Page 3 of 3 FirstFirst 123
Results 81 to 98 of 98
Thread: Charlie’s Super Cub project
  1. #81
    4,073
    If you install the seat belt tabs, tack weld a nut, on the outboard side of the tab, over the hole for the seat belt bolt. Makes it easier to install/remove the belts in the future.
    Likes DENNY, moneyburner, RaisedByWolves liked this post
  2. #82
    11,702
    I decided not to do the weld on float fittings. I am not float rated and am not planning on putting it on floats. Plus it adds weight. Not sure if I am going to do the third seat as it adds 8 lbs. I am doing the H brace in the tail as part of the Tost tow hook installation. Still debating the gross weight increase STC. It’s expensive and I don’t really need it for my mission.
    There’s no way I’d do this much work to a Cub rebuild and NOT install the gross weight STC.
  3. #83
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    853
    I am still considering it.
    On another note. After a good hard look at the wings I am going to do some level of rebuild. Didn’t notice when I bought the project that there’s biplane N strut fittings attached to the spar. I don’t really have a problem with them but the spar isn’t as clean as I would like and a lot of the ribs are beat up from hangar rash.
    Sooo I was looking at Dakota Cubs website. I am thinking doing stock wings with their ribs and new spars using my old fittings. The squared off, extended wings with slots are very tempting! If I did them I would definitely do the gross weight increase. Does anyone know what the squared off wings do to the climb rate?
    The biplane N strut attach fittings are free to anyone who wants them FYI.
    They attach right below the wing strut attach fittings.
  4. #84
    Jan 2008
    Arlington, WA
    853
    My “welders” Travel Air he built from scratch. Looking forward to a ride in it!
  5. #85
    11,431
    Nice ! Is that a data plate restoration or a total EAB?
  6. #86
    Jan 2008
    Arlington, WA
    853
    Data plate he bought a set of logs.
  7. #87
    Jan 2008
    Arlington, WA
    853
    I am pleased all the big pieces of my engine came back in good shape!
    Likes RaisedByWolves, AkPA/18, Steve Pierce liked this post
  8. #88
    21,172
    What cam followers are you using? $600 for new Lycoming DLC units seems like good insurance to me after replacing several cams.
    Likes DENNY liked this post
  9. #89
    Jan 2008
    Arlington, WA
    853
    I didn’t send them out. I was waiting to see if the cam was airworthy. Good call on the DLC! Where’s the best place to get them Aircraft Specialties?
  10. #90
    4,518
    Post the part number when you get them.
  11. #91
    Jan 2008
    Arlington, WA
    853
    I am pretty sure this is the one I need for my O320-A2B. http://www.aircraftspecialties.aero/...ppet-15b26262/ They’re giving me a further discount because I sent in all my steel parts. I need to organize a parts list and get it ordered.
  12. #92
    21,172
    Thanks RaisedByWolves, Charlie Longley thanked for this post
  13. #93
    Jan 2008
    Arlington, WA
    853
    My welder was like, “Charlie why didn’t you have your fuselage blasted? It makes my job easier.”
    So I just got the fuselage back from the sandblaster. They did a pretty good job with it! It didn’t reveal anything I didn’t already know but it’ll make for a cleaner look when I paint it.
    Likes wireweinie, cubscout liked this post
  14. #94
    Jan 2008
    Arlington, WA
    853
    Welding is all done. Wow the 3rd seat X is stout! I crawled in and stood on it. Little to no flex.
  15. #95
    Jan 2008
    Arlington, WA
    853
    Moose and glidering season is over. Time to get back to work on my project! Just received an under seat storage compartment from Randy. It’ll take a little trimming especially around the 2,000 lb gross weight reinforcement tube.
    65” rack on the moose I helped get with my bro-in-law and nephew. More importantly the meat is awesome!
    My 15 year old nephew going right after it!
    Likes Riverking, Hardtailjohn liked this post
  16. #96
    Jan 2008
    Arlington, WA
    853
    A mans gotta do whatever it takes.
    Likes Sam D liked this post
  17. #97
    3,643
    Working at home when you have that nice shop at the airport?
  18. #98
    Jan 2008
    Arlington, WA
    853
    I don’t have the hangar at the airport anymore. Too expensive and too much work. I need to build a detached garage!
  1. Super Cub project
    By Bearhawk Builder in forum Cafe Supercub
    Last Post: 10-10-2019, 07:19 PM
  2. LOOKING FOR A SUPER CUB PROJECT
    By palhal in forum Super Cub Sick Bay
    Last Post: 09-12-2006, 09:56 PM
