.
    2,868
    Ö..As the engine I'm fitting is zero timed and essentially new, in addition to the straight oil we'll be using for the break in period, I'm thinking of starting on the right foot and using CamGuard or similar, what's the collected opinion on the value of this kind of treatment? Ö.
    As already pointed out, no camguard til after the engine is broken is.
    I would also say no Lycoming additive or Aeroshell + oil that has the Lyc additive in it.
    Which "straight oil" are you gonna use for break-in?
    Used to be that ECI recommended using regular Phillips 20/50.
    I would check with whoever mfr'd your cylinders & see what they recommend.
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    722
    McFarland has some no-chafe stuff thatís a little stiffer. Iíve had it on for 3 or 4 years now and itís still tight to the cowl.
    https://www.mcfarlaneaviation.com/pr...ct/CS085X3GBF/
    19,109
    Pictures of 150 hp PA12 in my shop right now. Modified with Sutton exhaust. Has Airforms baffles.
    https://photos.app.goo.gl/t8e6eoQniX3jfM7x9
    Thanks mike mcs repair, Philly5G thanked for this post
    Jun 2018
    England
    388
    Quote Originally Posted by CamTom12 View Post
    McFarland has some no-chafe stuff that’s a little stiffer. I’ve had it on for 3 or 4 years now and it’s still tight to the cowl.
    Thanks for this and looks really well thought out. Interesting that the spec specifically refers to silicone being not great at all "Typical silicone rubber baffle seals have a coefficient of friction among the highest of any known material. This friction transfers engine vibration into your cowl and firewall causing fastener fretting, fatigue, cracking, chaffing and airframe vibration" does the McFarlane stuff really make such a difference?
    Jun 2018
    England
    388
    WOW!!!! THANK YOU for these Steve!!! These are pretty much exactly the clean, fresh and well-ordered look I'll aiming at!!! I'm loving the pic of the straight fitting HT leads being routed via the Rocker cover bolt clips, that's answered Question #3 PERFECTLY!!!
    I can see the heater box is mounted pretty much the same place on the firewall as mine/the standard one(?) but what is on the other side of the firewall? Just a single hole that the hot air blasts through? or some kind of tubing setup to distribute the heat?
    The baffles look fantastic, what kind of material is the non metal stuff?
    Thanks again
    9,658
    Phil, I don't recall specifically, but I think this is what I used as I bought most of my stuff from Spruce.
    https://www.aircraftspruce.com/catal...?clickkey=4767
    It is very smooth and slick. I can see no reason for it to adversely damage the cowl.
    Jun 2018
    England
    388
    Certainly a lot more affordable than the McFarlane stuff
    9,658
    Phil, The materiel which I used was Spruce part number 09-31800. It doesn't seem to be in their catalog any more.
    10,675
    Interesting modifications to cabin heat box... cold air hose added??
    Jun 2018
    England
    388
    Hi Steve this stuff has really helped, thank you!! I went to the hangar yesterday and dug out the heater box I have which is EXACTLY the same as the one in your pics AND it has the valve etc!!
    The position of the firewall hole and the muffler put the heater box pretty close to the muffler, so I'm planning to make an angled adapter and connect it directly to the firewall (as is the one in your pic) tilted back, to get more access to the lower (heat) connector.
    Do you have a pic that shows where the 2 Scat hoses connected to the heater in your pics are connecting to please? I'm guessing the fresh air one is going to one of the intakes in the lower cowl bottom and the heat one to the muffler?
    Thanks again
    19,109
    Yes, one goes to a fresh air pickup on the bottom cowl and the other to the cabin heat shroud on the aftermarket Sutton exhaust.
    Jun 2018
    England
    388
    Thanks Steve and I've just noticed the hole in the heat pipe fitting? I've also seen the same hole in another heater box pic on supercub.org.
Name:	Screenshot 2020-02-05 at 15.45.13.jpg
    Why is it there? Seems pretty dangerous as if there's any exhaust leak under the cowling and the heater flap is open, the exhaust gases will be sucked straight into the cabin?
    55-PA18A's Avatar
    Dillingham, Alaska
    615
    Is that for the hot air from the muffler shroud to dump out if the valve for the cabin heat isn't opened? It would get pretty warm in there if the hot air from the muffler shroud didn't have some place to go. I agree about being concerned about exhaust gas leaks, but remember this is the low pressure side of your engine cowling, so exhaust leaks and hot air from the muffler shroud SHOULD flow out with the engine cooling air. Not all works as it always should, and that's why having a working CO detector is important.
    I would be more concerned about exhaust leaks directly from the muffler into the shroud around the muffler.
    Jim
    9,658
    There is something wrong in this picture.
    The hot air from the heat muff should be coming in that larger tube to the valve box. The outside ambient ram air always passes through the heat shroud, then either overboard or into the cabin. Always flowing. When the heat valve is off, the air should flow through and out the open hole. When the heat is partly on, some hot goes into the cabin and some goes out that hole. When the heat is full on, all of the hot air goes into the cabin.
    What is the purpose of that smaller extra hose going down below the hole?
    9,658
    Another thing. The pivot on the valve appears to be in the wrong relationship to the overboard hole. Is there another photo which shows a bigger picture?
    Jun 2018
    England
    388
    According to the Parts catalogue the lower hole/tube on the heater box should actually connect to a hole/connector on the upper part of the shroud and support the heater box. Also, when the cabin heat knob is pulled out (for on) the flap in the heater box is pulled up allowing the airflow from the lower hole/tube into the cabin, this all points to the lower hole/tube being the hot air and the other hole/tube being unwarmed fresh air. My understanding is that ram air is piped into the heat shroud from one of the vent holes on the lower cowl and it's this flow that pressurises the warm air into the cabin.
    In this photo the heater box is actually connected to the heat shroud by the smaller scat hose, so although it's not the parts catalogue spec, it's still supplying the hot air? So this seems to be the correct config?
    Jun 2018
    England
    388
    ? It's in the same place as on my heater box, see the pic above where it's just resting on the heat shroud where the Parts Catalogue says it should be. In both photo cases the heater control cable comes out on the port side of the heater box and this aligns with the valve arm.
    Jun 2018
    England
    388
    Steve, where does the Scat hose from the front right baffle connect to? According to the Parts Catalogue, this hose should connect to the heat shroud to provide the pressure for the Cabin Heat. My PA-12 doesn't have an inlet on the front baffles, so to get some pressure for the cabin heater I'd need to use one of the lower cowling inlets OR modify the baffles. But also, my aircraft has the carb heat air ram air hose and connectors on the left rear baffle, rather than the right!!
    Jun 2018
    England
    388
    Starting work on redoing the baffles today by wrestling off the old felt and making a cardboard template to fill the gaping gaps on the back baffle
ID:	46942Click image for larger version.
    Also noticed there are baffles all the way from front to back horizontally underneath the cylinders on both sides, which I'm deducing are non standard as the pics in this link seem to prove https://www.knots2u.net/piper-pa-18-...ne-baffle-set/, as are the cowl hole bottom vents which join up with the under cylinder baffles....... Has anybody seen a similar arrangement? I already knew I'd be making new front baffles as I need to add the forward air intake for the cabin heater ram air feed, but the underneath baffles are a new discovery!!!
ID:	46944Click image for larger version.
    10,675
    can't say i seen baffles that far under cylinders... kinda useless looking..
    Jun 2018
    England
    388
    Yes, it looks like the baffle layout has been modified in an attempt to channel the air along the bottom of the cylinders, as I've just realised the inter cylinder baffles are missing
    19,109
    Common to the O-235 installation on the PA12, PA16 and PA22-108.
    Jun 2018
    England
    388
    WOW!!!! Thanks Steve!! So it IS a standard layout!!!! WOW and thanks again!! The aircraft was operating in professional aerial photography in Portugal before my ownership, which is a VERY hot climate and I've certainly never noticed anything untoward in temps when operating in UK, CHT stabilising at 180, so the cooling is obviously working ok in that config, would you suggest staying with this config? My real question in addition is that I need to add the intake for the cabin heater ram air and was considering making a "standard" ramped cowl/front baffle with the scat intake in that, but given this news what would you recommend?
    19,109
    The PA12 I took pictures of went home on Saturday. I will have to see if I have any more pictures of the install. One hose goes to an intake scoop on the bottom cowl. The other is to the heat muff on the Sutton exhaust.
    I don't think the original baffles are the best design but the O-235 is a low compression engine that normally doesn't even have an oil cooler. Operated one well past 2600 hours at which it wore out the rings and started using oil. Still had compressions in the 70s and inside of the engine looked great.
  1. Firewall Forward Kit PA18 180 Hp Titan
    By Lowleveldevil in forum Experimental Cubs
    Last Post: 01-31-2020, 06:29 AM
  2. Tanis Cabin Heater
    By WindOnHisNose in forum Products, Purchases, Reviews & Prices
    Last Post: 01-27-2016, 06:32 PM
  3. Jobs
    By Josh in forum Super Cub Repair Facilities
    Last Post: 11-16-2013, 09:17 AM
Tags for this Thread
